RE: P20 strange happening    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> RE: P20 strange happening
Page: <<   < prev  1 [2]
Login
RE: P20 strange happening - 1/1/2013 1:20 PM
Moonlight24
Score: 100
Last Login: 5/12/2013
Status: offline
quote:
ORIGINAL: frema
the old pumps need long feulline
new pumps dont need this
Regards,
Martin.
Martin,
even on the new pump types you can measure the pulsating flow especially near idle. As per direct contact with JetCat it's still advised to install the long fuel line to smooth out this pulsation to be on the safe side.
Cheers,
Ralf
Hide Signatures
(in reply to frema)
       Post #: 26
RE: P20 strange happening - 1/1/2013 1:48 PM
frema
Score: 103
Last Login: 5/22/2013
Status: offline
oh oke , i didnt know that, sorry
i tryed it with very short 30 cm line
and i was amazed that there was no pulsation
Regards,
Martin.
Hide Signatures
(in reply to Moonlight24)
       Post #: 27
RE: P20 strange happening - 1/3/2013 8:27 AM
CrocEnd
Score: 100
Last Login: 5/5/2013
Status: offline
Ralf
Thanks for the idea will try this weekend
Martin
So might be a new pump to come
Thanks guy's
Hide Signatures
(in reply to frema)
       Post #: 28
RE: P20 strange happening - 1/3/2013 11:30 PM
BaldEagel
Score: 118
Status: online
Shouldn't the fuel pump voltage at max be somewhere about 4.5volts not the 3.4volts you are getting?
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to CrocEnd)
       Post #: 29
RE: P20 strange happening - 1/3/2013 11:33 PM
BaldEagel
Score: 118
Status: online
quote:
ORIGINAL: CrocEnd
Pump voltage is showing when flat out at 3.4 volts.
Happy NEW YEAR
Cheer's
PS radio is SEKTRUM 18 channel
Shouldn't the max voltage be 4.5volts, at least thats what I am operating at with my P20.
Mike
Hide Signatures
       Post #: 30
RE: P20 strange happening - 1/4/2013 6:15 AM
CrocEnd
Score: 100
Status: offline
Mike
I Have all the english instruction's and no voltage readings to what it should be,thats why the Q
also no other people have said anything as well as yet
Cheer's Bob
Hide Signatures
(in reply to BaldEagel)
       Post #: 31
RE: P20 strange happening - 1/4/2013 6:20 AM
CrocEnd
Score: 100
Status: offline
Also is voltage thing a way to de rate the turbine
May be
I do NOT want to de rate this little donk
Cheer's Bob
Hide Signatures
       Post #: 32
RE: P20 strange happening - 1/4/2013 8:32 AM
Moonlight24
Score: 100
Status: offline
quote:
ORIGINAL: BaldEagel
Mike
Gents,
don't mix up things. You should be more concerned if the pump voltage would be higher than expected. This would mean that you have an issue on the fuel system like clogged valve, pipe, filter or a bad pump. The reason for this is that the ECU will increase the pump voltoage to reach the demanded rpm.
If the voltage stays lower than expected it means there is no max rpm demand from the ECU. If this happens and your tx settings are still ok, you really should perform the recalibration which I mentioned before. I can't explain why you have to do from time to time but it reactivated a lot of engines with a power / rpm loss issue before.
Cheers,
Ralf
Hide Signatures
       Post #: 33
RE: P20 strange happening - 1/4/2013 10:18 AM
BaldEagel
Score: 118
Status: online
Ralf
Have not mixed anything up, in the GSU you can restrict or increase the max voltage the demand from the turbine is up to that limit as far as I know, all three of my JetCats have never needed recalibrating in the way you mention, others have, but not the JetCats.
Mike
Hide Signatures
       Post #: 34
RE: P20 strange happening - 1/4/2013 11:18 AM
frema
Score: 103
Status: offline
Try your engine mike , i am curios
Hide Signatures
       Post #: 35
RE: P20 strange happening - 1/4/2013 3:44 PM
BaldEagel
Score: 118
Status: online
frema
Have not tried it out yet, perhaps this week-end will see it run, will let you know how it goes, I have thrust details from it prior to sending it to you, so will be interesting to see the improvement.
Mike
Hide Signatures
(in reply to frema)
       Post #: 36
RE: P20 strange happening - 1/5/2013 12:46 PM
CrocEnd
Score: 100
Status: offline
AND I have cal.' after cal., NO diff.,
My ecu is set to max as the instructions say as now I suspect the ECU then.
Moonlight24 we still don't have a max voltage out put at max RPM on the P20X for the pump
Old mate BaldEagel might be right at 4.5 volts
Lets see
Croc
Hide Signatures
       Post #: 37
RE: P20 strange happening - 1/5/2013 3:44 PM
Moonlight24
Score: 100
Status: offline
quote:
ORIGINAL: CrocEnd
Lets see
Croc
That's really strange. Still presuming that your ecu / transmitter calibration is ok and gives 100%
Can you send me a datalog from the last run after calibration and maybe a printout of the settings ? Will have a look and compare with the data of the 2 engines I have.
Cheers,
Ralf
Hide Signatures
       Post #: 38
RE: P20 strange happening - 2/15/2013 9:58 PM
drdoom
Score: 130
Status: offline
Ever get to the bottom of this???
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
       Post #: 39
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
