Glassing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Glassing
Page: [1] 2   next >   >>
Login
Glassing - 4/2/2012 5:30 PM
rcpete347
Score: 100
Last Login: 5/18/2013
Status: offline
HI all, need help in glassing a wing, the first coat, always looks great, but the second coat, always separates 1 hour , after applied. It separates and puddles.
First coat is 3/4oz cloth, with Pacer finishing resin. Second coat is just Pacer finishing resin, applied after sanding the first coat., several days later.It looks like the second coat does not like to bind to the first coat. This is a problem, I have had for years.
Any help would be appreciated.
Rcpete
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rcpete347 -- 4/3/2012 12:43 AM >
_____________________________
Rcpete has all 1/6th scale pilots, BB-F86, F-4,F-14, F-15, F-16,F-18, F-22, Thunderbirds, Aviators, Female Pilots, Mr Bean,Jason Statham, Hot Toys, Tom Cruise, Val Kilmer.
Rcpete has Blue Box Cockpits
Hide Signatures
       Post #: 1
RE: Glassing - 4/2/2012 5:37 PM
Kevin_W
Score: 105
Status: offline
When and how are you adding the second coat?
I always allow the first coat to dry completely, then lightly sand with 220 or 320 grit. Clean all the dust completely then brush on a second coat of resin, and squeegee it off as thinly as possible. Works great with West Systems epoxy, not sure about Zpoxy.
Kevin Whitlow
Texas Jetcat rep
Hide Signatures
(in reply to rcpete347)
       Post #: 2
RE: Glassing - 4/2/2012 5:41 PM
kirkj
Score: 100
Last Login: 5/17/2013
Status: offline
Hello again Pete,
I always apply the first coat using a playing card to scrape the resin and flatten the cloth. press just hard enough to remove most of the resin, but not so hard that the cloth is left dry and does not stick.
i do the second coat the same way with a playing card pressing pretty hard with the edge of the card. this removes all the resin, but pushes the second coat down into the glass poores.
brush coat of K-36 sanded 99% off - BVM pinhole filler, followed bt a spray K-36 and its smooth as silk.
Hide Signatures
       Post #: 3
Ruizmilton
Score: 100
Last Login: 5/19/2013
Status: offline
Allow 6 to 8 hrs for the first coat to dry hard, if it's gummy you will have this problem, sanding before it has hardened is not a good idea...
Hide Signatures
(in reply to Kevin_W)
       Post #: 4
RE: Glassing - 4/2/2012 5:42 PM
FalconWings
Score: 121
Status: offline
Why the second coat? Once you've saturated the glass on the first coat adding a secind coat only adds weight.
I'd fill the voids with K36 (or similar) , which sands so much easier than Epoxy.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 5
speedracerntrixie
Score: 189
Status: offline
You may want to change over to laminating resin. Laminating resin is intended for multiple applications. West Systems is a good way to go and redily available but there are many other good products out there.
Hide Signatures
       Post #: 6
RE: Glassing - 4/2/2012 5:49 PM
YellowAircraft
Score: 181
Status: offline
Pete,
Do you thin your resin at all? I used Z-Poxy (until I discovered West System) thinned down 50/50 with denatured alcohol and brushed on. It takes half the time of the playing card/squeegee method, and in direct sunlight dries incredibly fast. The second coat is also thinned to the same ratio and allowed to thoroughly dry. It sands perfect.
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 7
RE: Glassing - 4/2/2012 5:58 PM
RCISFUN
Score: 105
Last Login: 5/14/2013
Status: offline
quote:
ORIGINAL: FalconWings
Agreed, one coat for me, then polyester primer, sanding epoxy sucks!
http://www.eastwood.com/featherfill-g2-gray-quart.html
This stuff sands like butter
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
(in reply to FalconWings)
       Post #: 8
RE: Glassing - 4/2/2012 6:41 PM
rcpete347
Score: 100
Status: offline
HI Guys, thanks for the info, will give West systems a try, since I use it for every thing else.
Thanks Rcpete
Hide Signatures
(in reply to RCISFUN)
       Post #: 9
RE: Glassing - 4/2/2012 6:45 PM
Meesh
Score: 100
Status: offline
Rich
Don't hold back! Tell us how you really feel about sanding Epoxy!
Bob
If it''s worth doing, it''s worth doing it right.
AMA 779352, JPO 1965, IMAA 40337
Hide Signatures
       Post #: 10
RE: Glassing - 4/2/2012 8:42 PM
aquaskiman
Score: 100
Status: offline
Only one coat then prime with k2 and sand. easy
George
Hide Signatures
       Post #: 11
RE: Glassing - 4/2/2012 8:50 PM
RCISFUN
Score: 105
Status: offline
quote:
ORIGINAL: Meesh
Rich
Bob
No problem Bob...
I learned to hate sanding at a young age, my first job out of High School was painting these bad boys
After a couple of years of doing that I decided to go to college for my BS degree
Click for fullsize
Rich
Hide Signatures
(in reply to Meesh)
       Post #: 12
RE: Glassing - 4/2/2012 9:29 PM
YellowAircraft
Score: 181
Status: offline
Hi,
Thinned West System sands easily to powder. I've never looked back....
Hide Signatures
       Post #: 13
RE: Glassing - 4/2/2012 10:05 PM
k_sonn
Score: 123
Status: offline
I have always used the West System laminating epoxy and have not seen what you are experiencing.  I put on the first coat and squeegy off the excess resin.  For the second coat, I mix in micro ballons until the resin is a slightly runny paste.  Apply this and squeegy off the excess.  The micro ballons fill in the weave of the cloth with very little weight gain.  Wet sand with 400 and it's ready for primer and paint.  Never had to use pin hole filler since I've started adding micro ballons to the second coat of resin.
Kirk
Schubeler USA Demo Team
"Schubeler - The Future Of Electric Jets"
Hide Signatures
(in reply to YellowAircraft)
       Post #: 14
RE: Glassing - 4/2/2012 10:07 PM
dbsonic
Score: 100
Status: offline
k_sonn, I was just going to post the same thing about adding micro balloons to primer. I recently starting doing this and its a nice way to thicken up the primer for filling where you need a little extra buildup. Its a great idea and wish I knew that trick years ago.
Hide Signatures
(in reply to k_sonn)
       Post #: 15
RE: Glassing - 4/2/2012 11:12 PM
j.duncker
Score: 121
Status: online
Pete your problem is something called amine blush. See clicky for a good is little dated expo on the subject.
I had this also and solved it by going to a laminating resin for the first coat and finishing resin for the final coat. I had success with the early West System varients 206 and 207 without sanding between coats just rolling them on with foam rollers then wiping down with acetone followed by water but you might want to try a test piece first. At that time I was going for a clear finish on glider wings.
My F 104 was the last thing I glassed and that was with West System but would have been 6 years back now so formulations may have changed.
West advice on the topic here. clicky
Basically if you can wet sand without getting a 'water bead' then you should be good to go.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
(in reply to dbsonic)
       Post #: 16
RE: Glassing - 4/3/2012 12:34 AM
rcpete347
Score: 100
Status: offline
Here is a great shot of the epoxy separating
Click on pictures for detail
This picture shows the fiberglass weave after squeegeeing the first filler coat (MAS epoxy). This is how it should look but it doesn't last long because it was put on top of barely cured substrate only 3 hours later.
The hardener is a blend of 20% fast and 80% slow
  This is the same patch of surface as in the picture above only few minutes later. I am puzzled by this myself but it seems like the uncured epoxy wants to repel the new coat in the same way a new car polish beads up water. Good ol' surface tension at work.
This 'beading' actually became an advantage because the next filler coat really filled the deep valleys between the high beads and it saved me from applying the last coat. It took 3 coats in total to cover the deck.
Thanks ,great clicky, on the epoxy, J. duncker
Rcpete
Hide Signatures
(in reply to j.duncker)
       Post #: 17
RE: Glassing - 4/3/2012 1:13 AM
Airplanes400
Score: 202
Status: offline
I only use one coat of resin while applying the glass cloth. After that, I just spray on a few coats of primer, sand it smooth, then paint. I feel that a second coat of resin dries too hard to sand, and ends up giving you the problems you have.
We in the Federal Government have no sense of humor that we are aware of.
Hide Signatures
       Post #: 18
RE: Glassing - 4/3/2012 1:23 AM
DAN AVILLA
Score: 100
Status: offline
I have always used the 2 coat process with west system. It is what you want to do if the plan is to flite metal or presto because you are cutting the material on the surface and want a hard shell . Dan
Hide Signatures
(in reply to Airplanes400)
       Post #: 19
RE: Glassing - 4/3/2012 3:02 AM
SPLIT S
Score: 109
Last Login: 5/11/2013
Status: offline
Learned a lot from that link on epoxy blushing. For what it is worth, I wipe down the raw epoxy surface with alcohol before I start to sand. Takes away most of the tacky feel that destroys sandpaper before you even get started when using laminating resins that are air dried.
Dan
Hi Dad, Doing anything? Want to go to the field?
Hide Signatures
(in reply to DAN AVILLA)
       Post #: 20
RE: Glassing - 4/3/2012 9:53 AM
handyman 220
Score: 100
Status: offline
I didn't know alcohol worked, I have used MEK to wipe down before sanding with good results. I'll have to try alcohol, much more user friendly.
Do it right the first time, or not at all!
Hide Signatures
(in reply to SPLIT S)
       Post #: 21
RE: Glassing - 4/3/2012 1:00 PM
proline8000
Score: 105
Status: offline
Pete,
I have seen this before. Epoxy and polyester resin have styrene (wax) added to it for curing. This floats to the surface to isolate the air form the chemical reaction so you get a 100% cure. If the epoxy is not isolated the epoxy will be tacky to the touch. This is good if you are doing multiple lay-ups because you will get a chemical bond instead of a mechanical one. But you still need epoxy with wax in it for the final lay-up. The epoxy will not stick to the wax and must be sanded off before you can add a second layer. If you don’t sand off the wax it will be like the wax on your car, the water just beads up.
Hide Signatures
(in reply to handyman 220)
       Post #: 22
RE: Glassing - 4/3/2012 1:21 PM
invertmast
Score: 193
Status: online
man, you guys are doing it the old-fashioned elbow-grease way... I quit doing that 2 years ago!
Go get some 100% pure polyester DRESS liner fabric from your local fabric supply store.
Fiberglass your part using whatever glass cloth, epoxy resin and your preferred method of application.
once your done (only squeegee off the excess Puddles of resin, not the entire surface. A little extra resin can be left on the surface)
Lay down the polyester dress liner on the part and smooth it down using a squeegee (if your cloth has a crease in it, throw it in the dryer for a minute or 2). then LEAVE it on till the epoxy has cured.
The next day, pull off the dress liner and throw it away. Your left with a surface ready for paint, no sanding required!
Also, if you have an area of fiberglass that peels away from the surface, take a plastic baggy, put your finger in it, put a drop of thin CA on the lifted fiberglass, then rub the CA into the fiberglass with your plastic wrapped finger (keep it moving, you'll feel it warm up, at that point you can stop).
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
(in reply to proline8000)
       Post #: 23
RE: Glassing - 4/3/2012 2:03 PM
BullardRM
Score: 100
Status: offline
If you use a roll of toilet paper and roll it over the first coat of resin/epoxy it will soak up the excess bonding agent while pressing the cloth to the wood. With each pass the wet paper has to be disposed. No bubbles or high spots in the cloth and no excess fluid left in the cloth. Second coat of resin/epoxy should be cut to make it flow. Use a guid coat of laquor to sand the high spots out.
Hide Signatures
(in reply to invertmast)
       Post #: 24
RE: Glassing - 4/3/2012 2:30 PM
Airplanes400
Score: 202
Status: offline
quote:
ORIGINAL: handyman 220
Yes, alcohol works very well. Especially when you drink it ... makes the time go by faster.
Time flys when you're having rum!
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
