YA Skyhawk and Wren 44 Gold Perfect together    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> YA Skyhawk and Wren 44 Gold Perfect together
Page: [1] 2 3   next >   >>
Login
YA Skyhawk and Wren 44 Gold Perfect together - 4/2/2012 9:14 PM
Mark 5
Score: 100
Last Login: 6/10/2013
Status: offline
Here are some pictures of my Skyhawk.
Will be flying it next week.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/2/2012 9:31 PM
YellowAircraft
Score: 196
Last Login: 6/18/2013
Status: offline
Nice!
How much fuel are you carrying? No bellmouth on the pipe?
_____________________________
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
(in reply to Mark 5)
       Post #: 2
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/2/2012 10:49 PM
hooker53
Score: 100
Last Login: 6/20/2013
Status: offline
Very nice job and clean install. Be sure to get some vids of your flights.
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
(in reply to YellowAircraft)
       Post #: 3
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/3/2012 2:39 AM
jetspud
Score: 100
Status: offline
Looks like a good home for my 44 gold. Lets know the details when fly it
Hide Signatures
(in reply to hooker53)
       Post #: 4
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/3/2012 3:31 AM
Mark 5
Score: 100
Status: offline
Thanks for the compliments, I will try to get some video next week. Shaun can you tell me the what C.G. you used. The instruction says it should be 12 1/2" forward of the trailing edge at the wing root with fuel tanks full. What is the C.G. with empty tanks? I have a total of 40 ounces of fuel, two 10 ounnce tanks in front of the turbine and two 10 ounce tanks on either side of the turbine. The pipe was made by my friend Tino from Baltimore. It is very light and the wren 44 gold runs very cool with it.
Hide Signatures
       Post #: 5
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/3/2012 5:01 AM
yeahbaby
Score: 135
Status: offline
dude!!! I'm psyched to see someone else out there with the YA A4 and wren 44 combo. I've got one on the shelf that just needs a motor.
can't wait to see the result
"Audentes fortuna iuvat"
Hide Signatures
       Post #: 6
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/3/2012 4:28 PM
JeffH
Score: 114
Status: offline
Your left upper tank looks to be a Sullivan Flex tank(clearish vs. your right tank that is normal white nylon). They are rated for Glow fuel only. I know that gasoline will destroy them, I am not sure about kerosene.
Hide Signatures
(in reply to yeahbaby)
       Post #: 7
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/3/2012 6:35 PM
jetspud
Score: 100
Status: offline
Buck bring that A-4 to mississippi we can put my 44 in it and fly it all weekend.
David
Hide Signatures
(in reply to JeffH)
       Post #: 8
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/3/2012 6:48 PM
yeahbaby
Score: 135
Status: offline
nice!!!! I just may do that amigo.
I can't wait for Mark5 to report back on how he the performance of the bird.
Hide Signatures
(in reply to jetspud)
       Post #: 9
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/5/2012 3:00 PM
Mark 5
Score: 100
Status: offline
Hello JeffH, you are correct, the sullivan flex tank is rated for glow fuel only. Good eyes. You saved me a lot of headaches. Thank you! Mark.
Hide Signatures
(in reply to JeffH)
       Post #: 10
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/5/2012 3:37 PM
YellowAircraft
Score: 196
Status: offline
Hi,
Use the 12.5" location. That will work fine if your tanks stay in the location you have them.
Hide Signatures
       Post #: 11
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/6/2012 9:55 PM
Mark 5
Score: 100
Status: offline
Thank you Shaun. Is that measurement with the tanks full or empty.
Hide Signatures
       Post #: 12
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/7/2012 4:42 AM
YellowAircraft
Score: 196
Status: offline
Hi,
Your tanks appear to be centered on or about the CG, so it shouldn't matter. Measure the CG location and mark it, then verify that the tank is centered on it, then measure it empty. Gear DOWN.
Hide Signatures
       Post #: 13
RE: YA Skyhawk and Wren 44 Gold Perfect together - 4/7/2012 6:06 AM
Mark 5
Score: 100
Status: offline
Thank you Shaun. I love this little jet. It's small enough to fit in my SUV with the wings on and large enough to see in flight. I hope the Wren44 has enough power to lift it off my grass field.
Hide Signatures
       Post #: 14
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 7:12 AM
Mark 5
Score: 100
Status: offline
I finally got the chance to put two flights on the Skyhawk. The take off roll is similar to the ducted fan Skyhawk,but once in the air the wren 44 has better vertical, however the top speed is also similar to the ducted fan Skyhawk. The Skyhawk is also very stable and easy to fly which surprised me. I do not think that my Skyhawk has enough power to take off of grass which was my main concern.
Hide Signatures
       Post #: 15
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 12:14 PM
Dr Honda
Score: 100
Status: offline
What's the ready to fly weight? I'm just finishing up a T-45... and I'm planing on flying it from grass.
One thing... I know they are a little pricey... but if you change to the Wren pipe... they claim a 5% thrust increase.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 16
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 2:52 PM
Mark 5
Score: 100
Status: offline
Hi Tony, the Skyhawk weighs 12 and 3/4 LBS without fuel. I dont know how guys are getting them under 11 LBS. This combo flies very scale like at a little above 1/2 throttle and the light wing loding seems to help when landing. Mark
Hide Signatures
(in reply to Dr Honda)
       Post #: 17
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 3:12 PM
Bob_B
Score: 100
Status: offline
Mark superb effort on the skyhawk.
Cincinnati Jet Club, Team Futaba, Wren Turbines USA
Hide Signatures
       Post #: 18
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 7:04 PM
Gordon W
Score: 105
Last Login: 6/19/2013
Status: online
Mark, how did you choose the distance between the 44 nozzle and the tailpipe? I have a couple of Wren tailpipes in use with 44 Golds, and have set them at Wren's specified distance. However, someone gave me a tailpipe which is similar to yours, except the entrance is flared ever so slightly. I'd like to use the pipe in a model to save the expense of buying another Wren pipe, but can't decide how far to set it from the 44 nozzle.
Gordon
Hide Signatures
(in reply to Bob_B)
       Post #: 19
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 9:14 PM
Vettster
Score: 105
Status: offline
Very Nice set up Mark.. It even pre heats the fuel for you Good luck with the Maiden.
If anyone is selling a Wren 44 Gold.. I am interested
Club NO MAX! No boarder..No Limits..No POLITICS! NO "MAX"
Hide Signatures
(in reply to Gordon W)
       Post #: 20
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 11:01 PM
yeahbaby
Score: 135
Status: offline
Nice job with your 44 amigo. I look forward to adding this motor to my stable
Hide Signatures
(in reply to Vettster)
       Post #: 21
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/16/2012 11:25 PM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: Mark 5
Thanks for the info. I was worried about the 44 gold, and general grass flying. So... with fuel... you are at about 14 Lbs I guess. I'm projecting my T-45 at only being at 8~9 Lbs with fuel. I also left the retracts out, and put on 3" tires. (lol) I'l be the only guy with a "Tundra" T-45.
quote:
ORIGINAL: Vettster
I had my 44 for sale for a few months. People were only offering $500... so I pulled it. They don't come up too often on the used, but hang in there... you'll find one.
Tony
Hide Signatures
       Post #: 22
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/17/2012 2:21 AM
Vettster
Score: 105
Status: offline
$500 bucks?? Must have been a bunch of EDF'ers thinking they could play with the big boys for the same price..lol
Im not in hurry for one.. Winter will soon be here
Hide Signatures
       Post #: 23
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/17/2012 3:11 AM
Mark 5
Score: 100
Status: offline
Gordon, my Wren 44 gold is about 3/4 of an inch from the pipe. Tony if your T-45 is only 8 LBS ,it will be a rocket with the Wren 44.
Hide Signatures
       Post #: 24
RE: YA Skyhawk and Wren 44 Gold Perfect together - 9/17/2012 3:22 AM
Dr Honda
Score: 100
Status: offline
quote:
ORIGINAL: Vettster
That's what I was thinking too.
I Picked up a boat project for the fam... and I was going to sell my 44 to fund the rebuild. Plus... it was sitting on the shelf for over a year. So I posted it. But, after getting the low offers, and selling a few other things... I decided to finish my T-45 project.
At this point... I'm glad I kept it... but I am shocked that it didn't sell. (FYI, it was posted for $1500 with new bearings, and a wren pipe. AND, it only had 2 hrs on the fuel pump, and temp prob)
quote:
ORIGINAL: Mark 5
I'm hopping to have it done tomorrow. So... I'll get a weight on it. I'm thinking about turning down the thrust a little. I don't need +1:1 on a little jet. (lol) I think Ron told me that 175K rpm would be 7#.
I guess I took it a little off subject. Sorry. I'll shut-up now.
Tony
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.781RCU1
