Futaba R6014 Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Aviation Design Super Scorpion
Seller:  Modellbau USA
Details:   $6,750.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Futaba R6014 Question
Page: [1] 2   next >   >>
Login
Futaba R6014 Question - 3/29/2012 12:09 AM
YellowAircraft
Score: 186
Last Login: 5/25/2013
Status: offline
Hi,
You guys running this receiver.... is it fine to run two LiFe batteries into it?
_____________________________
Yellow Aircraft, JetCat Engines and Turn Key Jets
Hide Signatures
       Post #: 1
RE: Futaba R6014 Question - 3/29/2012 12:16 AM
Nick Yuhasz
Score: 100
Last Login: 5/24/2013
Status: offline
I've been running two A123's through 2 switches through Smartfly PowerExpanders through R6014's in 3 jets since 2008. No problem.
Nick
Nick Yuhasz
Amherst, Ohio
Hide Signatures
(in reply to YellowAircraft)
       Post #: 2
RE: Futaba R6014 Question - 3/29/2012 12:32 AM
Wap4life
Score: 110
Status: offline
I've been running 2 a123 bat with the orbitz from sin city.  No issues at all!
Wap
Hide Signatures
(in reply to Nick Yuhasz)
       Post #: 3
RE: Futaba R6014 Question - 3/29/2012 1:45 AM
phjoker
Score: 100
Status: offline
quote:
ORIGINAL: Wap4life
+1
same set up in my Flash over 100 flights no problems at all
Pete H
A Happy Jet Central Falcon & Rhino Owner
Hide Signatures
(in reply to Wap4life)
       Post #: 4
RE: Futaba R6014 Question - 3/29/2012 1:58 AM
readyturn
Score: 115
Status: offline
quote:
ORIGINAL: phjoker
quote:
ORIGINAL: Wap4life
+1
Are you runnng high voltage servos ?
Rick
Hide Signatures
(in reply to phjoker)
       Post #: 5
RE: Futaba R6014 Question - 3/29/2012 4:13 AM
furloughed ual
Score: 100
Status: offline
Sean, 2 LiFe/A123's directly into the 6014 for years. Zero issues.
Ryan
Team Futaba
[i] "somewhere between the port of indecision and southeast of disorder" [/i]
Hide Signatures
(in reply to readyturn)
       Post #: 6
RE: Futaba R6014 Question - 3/29/2012 4:24 AM
Gary Arthur
Score: 105
Status: offline
quote:
ORIGINAL: furloughed ual
Ryan
Team Futaba
Same here.
Hide Signatures
(in reply to furloughed ual)
       Post #: 7
RE: Futaba R6014 Question - 3/29/2012 1:15 PM
phjoker
Score: 100
Status: offline
quote:
ORIGINAL: readyturn
Rick
Futuba 9156's all around
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRAX0&P=ML
Pete H
Hide Signatures
       Post #: 8
RE: Futaba R6014 Question - 3/29/2012 5:12 PM
Meesh
Score: 100
Status: offline
I have the same set-up as Nick. No Problems!
Bob
If it''s worth doing, it''s worth doing it right.
AMA 779352, JPO 1965, IMAA 40337
Hide Signatures
       Post #: 9
RE: Futaba R6014 Question - 3/29/2012 7:13 PM
quist
Score: 116
Status: offline
I run this exact setup in 4 jets. Never a problem.
quote:
ORIGINAL: phjoker
quote:
ORIGINAL: readyturn
Rick
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
       Post #: 10
RE: Futaba R6014 Question - 3/29/2012 8:18 PM
mr_matt
Score: 116
Status: offline
So how do you guys handle the servos? you just run the 2 cell A123 power bus straight to the servos?
Matt
Hide Signatures
(in reply to quist)
       Post #: 11
RE: Futaba R6014 Question - 3/29/2012 8:24 PM
fireblade5437
Score: 105
Status: offline
I run Futaba 351 x4 and Hitec 7955 straight off A123 but not JR if you put a suitable diode in series with each positive to each JR which will drop around 0.5v so will make the A123 around 6.1v but certain JR don't like anything over 5v!
Alan
Hide Signatures
(in reply to mr_matt)
       Post #: 12
RE: Futaba R6014 Question - 3/29/2012 9:16 PM
PaulD
Score: 105
Status: offline
quote:
ORIGINAL: phjoker
quote:
ORIGINAL: Wap4life
+1
+2
Have 3 jets on this set-up.Works perfect.
PaulD
If it''s too LOUD - You''re too OLD
Hide Signatures
       Post #: 13
RE: Futaba R6014 Question - 3/30/2012 1:30 AM
Wap4life
Score: 110
Status: offline
I run all 8711 & 8411.
Wap
Hide Signatures
(in reply to PaulD)
       Post #: 14
RE: Futaba R6014 Question - 3/30/2012 6:04 AM
fireblade5437
Score: 105
Status: offline
How long you been running them on A123?
Alan
Hide Signatures
       Post #: 15
RE: Futaba R6014 Question - 3/30/2012 4:57 PM
Wap4life
Score: 110
Status: offline
about a year!  I just got into this hobby   Its been great!  This set is on my f-14 & mig 29 and all of my future jets.
Wap
Hide Signatures
(in reply to fireblade5437)
       Post #: 16
RE: Futaba R6014 Question - 3/30/2012 5:55 PM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: Wap4life
About how many flights?
Other futaba receiver/Jr servo combos were not always well behaved when the supply voltage was high.
Matt
Hide Signatures
       Post #: 17
RE: Futaba R6014 Question - 3/30/2012 5:57 PM
BaldEagel
Score: 118
Status: offline
Two A123's from an Orbit power jack, ever since the power jack has been available, prior to that just straight into the 6014 from two switch's no problems.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 18
RE: Futaba R6014 Question - 3/30/2012 6:33 PM
Meesh
Score: 100
Status: offline
The 12 Channel Smartfly provides "Filtered and Regulated 5.0V to the Receiver".
Quoted right from the front of the users manual. Using that with 2 2300 A123 packs no problems. This will be my 4th season with this set-up.
Hide Signatures
       Post #: 19
RE: Futaba R6014 Question - 3/30/2012 7:45 PM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: Meesh
The 12 Channel Smartfly provides ''Filtered and Regulated 5.0V to the Receiver''.
Yes that is the set up I have used in the past. i am curious about the scenario Wap4life is speaking of.
Does the smartfly regulate the voltage to the servos as well?
Matt
Hide Signatures
(in reply to Meesh)
       Post #: 20
RE: Futaba R6014 Question - 3/30/2012 8:45 PM
YellowAircraft
Score: 186
Status: offline
Hi,
Who's the 6014 guru? Anyone wanna give me a ring on a problem I'm having with this Rx? 619-944-7574. Basically, I tried to plug the second battery into the DG1 port, and the batter started to short. The Rx didn't get hot at all, but the leads to the battery got hot enough to melt the shielding. The Rx seems to be working fine, but did I just ruin this thing? What's the deal with the DG1 and DG2 ports??
Hide Signatures
       Post #: 21
RE: Futaba R6014 Question - 3/30/2012 11:15 PM
BaldEagel
Score: 118
Status: offline
DG1 and DG2 are on/off switched ports not proportional, so may connect or not when in operation, this may give you a short when operational as they are driven to one end or the other of their range.
Mike
Hide Signatures
       Post #: 22
RE: Futaba R6014 Question - 3/31/2012 12:01 AM
DAN AVILLA
Score: 100
Status: offline
Shawn I just pluged a ion into the battery port and a 123 into the DG1 or DG2 and it works fine. I suspect the plug on the battery might be the problem or some thing wrong with the reciever.
Like I said on my F100 I use the DG as the extra port for my second battery. If you have a 4 or 5 cell nicad you can use you might test it again. If you have a astro flite meter set it up to see what current it pulls when pluged in. It should be next to nothing. Dan
quote:
ORIGINAL: YellowAircraft
Hi,
Hide Signatures
       Post #: 23
RE: Futaba R6014 Question - 3/31/2012 12:20 AM
Hibrass
Score: 105
Status: offline
Shawn,
As stated DG 1 & 2 are digi on/off ports. They are connected to the main buse and can be used for power at anytime. If you are using a non Futaba plug just make sure the polarity is correct. Left pin is Black and the Center is Red. ( Referenced while looking at the end of RX with the face up with the DG plugs on the bottom...) If you get the wrong order it will short the Battery...
Good Luck,
Ed "6014" Harley
Hi,
Ed "Hibrass" Harley Club Saito #457
"If you don't know the Dog, don't yank his chain."
Hide Signatures
       Post #: 24
RE: Futaba R6014 Question - 3/31/2012 12:44 AM
DAN AVILLA
Score: 100
Status: offline
Just to clear that up. If you plug it in reverse nothing will happen. I just did that also. He is right about the positive needing to be in the center. Make sure you were not useing a airtronics extension.  Dan
Hide Signatures
(in reply to Hibrass)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
