Help....Warped elevator    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Help....Warped elevator Page: [1]
Login
Help....Warped elevator - 4/2/2012 2:45 AM
flybyme
Score: 100
Last Login: 4/1/2013
Status: offline
How can i fix what seems to be a warped elelvator. The right side is flush, while the left side is off center. Fresh out of the box.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Help....Warped elevator - 4/2/2012 3:19 AM
Redback
Score: 115
Last Login: 5/23/2013
Status: offline
Can't see from the pix what the elevator joiner looks like.
If it's wire and you can get to it should be fairly simple to (carefully) bend it until the two sides are level. Hold one end in a vice and carefully twist the other end round with pliers. Will usually take a couple of goes to get right, little at a time is the way to go.
Terry
Hide Signatures
(in reply to flybyme)
       Post #: 2
RE: Help....Warped elevator - 4/2/2012 3:23 AM
daveopam
Score: 191
Last Login: 5/18/2013
Status: offline
It's not the wire, the right elev half is twisted. Is that a foamy? Or is it built up and covered/painted?
David
_____________________________
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to Redback)
       Post #: 3
RE: Help....Warped elevator - 4/2/2012 3:50 AM
flybyme
Score: 100
Status: offline
it's buit up and covered....is there a quick fix?
Hide Signatures
(in reply to daveopam)
       Post #: 4
RE: Help....Warped elevator - 4/2/2012 7:01 AM
42etus
Score: 126
Status: offline
You could try heating the covering to pull some of the warp out, but judging from the severity of the warp, I don't think it'd work. I don't see a quick fix. If it were my plane, I'd:
1. Return it to where I got it
2. Build a new (straight) elevator from scratch
YMMV and others may have better suggestions
You don''t need a parachute to skydive.
You only need a parachute to skydive again
Hide Signatures
       Post #: 5
RE: Help....Warped elevator - 4/2/2012 2:57 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
I think it looks fixable, but you might need two sets of hands.
have one person hold the elevator and twist it the other way (wearing gloves) while the other person applies a heat gun to the top and bottom
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to 42etus)
       Post #: 6
RE: Help....Warped elevator - 4/2/2012 4:01 PM
j.duncker
Score: 121
Last Login: 5/22/2013
Status: offline
IMHO any twist and heat gun fix will be pretty temporary.
Ask the mf for a new elevator.
OR strip the covering off, seperate the joints pin flat and reglue then recover.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to MinnFlyer)
       Post #: 7
RE: Help....Warped elevator - 4/2/2012 4:03 PM
MinnFlyer
Score: 390
Status: offline
These things are jig-built, so more often than not, the warp was caused by the covering to begin with and re-heating should fix it.
Hide Signatures
(in reply to j.duncker)
       Post #: 8
RE: Help....Warped elevator - 4/2/2012 6:39 PM
flybyme
Score: 100
Status: offline
Then re-heating with four hands should do the trick.......thanks a bunch guys.
Hide Signatures
       Post #: 9
RE: Help....Warped elevator - 4/2/2012 7:17 PM
flybyme
Score: 100
Status: offline
Now this is what I call great Customer Service. I sent notice to Top Flite informing them of the warped elevator. The first response I received from them was that they had verifed my purchase from Tower, and that my replacement tail surfaces were on the way. Yeaaahhhhhhhhhh Baaaaabyyyyyyyy
Hide Signatures
       Post #: 10
RE: Help....Warped elevator - 4/2/2012 11:43 PM
j.duncker
Score: 121
Status: offline
quote:
ORIGINAL: flybyme
RESULT
Hide Signatures
       Post #: 11
RE: Help....Warped elevator - 4/3/2012 12:32 AM
KitBuilder
Score: 131
Status: offline
How are they attached.. CA hinges?
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 12
RE: Help....Warped elevator - 4/4/2012 6:45 PM
flybyme
Score: 100
Status: offline
Yes
Hide Signatures
(in reply to KitBuilder)
       Post #: 13
RE: Help....Warped elevator - 4/5/2012 1:37 AM
KitBuilder
Score: 131
Status: offline
So you'll need to be cutting the originals and making new slots, etc. have you installed CA hinges before? I'm not sure if where there are located now there is some wood backing. They'll have to be reinstalled a bit left or right of the oringnals whch may have no add'l wood for the hinge as backing.
Mike -
Hide Signatures
       Post #: 14
RE: Help....Warped elevator - 4/5/2012 3:58 AM
flybyme
Score: 100
Status: offline
Yep, have installed many before, they weren't glued in yet......the warp was discovered in the dry fitting. Looking for delivery of the new ones tomorrow, I hope.
Hide Signatures
       Post #: 15
RE: Help....Warped elevator - 4/5/2012 4:57 PM
flybyme
Score: 100
Status: offline
Hmmmm, I received my new elevator today, and I got the same result....so I twisted the wire a bit, same result. Next I guess I'll try the four hands heat and twist, and if that doesn't work, the rebuild of the left elevator. I guess. Bummer....but I'll not give up, something has to work.
Hide Signatures
       Post #: 16
RE: Help....Warped elevator - 4/5/2012 7:47 PM
flybyme
Score: 100
Status: offline
Hooooraaaay, worked like a charm, the four hand heat and twist method worked. You guys are great......Thanks
Hide Signatures
       Post #: 17
RE: Help....Warped elevator - 4/5/2012 11:12 PM
daveopam
Score: 191
Status: offline
That's great, just keep an eye on it for the first few flights. Sometimes they will twist back a little. Normally you have to twist them past the straight point so when they bounce back they are straight. So if your trim starts to change in flight, land and check it out.
david
Hide Signatures
       Post #: 18
RE: Help....Warped elevator - 4/6/2012 3:12 PM
MinnFlyer
Score: 390
Status: offline
WadidItellya?
Hide Signatures
       Post #: 19
RE: Help....Warped elevator - 4/6/2012 10:34 PM
daveopam
Score: 191
Status: offline
You da man Minn!
David
Hide Signatures
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.375RCU1
