Traxxas TQi thoughts??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Radio Equipment >> Traxxas TQi thoughts??
Page: [1]
Login
Traxxas TQi thoughts?? - 3/30/2012 3:51 PM
phmaximus
Score: 627
Last Login: 5/19/2013
Status: offline
Hey guys whats ur thoughts on the TQi????
I personally love its telemetry and ipod dock.
Ive heard it feels cheap , but there is no real facts to that. maby those people could fil it up fith some weights & make a lether grip with diamond studs... lol
Im currently running the Traxxas Link 2.4ghz 5ch on 5 out of 13 cars & plan to upgrade the rest to run of the one controller.
Im mainly running that TX because i dont know of any other that controll 5ch.
Ive since found out that the TQi is compatable with the RX's i use. how cool is that
So im planing to upgrade my TX tothe TQi and outfit my other cars with the telemetry RX's
What u guys think, know a better 5ch pistol grip TX with model memory?
_____________________________
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
       Post #: 1
RE: Traxxas TQi thoughts?? - 4/1/2012 2:35 AM
phmaximus
Score: 627
Status: offline
Here is some info on them
MODEL 6507: TQi Transmitter, 4-channel with 5-channel Receiver and Docking Base
MODEL 6508: TQi Transmitter, 4-channel with 5-channel Receiver
MODEL 6509: TQi Transmitter, 2-channel with 5-channel Receiver
MODEL 6510: TQi Docking Base
MODEL 6518: TQi 5-channel Receiver
■Sleek Design with Internal Antenna
■5-Channel Receiver with 3 Telemetry Ports
■Traxxas Link Model Memory for up to 30 Models
■Simple 2-Button Programming Interface
■Built in Failsafe
■Direct Sequence Spread Spectrum Technology (DSSS)
■Uses only 4 AA Batteries
■Accessory Docking Base Connects TQi with Apple iPhone or iPod touch
■Traxxas Link Application Provides Visual Access to: ■Real-Time Telemetry
■Customizable Dashboards
■Steering/throttle expo
■Steering/braking dual rate
■Servo reversing
■Endpoint adjustment
■Profile customization and sharing
■Manage an unlimited number of models with the Traxxas Link App
TQi 2.4GHz Radio System Features:
■High Output signal for maximum range
■Integrated internal antenna
■Simple 2-Button Interface
■Steering trim and Multi-Function knobs
■Adjustable steering and throttle percentage (dual rates)
■Adjustable steering and throttle sensitivity (exponential)
■Adjustable steering and throttle end points
■Automatically stores and loads settings for up to 30 Traxxas Link Model Memory enabled models—just switch on and drive, "model selection" is not required.
■High 13ms frame rate and near-zero latency for responsive control
■Telemetry enabled 5-channel micro receiver with dual channel-1 inputs
■Comfortable ergonomic design
■New steering wheel and foam grip
■Operates on just 4 AA batteries
TQi Docking Base (#6510) Features:
■Quickly installs on the TQi transmitter
■Accepts Apple iPhone and iPod touch
■Height adjustment pads included for iPhone and iPod touch devices with and without cases
■Secure clamping mechanism holds iPhone or iPod touch in place via three rubber padded cleats
■Capable of charging Phone or iPod touch
■Accepts accessory 5-cell NiMH rechargable battery pack (#3037)
■Integrated charge jack for use with NiMH batteries
■TQi Docking Base included on select Traxxas vehicles
Traxxas Link Application Features:
■Intuitive iPhone and iPod touch interface
■Customizable Dashboard ■Dial or digital readout gauges
■Up to nine gauges can be displayed at one time
■Set threshold warnings and log maximums, minimums, or averages
■Review telemetry feedback via the dashboard recording function that includes sound
■Instant replay feature captures the previous 60-seconds of dashboard activity
■Recordings can be named and saved
■See telemetry feedback from electric and nitro models for speed, temperature, and voltage
■Edit, save, and share drive profiles
■Visually manage an unlimited number of models with the Traxxas Link App and see: ■Transmitter model history
■Model names
■Customizable settings
■Profiles
Hide Signatures
(in reply to phmaximus)
       Post #: 2
RE: Traxxas TQi thoughts?? - 4/1/2012 2:46 AM
phmaximus
Score: 627
Status: offline
#6523 - Temp/Voltage Telemetry Sensor (short)
#6521 - Temp/Voltage Telemetry Sensor (long)
#6535 - Temp Sensor Mount for Electric Motors
#6522 - RPM Telemetry Sensor (short)
#6520 - RPM Telemetry Sensor (long)
#6541 - Power Tap for Voltage
Sensor with Cable and Accessories
#6860R - Motor Mount for Models 6808,6807, 6708
Blue-Anodized Machined Aluminum
#6860A - Motor Mount for Models 6808,6807, 6708
#6538 - Spur Gear Telemetry Trigger Magnet Holder
#6539 - Center Diff Telemetry Trigger Magnet Holder
#6540 - Telemetry Trigger Magnet (5mm x 2mm)
#5677A - Sensor-Ready Gear Cover for Model 5603
#5677R - Sensor-Ready Gear Cover for Models 5608, 5607
#3977A - Sensor-Ready Gear Cover for Model 3903
#3977R - Sensor-Ready Gear Cover for Model 3908
#3792 - Sensor-Ready Gear Cover for All Rustler, Bandit, Stampede
and 2wd Slash
#6537 Wire Retainer
#7077R - Sensor-Ready Gear Cover for 1/16 VXL Models
#7379R - Sensor-Ready Gear Cover for 1/16 Models
with Titan 12T
#7045R - 45-tooth Spur Gear for Telemetry
#7046R - 50-tooth Spur Gear for Telemetry
#7047R - 55-tooth Spur Gear for Telemetry
#6542X - Flywheel for Telemetry
(large, knurled for use with starter boxes)
#6542 - Flywheel for Telemetry (35mm)
#6536 - RPM Sensor Mounts
for Nitro Models
#6550 - Telemetry Expander Module
Plugs directly into the TQi receiver and
allows the use of additional sensors and
the GPS module
#6551 - GPS Module
Provides the most precise speed
information based on GPS location instead of RPM
Hide Signatures
       Post #: 3
RE: Traxxas TQi thoughts?? - 4/2/2012 1:04 AM
TheKennyKiller
Score: 462
Last Login: 1/23/2013
Status: offline
They look pretty good and if you're in to the iPhone thing I guess it will come in handy. A buddy of mine over on the Summit thread says the wheel is smaller then the old one and it feels a little tight, it might loosen up with a bit of use though.
Do you even RC?
Hide Signatures
       Post #: 4
RE: Traxxas TQi thoughts?? - 4/2/2012 1:33 AM
Summit is Beast!!!
Score: 436
Last Login: 5/14/2013
Status: offline
My buddy just bought the "slow POS toy" summit according to phmax. The new 1...i have the 1 b4 the new 1. I hate hate hate the new controller, its tiny compared to mine and the wheel is super tight and id say a half inch smaller than my wheel. Which means alot to me maybe not to others. Thats just my opinion tho, but hey what do i know im an unexperienced noob right.
Summit-$564, Tires and wheels-$150, lipos,servos and all my hopups-About $700, being the owner of the best rc ever-priceless
Hide Signatures
(in reply to TheKennyKiller)
       Post #: 5
RE: Traxxas TQi thoughts?? - 4/2/2012 11:00 AM
phmaximus
Score: 627
Status: offline
Hummmm little tight.... that might be a easy fix... might look into that
I see what u mean by the size....
Hide Signatures
(in reply to Summit is Beast!!!)
       Post #: 6
RE: Traxxas TQi thoughts?? - 4/2/2012 11:17 AM
phmaximus
Score: 627
Status: offline
That sucks about the wheels size, Dammmm. still if there is a will thereis a way....
Before u upgraded to 2.4ghz i use to use the HPI/Onfa radios. and was use to the nice rubber grip.
When i went to the traxxas controller I hated the feel of the foam & it felt to small. Allso I dident like the fact that it dident show the voltage like most other 2.4ghz controllers, but it was the only controler that could controll 5ch. even tho its listed as a 4ch.
Well anyway this is what I did to my controller. I fitted a volt meter & a touring car tyre to the wheel.... dare say might be able to mod the newer controller in the same way.... Untill the new controller came out I was planing to Jam a BEC in it & run a lipo... the advantage would be i could run it if any voltage battery providing it fitted.
Here is one of my current controllers.... soon will be up for sale with reciver & i will be selling a non "link" one with a reciver
Hide Signatures
       Post #: 7
RE: Traxxas TQi thoughts?? - 4/2/2012 11:21 AM
phmaximus
Score: 627
Status: offline
This is the older style controller I was use to... I sold if off with the car pictured.
Hide Signatures
       Post #: 8
RE: Traxxas TQi thoughts?? - 4/2/2012 1:50 PM
Summit is Beast!!!
Score: 436
Status: offline
Hmmmmm thats a pretty sweet controller. How much will u be asking for it?
Hide Signatures
       Post #: 9
RE: Traxxas TQi thoughts?? - 4/2/2012 3:36 PM
phmaximus
Score: 627
Status: offline
Dont know yet... around $60-70 with spare arial & the 5ch reciver only because the recivers are around $30 so thats only $30-$40 for the controller itself with a spare arial For a additional $10 i can sepperate the 4th & 5th channel so they have there own switch....
Hide Signatures
       Post #: 10
RE: Traxxas TQi thoughts?? - 4/3/2012 11:20 AM
TheKennyKiller
Score: 462
Status: offline
quote:
ORIGINAL: Summit is Beast!!!
If you buy it at least you won't have to worry about supplying your shipping address.
Do you even RC?
Hide Signatures
       Post #: 11
RE: Traxxas TQi thoughts?? - 4/3/2012 11:49 AM
phmaximus
Score: 627
Status: offline
LMAO now now, lol
Hide Signatures
       Post #: 12
RE: Traxxas TQi thoughts?? - 4/3/2012 8:51 PM
Summit is Beast!!!
Score: 436
Status: offline
Lmfao i was thinking the same thing!
Hide Signatures
       Post #: 13
RE: Traxxas TQi thoughts?? - 5/15/2012 2:14 PM
phmaximus
Score: 627
Status: offline
Well I've had my controller for a few weeks now, and love it...
Problems well I left it in the car and one f the kids stepped on it braking off the lever for the dock, still works ok just harder to lock a iPod in.
Only other complaints... It can't be changed from mph and f to km/h and c.
Oh and u can't set custom wheel sizes....
Hide Signatures
       Post #: 14
RE: Traxxas TQi thoughts?? - 6/11/2012 8:01 AM
phmaximus
Score: 627
Status: offline
woot not long till the expander comes out
Hide Signatures
       Post #: 15
RE: Traxxas TQi thoughts?? - 7/20/2012 8:54 AM
phmaximus
Score: 627
Status: offline
Traxxas Selects Cypress's WirelessUSB-LP™ Radio Solution For World's Fastest Ready-To-Run Radio Controlled Car
Hide Signatures
       Post #: 16
RE: Traxxas TQi thoughts?? - 8/7/2012 12:01 PM
bigblock454XXL
Score: 391
Last Login: 5/7/2013
Status: offline
I always wanted one since they came out and I now own the XO-1. It's a nice controller and the size of the wheel was my first thought. But to me a smaller steering wheel is a great idea. It was so good that I bought my 6 year old son the TQi controller too for his 30th Anniversary Grave Digger. I love the no-folding antennea. My son has had his truck 3 weeks and has allready broke the antennea and bent the second one. Not from abuse but from trying to push it in. Hahaha. I've broke a few too in my lifetime. So finally words. I love the TQi and haven't found anything wrong with it. But I race my Short Course truck with a Spektrum.
Full Member of ECMT. Tamiya Hauler with Custom Aluminum Trailers. Drop deck and Flatbed''s, Loading Dock and Scale Garage.
Hide Signatures
       Post #: 17
RE: Traxxas TQi thoughts?? - 10/10/2012 4:51 PM
dadon
Score: 100
Last Login: 2/12/2013
Status: offline
some of you said they look cheep..... hmmmmm I have one here this new style with docking base for ipod. It developed a problem and LED doesnt go on as well as the top part of the TX is dead. When Ipod is connected and I switch on button the Ipod is binded with TX but the TX does not work and no LED light.
I spoke to 2 people with exactly same problem. I think TQI with docking base is not yet fit for general sale. Obviously there are some problems which are not yet sorted out.
BTW - if anyone knows hot to fix top of the TX (as docking base is working) please let me know.
Firestorm Flux, Hyper 8.5 pro, MERV, Traxxas 4tec, Traxxas E-Maxx 3.3, Traxxas E-Maxx MM 3809,
to be - Savage Flux HP
Hide Signatures
(in reply to bigblock454XXL)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
