RPM higher when cold?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RPM higher when cold?
Page: [1]
Login
RPM higher when cold? - 3/25/2012 5:37 PM
Scota4570
Score: 115
Last Login: 6/16/2013
Status: offline
It is not the needle settings.
I have been playing with my OPS maxi conversion. The Bowman ring has about 1-hour on it with synthetic oil. Yes, I know he suggests regular oil for break in. I am thinking that the compression is a little better when the oil is colder thus giving slightly higher compression. It is a matter of about 200 RPM. Not a big deal but interesting. Anyone seen this too?
Hide Signatures
       Post #: 1
RE: RPM higher when cold? - 3/25/2012 6:11 PM
av8tor1977
Score: 665
Last Login: 6/17/2013
Status: offline
Yes, I have frequently seen this; a sort of a "flash" reading of a couple of hundred rpms higher when an engine is cooler. It could be due to the viscosity of the oil helping ring seal, but I always attributed it to the crankcase being cool, and the engine getting a denser fuel/air charge than it does when the crankcase is warming the mix before it gets to the combustion chamber.
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to Scota4570)
       Post #: 2
RE: RPM higher when cold? - 3/25/2012 6:13 PM
SrTelemaster150
Score: 229
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Scota4570
quote:
ORIGINAL: av8tor1977
Yes, I have frequently seen this; a sort of a ''flash'' reading of a couple of hundred rpms higher when an engine is cooler. It could be due to the viscosity of the oil helping ring seal, but I always attributed it to the crankcase being cool, and the engine getting a denser fuel/air charge than it does when the crankcase is warming the mix before it gets to the combustion chamber.
AV8TOR
I've seen similar results on all of my Saito 4 strokes even when running glow fuel.
I think the assumpsions regarding ring seal & denser charge are correct.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 3
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> RPM higher when cold?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
