DLE 20 or ZEN G23 on a nosen citabria?? We're    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> DLE 20 or ZEN G23 on a nosen citabria?? We're
Page: [1]
Login
DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/28/2012 10:59 PM
93octane
Score: 105
Last Login: 4/14/2013
Status: offline
which engine would best suit this plane? have both later mag version of G23 and a new DLE 20. CG not an issue.thanks for your thoughts on this.........
Hide Signatures
       Post #: 1
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/28/2012 11:19 PM
w8ye
Score: 318
Last Login: 5/24/2013
Status: offline
Go with the DLE 20
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to 93octane)
       Post #: 2
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/29/2012 12:12 AM
MetallicaJunkie
Score: 243
Last Login: 5/17/2013
Status: offline
The 20 will have the edge in power.... if you need a ton of lead to balance, and dont want to use "dead weight" go with the g23
i think the 23 weighs over a pound and a half more
"Propellers are notorious for inflicting serious bodily harm while vigorously defending their space" George Aldrich
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/29/2012 1:26 PM
ahicks
Score: 669
Status: offline
As a Nosen Citabria owner, I don't get why you're saying C.G. is not an issue? Or do you just want the issue left out for purposes of this decision?
You're prepared for "scale" power levels with either of these choices?
Hide Signatures
(in reply to MetallicaJunkie)
       Post #: 4
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/29/2012 5:21 PM
AA5BY
Score: 153
Status: offline
Another comparison is starting... the G-23 on mag pretty much requires a starter.
Hide Signatures
(in reply to ahicks)
       Post #: 5
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/30/2012 1:33 AM
karolh
Score: 310
Status: offline
Before my G23 was converted to CD ignition it was ever so easy to hand start, and I only switched ignitions to lose some weight for my Goldberg Extra.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
(in reply to AA5BY)
       Post #: 6
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/30/2012 2:00 AM
AA5BY
Score: 153
Status: offline
Hi Karol... that is interesting. I've one that will do a lot of popping but is otherwise difficult to hand start. Enough so that I no longer make the attempt. I wonder if it is where I'm parking the prop. Should I park it at 10 o'clock and back from the compression and slap start it and let it gain speed through the compression?
Hide Signatures
(in reply to karolh)
       Post #: 7
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/30/2012 5:59 PM
karolh
Score: 310
Status: offline
Mine has no choke plate and if she is only popping maybe the carb is not wet enough, as most all Zens like being very wet prior to starting. I can't recall the exact prop position, but can remember that initially I used to have problems hand starting until I used the prop position as described in the manual, and I then began slapping the prop right through compression from about 3' oclock and down and away on the back side and she would start up quite easily with that method.
Hide Signatures
(in reply to AA5BY)
       Post #: 8
RE: DLE 20 or ZEN G23 on a nosen citabria?? We're - 3/30/2012 10:17 PM
AA5BY
Score: 153
Status: offline
Yeah... mine has no choke plate either. I do however have a hole in the cowl in line with the venturi and use a syringe with a tube measured to go into the venturi to prime. I'll go back and read the starting instructions. Thanks for the heads up as it is the only gas engine I've got that has been requiring a starter that has to be run on 24v and thus needs two batteries I'd rather not be fooling with.
Hide Signatures
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> DLE 20 or ZEN G23 on a nosen citabria?? We're
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
