Source for dural wing tubes    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Source for dural wing tubes
Page: [1]
Login
Source for dural wing tubes - 3/30/2012 12:16 AM
jetnuno
Score: 105
Last Login: 5/20/2013
Status: offline
Hi
I am looking for a wing tube for my SM big Hawk. I have received 2 from SM, but they just don't get the point. The first tube is a dural one and it looks sturdy, but it is short in lenght. The second tube is a carbon one, but because it could brake, they have filled it with resin and now weights 300gr. .
Does any one know a good source for reinforced dural tubes? I need one with 38mm OD.
Regards
Nuno
Hide Signatures
       Post #: 1
RE: Source for dural wing tubes - 3/30/2012 12:37 AM
ByLoudDesign
Score: 105
Status: offline
Nuno
I do not know that term: reinforced dural tubes, A lot of old plane that were fabric covered had sheet metal on the leading edge and it was called a dural nose!
Like to know what you are talking about.
Charlie
_____________________________
Kits: F11C-2 1:4, Do-24T 1:8, P-3 1:10, Howard 500 1:5, XFY-1 1:4, SR-9 1:4, V-22 1/6, B-25J 1:4, F+W C3603 1:5
Hide Signatures
(in reply to jetnuno)
       Post #: 2
RE: Source for dural wing tubes - 3/30/2012 12:42 AM
seflyer
Score: 105
Status: offline
TNT landing gear sells wing tubes, the nearest size to 38mm (1.496") is listed here. http://www.tntlandinggear.com/store/shop/wing_tubes.htm
Kevin
Hide Signatures
(in reply to ByLoudDesign)
       Post #: 3
RE: Source for dural wing tubes - 3/30/2012 12:52 AM
Square Nozzle
Score: 105
Status: offline
Nuno, in the USA we have a supplier for all sorts of hardware. It's called McMaster Carr ( www.mcmaster.com ). They have aluminum tube in different hardnesses. Check their web site and see if they have what you want. The only problem is whether they will ship to your country.
John
Hide Signatures
       Post #: 4
RE: Source for dural wing tubes - 3/30/2012 12:55 AM
Kevin_W
Score: 105
Status: offline
Just guessing but I think;
"Dural" is probably short for "duraluminum", which in the US is simply "aluminum". In the UK they call the same stuff "aluminium".
Kevin Whitlow
Texas Jetcat rep
Hide Signatures
(in reply to Square Nozzle)
       Post #: 5
RE: Source for dural wing tubes - 3/30/2012 1:04 AM
erbroens
Score: 105
Status: offline
Ola Nuno, tudo em ordem?
I faced the same problem with the Viper wing tube.
I just used a thick wall (about 2mm) 1 1/2 inch o.d. aluminum tube wich is twice as heavy as the original one but stronger, even if it is not sold as dural. Later I sent it to a local machinist to reduce a bit the outside diameter to fit the airplane fuselage and wings.
Um abraço, Enrique.
Hide Signatures
       Post #: 6
RE: Source for dural wing tubes - 3/30/2012 1:33 AM
ByLoudDesign
Score: 105
Status: offline
Thanks, Kevin
BTY www.onlinemetals.com is a great place to get all types of metal!!!!
Hide Signatures
(in reply to erbroens)
       Post #: 7
RE: Source for dural wing tubes - 3/30/2012 10:37 AM
PaulD
Score: 105
Last Login: 5/18/2013
Status: offline
Here ya go:
http://www.troybuiltmodels.com/items/JAE38X950.html
Good deal for a Carbon tube.
http://aero-works.net/store/detail.aspx?ID=267
PaulD
If it''s too LOUD - You''re too OLD
Hide Signatures
       Post #: 8
RE: Source for dural wing tubes - 3/30/2012 3:42 PM
RUFTER
Score: 104
Last Login: 5/19/2013
Status: offline
http://shop.lindinger.at/product_info.php?cPath=1749_1755&products_id=66812
This might work.
Regards, Bart.
Team Harofly
Hide Signatures
(in reply to PaulD)
       Post #: 9
RE: Source for dural wing tubes - 3/30/2012 3:54 PM
dbsonic
Score: 100
Status: offline
Dural. I dont know what that is. And not all aluminum is created equal as there are lots of different yield strengths out there.
Carbon is usually a good choice and its unlikely you need solid but of course it does increase the AMOI. Post crash Ive seen nothing left but a solid carbon rod sticking out of the ground. those things are tough.
Hide Signatures
(in reply to PaulD)
       Post #: 10
RE: Source for dural wing tubes - 3/30/2012 4:31 PM
ByLoudDesign
Score: 105
Status: offline
If you want aluminum for your models, the aircraft grades are the way to go, 6061-T6 for anything that is flat [Note: 6061-T6 dose not bend tight enough for small parts, and most likely crack a/o break]. Then it is 5052-H32 is A/C grade bendable aluminum. Both drill and tap well. Carbon is about 25% lighter the aluminum and much stronger the aluminum, allowing you to use smaller components.
Hide Signatures
(in reply to dbsonic)
       Post #: 11
RE: Source for dural wing tubes - 4/1/2012 7:03 PM
jetnuno
Score: 105
Status: offline
Hi
Thanks for your replies. In fact what I am looking for is a decent wing tube that can cope the high G manouvers in a jet.
Dural is the short term for duraluminium. It is what you guys in the US call alloy, right? It is a harder aluminium with more shear strenght.
Also found this for people in Europe
http://www.shop-en.carbon-composite.com/index.php?cat=KAT11-10100
Regards
Nuno
Hide Signatures
       Post #: 12
RE: Source for dural wing tubes - 4/1/2012 9:13 PM
jetnuno
Score: 105
Status: offline
Hi
Do you think this tube could do the job?
http://www.regals-motorsport.co.uk/aluminium-pipes/straight-alloy-pipes/38mm-od-x-1000mm-1m-straight-t6-grade-6063-alloy-pipe-hj-1000-38.html
Regards
Nuno
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
