RE: Scratch Designed/Built Sailplane    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> RE: Scratch Designed/Built Sailplane
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: Scratch Designed/Built Sailplane - 4/22/2012 4:46 AM
Nodd
Last Login: 5/17/2013
Status: offline
I got 90% of the v-tail done today, SWEET!
I decided to do things properly & use a symmetrical airfoil for the tail feathers. Flat stabs tend to stall sooner than those with an airfoil... stalling = bad. I printed a set of tail ribs & contact cemented them to the wood...
Used my scroll saw to rough-cut the ribs...
Finished up the rib shapes with a sanding block...
The notch in the ribs is to accommodate some carbon fiber reinforcing. I glued a small CF tube to the center spar, it should make the tail nice & rigid...
The root of the v-tail is made from some fairly dense 3/8" balsa, carved to the airfoil shape. It should give a nice solid foundation for the tail & hopefully make mounting everything to the tail boom a snap...
Looks like something that belongs on a jet... fun fun. I still need to add the strengthening gussets & do some sanding. Will pick that up tomorrow...
_____________________________
Nodd
Check out my YouTube videos: http://www.youtube.com/user/noddscipie
Hide Signatures
(in reply to Nodd)
       Post #: 51
RE: Scratch Designed/Built Sailplane - 4/22/2012 8:17 AM
highfly3D
Last Login: 5/10/2013
Status: offline
very nice build.. Which scroll saw are you using for cutting the ribs?
I will say it only once Yak 54 the best aerobatic plane ever made.
Hide Signatures
(in reply to Nodd)
       Post #: 52
RE: Scratch Designed/Built Sailplane - 4/22/2012 7:35 PM
Nodd
Status: offline
quote:
ORIGINAL: highfly3D
Thank you. Mine is a bog-standard, entry level, 16" scroll saw from Skil Tools. Other than color, as far as I can tell its identical to the Ryobi scroll saw currently available at the Home Depot. Both are relativly cheap, kinda wobbly, vibrate like crazy at high speed but are invaluable in the workshop. I'm not sure how I ever got along without one. There's several other brands worth a look but if you have the cash & want a quality tool, I've heard the DeWALT DW877 is the saw to get. Silky smooth, vibration free cutting & made to last.
Nodd
Hide Signatures
(in reply to highfly3D)
       Post #: 53
RE: Scratch Designed/Built Sailplane - 4/23/2012 2:02 AM
Nodd
Status: offline
Why is it the last 10% takes 90% of the time?
So I started adding gussets to the v-tail. I carefully measured the required angle then set about making 32 of these little buggers...
Then I noticed, duh, I'd need different shaped gussets for different areas of the tail. The leading edge, for example, runs at a different angle to the ribs than at trailing edge. After a long groan I tossed most of them & set about cutting out a new set. Anyway here's a panel with the corrected gussets installed. Came out nice & strong & fairly light...
And now for the next time sucking issue...
One of my ruddervators (love that word) annoyingly appears to have developed a moderate warp along its hinge line...
So back to my damp sponge trick, I saturated the wood then using a straight-edge as a guide, secured it to my workbench. I'll let it sit overnight, fingers crossed she'll be straightened out come morning...
Nodd
Hide Signatures
(in reply to Nodd)
       Post #: 54
RE: Scratch Designed/Built Sailplane - 4/23/2012 4:02 PM
FlyerInOKC
Status: offline
Hey Nodd,
What is the worse warp you ha been able to fix with the sponge trick?
My workbench where you always find the weird and unusual! Sig Kadet Brotherhood #89 Ryan STA/STM/SC Brotherhood # 27
Hide Signatures
(in reply to Nodd)
       Post #: 55
RE: Scratch Designed/Built Sailplane - 4/24/2012 5:54 AM
Nodd
Status: offline
Theoretically you could take a piece of balsa, bend it around so one end touches the other. Just add water, bend, let dry & repeat. Its pretty malleable stuff if you take your time. Steaming or heating in an oven are other wood bending techniques.
Nodd
Hide Signatures
(in reply to FlyerInOKC)
       Post #: 56
RE: Scratch Designed/Built Sailplane - 4/24/2012 5:56 AM
Nodd
Status: offline
I had a great session today, got a lot done. Best of all I'm not all grumpy like I was yesterday.
The warp in my ruddervator is better but I'm still not happy with it. Will give it another go with the damp sponge trick & see where that takes me...
So anyway, I'm not letting that issue slow me down. Time to make a V out of my tail...
I needed to add a 55° bevel to each of my tail-feathers. I spent some time scratching my head, thinking up all sorts of crazy jigs & whatnot. In the end I decided to just get on with it & adjusted the table on my belt sander to 55° & went for it...
With very little fine tuning from the block sander, amazingly she went together at exactly 110°, SWEET!..
Again with the head scratching, I needed a way to attach the v-tail to my CF tail-boom. Actually that's the easy part, I'm just going to fiberglass it around the tail-boom. The tricky part was finding a way to make sure the tail lines up straight. So here's what I came up with... I temporarily tacked a short section of scrap CF tube to the v-tail making sure it ran down the joint precisely. I then epoxied two small strips of plywood either side to just the tail, not the CF...
While that set I carved a few short slots in the very end of the tail-boom. The thinking here is that'll give the glue something to index & hopefully keep the tail from working loose & spinning on the shaft. I also roughed up the CF with some course sandpaper...
Next I mounted the wing center section to the fuselage & used a bunch of clamps to hold the wing perfectly level with my work bench...
Yet another use for the amazing Quick Grip clamp, love those things. Once I had the airframe squared up I removed the temporary CF tube from the tail then went ahead & epoxied the v-tail to the tail-boom. I used a ruler to check it was square with the bench, propped it up with a glue bottle & I'm leaving this puppy to set overnight...
Tomorrow I'll reinforce the tail joint with fiberglass. Feels great to finally get the tail on there. Another major milestone achieved, YIPPY!
Nodd
Hide Signatures
(in reply to Nodd)
       Post #: 57
RE: Scratch Designed/Built Sailplane - 4/24/2012 10:52 AM
highfly3D
Status: offline
very good... this reminds me of the Kyosho Glider
Hide Signatures
(in reply to Nodd)
       Post #: 58
RE: Scratch Designed/Built Sailplane - 4/25/2012 4:40 AM
Nodd
Status: offline
Yeah she looks a little like the Kyosho, ONLY TOTALLY COOLER! *grin* just kidding
Nodd
Hide Signatures
       Post #: 59
RE: Scratch Designed/Built Sailplane - 4/25/2012 4:42 AM
Nodd
Status: offline
Odds & Ends
No photos today. I didn't really do anything photo-worthy, just lots of odds & ends. Here's a quick list of what I got done...
  • Visited hobby shop & picked up nicknacks, control horns, pushrods etc
  • Finished fiber-glassing the v-tail to the tail-boom
  • Fixed the warped ruddervator by sanding it straight
  • Trimmed to length all the control surfaces
  • Installed the two ruddervator pushrods
  • Did more sanding here & there
Movie night tomorrow so not sure how much I'll get done but I believe I've arrived at yet another milestone. It might finally be time to break out the Ultracoat, WOOHOO!
Nodd
Hide Signatures
(in reply to Nodd)
       Post #: 60
RE: Scratch Designed/Built Sailplane - 4/25/2012 2:49 PM
FlyerInOKC
Status: offline
quote:
ORIGINAL: Nodd
Odds & Ends
A photo of the fiberglassing of the V tail would have been note worthy in my view.
Hide Signatures
(in reply to Nodd)
       Post #: 61
RE: Scratch Designed/Built Sailplane - 4/27/2012 6:05 AM
Nodd
Status: offline
Here's a detail of how the tail was fiber-glassed to the tail-boom...
Added some stylish wingtips...
Bare-Bones
And with that the airframe is complete, wO0t! Before she's covered I thought I'd take a few bare-bones photos to help celebrate...
Feels great to have gotten this far.
Nodd
Hide Signatures
       Post #: 62
RE: Scratch Designed/Built Sailplane - 4/27/2012 6:32 AM
BMatthews
Last Login: 5/14/2013
Status: offline
I'm beginning to get all goose pimply thinking about the test flight post.
It's coming along great. And you've done a really fine job of doing a comprehensive build thread.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to Nodd)
       Post #: 63
RE: Scratch Designed/Built Sailplane - 4/27/2012 2:47 PM
FlyerInOKC
Status: offline
quote:
ORIGINAL: BMatthews
AMEN!
Hide Signatures
(in reply to BMatthews)
       Post #: 64
RE: Scratch Designed/Built Sailplane - 4/29/2012 4:34 AM
Nodd
Status: offline
Thanks guys. Yeah I'm not sure which I've spent more time on, the plane or this silly build thread LOL
Wrapping Things Up
Well we can't have this glider parading around naked, time to do some covering. I chose to use Hanger 9 Ultracoat as I've worked with it before & like the way it applies. Low temperature to activate the adhesive then switch to higher temp to do the shrink-wrapping. Its also pretty forgiving & most wrinkles can be eliminated with some heat...
I wanted to show off the built up structure so I'm using transparent red on the open areas & opaque white everywhere else...
Before I got too far into the wing covering I performed another balance check...
I centered the wing on my balance stand & added weight to the light side...
Three small nails on the left wingtip & she balances perfectly. There is a school of though that says its a mistake to add weight at the tips as this adds unwanted mass way out on the ends of the wing, not where you want it. Its often better to add weight further in & keep the tips as light as possible. The down side is you need more weight to achieve the same result. As my wing was already balanced fairly close & needed just a few grams I felt it was fine to just stick the nails into the end of the wing...
If you use nails for weight you should pre-drill the holes. Don't go hammering away at your wingtips, bad idea. Once in place a drop of CA glued keeps them secure...
Here's my home-brewed CG balance stand. Simple & because its in two pieces it fits just about any airplane. Note the spiffy rubber tips to keep things from slipping while balancing...
Anyway with the wing balanced I covered over the nail holes & turned my attention to the v-tail...
I'm trying something new on this model. I usually use CA hinges but I noticed one of my ARF gliders uses just the covering its self as a hinge joint. The result is a gap-less joint that's fairly sturdy & doesn't seem to bind at all. If my ruddervators start to fall off in a month or so I guess its back to CA hinges but my other glider has been around for years & no signs of hinge fatigue yet. So I thought I'd give it a try. Here's how my hinges are laid out...
From the top at least the joint looks totally seamless. Obviously there's a small slot on the under-side to allow the control surface to move downwards but aerodynamically its pretty clean. I like...
Well that's enough for today. I'll tackle the rest tomorrow...
< Message edited by Nodd -- 4/29/2012 7:36 PM >
Nodd
Hide Signatures
       Post #: 65
RE: Scratch Designed/Built Sailplane - 4/29/2012 7:17 AM
highfly3D
Status: offline
Awesome... great superb..
Hide Signatures
(in reply to Nodd)
       Post #: 66
RE: Scratch Designed/Built Sailplane - 4/29/2012 12:35 PM
sylvie369
Last Login: 12/29/2012
Status: offline
This "silly build thread" is the most educational thing I've seen here.
On the other hand, it's depressing to see how much work I have to do on my covering technique. I'd better get another build started for practice.
Hide Signatures
       Post #: 67
RE: Scratch Designed/Built Sailplane - 4/30/2012 2:17 PM
FlyerInOKC
Status: offline
I prefer using hinges and thenusing either clear tape or covering to hide the gap. On large aircraft I round the moveable surface and then make a matching concave slot in the trailing edge of the mating surface.
Hide Signatures
(in reply to sylvie369)
       Post #: 68
RE: Scratch Designed/Built Sailplane - 4/30/2012 8:34 PM
BMatthews
Status: offline
The plastic covering films work fine on slower flying models even up to 3 meter span gliders. For a faster powered or contest sailplane where high speeds will be regularly used then I like the security of proper hinge with some sort of sealing film or tape. In the case of a sport glider such as what Nodd is doing here I'd be using the film hinges as well. Simple, clean, and workable for a model such as this.
Nodd, the first sign of any possible "hinge distress" will tend to show up on the longer hinge lines such as on the ailerons. This can occur if the wings flex up under load and you're flexing the ailerons at the same time. So keep an eye on all the hinges but especially the ailerons.
Hide Signatures
       Post #: 69
RE: Scratch Designed/Built Sailplane - 4/30/2012 10:46 PM
rhall999
Last Login: 3/26/2013
Status: offline
First off, let me say that you have built one heck of a nice looking glider!!
Now, if it makes you feel any better.....I have been using that "covering hinge" method for quite a few years.  When done properly it is a superb, trouble free system.  To reiterate what Bruce said, it is best on slower aircraft such as gliders and park flyers, and you will have no problems with yours at all.  Now, just to show you how well they can stand up even on an aircraft that is able to fly a bit faster and put more loads on the controls................
This nice green airplane does not have a single "proper hinge" anywhere.  Every control, ailerons, elevator, and rudder, are ALL done with the exact system you show above in your diagram.  After 1 full season of hard flying, including a bunch of glider towing.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 70
RE: Scratch Designed/Built Sailplane - 4/30/2012 11:02 PM
FlyerInOKC
Status: offline
Nice Rhall999! Is that a Hoerner wingtip you have on the green airplane? What are the specs?
Hide Signatures
(in reply to rhall999)
       Post #: 71
RE: Scratch Designed/Built Sailplane - 4/30/2012 11:35 PM
rhall999
Status: offline
Sorry Nodd, we are heading slightly off topic for a couple minutes
Hi Flyer, that there green machine is a just good ole' Sig Kadet Seniorita kit, somewhat modified.  It was made a taildragger, ailerons were added, went to a bolt on wing.  The drooped STOL tips were hand carved/sanded until "they looked about right", and I also added mounts for floats while building it.  It is powered by a Saito .30 with an APC 12X4.  Wingspan on the box is listed at 63", I haven't measured to see how close it is with my fancy tips installed.  It came out at 3.7 pounds, all up ready to fly, so you can imaging how nice and slow it can go with that much wing!!  I built it mainly to be able to tow small (2-3m) sport gliders, and to date it has succesfully towed a GP Spirit 2m and a 111" span Sagitta 900.  Plus, it is just a whole lot of fun to fly when a guy feels like a relaxing putt-putt sort of flight.
Anyhow......back on topic..............I have a question for Nodd, what are you going to call that beauty that you built.  (Maybe you already said, but I might have missed it)
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 72
RE: Scratch Designed/Built Sailplane - 4/30/2012 11:57 PM
Nodd
Status: offline
Nice Kadet. Yeah some of the guys I fly with are into the aerotow thing. I'm planning to attend the New England Aerotow 2012 next month. Trying to get my 4m Discus ready for that. Will probably bring this plane with me too as they allow motor-gliders. Should be fun.
quote:
ORIGINAL: rhall999
...I have a question for Nodd, what are you going to call that beauty that you built.  (Maybe you already said, but I might have missed it)...
An excellent question which unfortunatly I have no answer for just yet. I do have a few ideas though. We'll see.
Nodd
Hide Signatures
       Post #: 73
RE: Scratch Designed/Built Sailplane - 5/1/2012 12:18 AM
Nodd
Status: offline
quote:
ORIGINAL: BMatthews
...Nodd, the first sign of any possible "hinge distress" will tend to show up on the longer hinge lines such as on the ailerons. This can occur if the wings flex up under load and you're flexing the ailerons at the same time. So keep an eye on all the hinges but especially the ailerons...
No kidding, that makes a lot of sense. Yeah these wings are likely to be prone to some flex. I supose placing small gaps here & there along the hinge tape/covering might help with that, although that'd also introduce more places for a crack to form. I guess we'll see what happens. Thanks for the tip.
Nodd
Hide Signatures
       Post #: 74
RE: Scratch Designed/Built Sailplane - 5/1/2012 12:21 AM
rhall999
Status: offline
Well, you'll just have to let us know later when you decide  Personally, I can't wait to see the completed photos.  It is going to look great!!
We haven't gotten into serious glider towing and gone to big events.  We have just been doing it for our own enjoyment with our smaller stuff.  It is really quite a lot of fun.
Hide Signatures
(in reply to Nodd)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
