Aerofly 5 choppiness    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Aerofly 5 choppiness
Page: [1]
Login
Aerofly 5 choppiness - 4/5/2012 3:44 AM
can773
Score: 105
Last Login: 5/26/2013
Status: offline
Have my AF5 up and running with the latest updates, (have tried both latest release, and beta release). In either case, the sim starts off fine getting 40-50 fps on simply sceneries (Sky Nights for instance), then after some time it begins to cycle from 40-50 fps, down to 20 fps and will not stop until I stop the sim for a while and restart, and the cycle repeats. Any suggestions how to prevent this would be appreciated. All graphics settings are turned right down, sim is running in window mode.
Chad
Computer is a:
Model Name: MacBook Pro
Model Identifier: MacBookPro5,5
Processor Name: Intel Core 2 Duo
Processor Speed: 2.26 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 8 GB
Bus Speed: 1.07 GHz
NVIDIA GeForce 9400M:
Chipset Model: NVIDIA GeForce 9400M
Type: GPU
Bus: PCI
VRAM (Total): 256 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0863
Revision ID: 0x00b1
ROM Revision: 3427
Displays:
Display Connector:
Status: No Display Connected
DELL U2312HM:
Resolution: 1920 x 1080 @ 60 Hz
Pixel Depth: 32-Bit Color (ARGB8888)
Display Serial Number: T9MJ31B4C6HL
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
TM Log is,
tmmodule: (5 modules) (tmatmosphere,1) (tmsystimer,1) (tmrandom,2) (tmfile,4) (tmopenal,20)
tmmodule: init modules=(tmrandom=(seed=708617884) ok) done
macosx-cocoa: Program version 5.7.1.9
macosx-cocoa: Library Version 5.7, Copyright (C) 1998-2011, IPACS
macosx-cocoa: http://www.ipacs.de
macosx-cocoa: cpu speed = 2260 Mhz type=78ea4fbc
macosx-cocoa: mac os version=1068 (10.6.8) (logical mem=2047MB) (physical mem=2047MB)
tmfile: loading tmfile 'config/main.mcf' = (4777 bytes) done
tmopenal: init= (default=Built-in Output) (0:Built-in Output) (version=1.1) (1.1) ok
macosx-cocoa: gl: vendor=NVIDIA Corporation, renderer=NVIDIA GeForce 9400M OpenGL Engine, version=2.1 NVIDIA-1.6.36
macosx-cocoa: (version=2.1) (compatibility profile)
macosx-cocoa: gl: (viewport=8192x8192) (texturesize=8192)
macosx-cocoa: gl: extensions=GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4 GL_EXT_transform_feedback GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_APPLE_aux_depth_stencil GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_ARB_color_buffer_float GL_ARB_half_float_vertex GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_ARB_framebuffer_object GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_depth_bounds_test GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_ARB_half_float_pixel GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_point_sprite GL_NV_blend_square GL_NV_fog_distance GL_NV_depth_clamp GL_NV_multisample_filter_hint GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_conditional_render GL_ATI_texture_mirror_once GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_EXT_texture_array GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays GL_ARB_depth_buffer_float GL_EXT_packed_float GL_EXT_texture_shared_exponent
macosx-cocoa: gl: extensions=(anisotropic filter of 16.00) (gpu shader 4)
sim:
sim: FUNC RenderOpen BEGIN
sim:
tmxgltext: loading font (0) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (1) 'texture/fontbig.tff'=(512x256) (h=26) (nc=256) ok
tmxgltext: loading font (2) 'texture/console.tff'=(256x128) (h=15) (nc=256) ok
tmxgltext: loading font (3) 'texture/font.tff'=(2048x2048) (h=17) (nc=65535) ok
tminput: searching for input devices...(3)
macosx-inputdeviceusb: searching usb interface (0,0)=(radiointerface) ce3bce7e
tminput: 1 devices found= (USB Interface #1) (ce3bce7e)
tmmusic: (11 mp3 files found) (playlist = 0 songs)off
sim: loading scenery 'scenery//us-lincoln-sky-knights'...
tmscene: (12x12) (19x8) (r=5000.00) (sp=0.01 -0.00 -18.40) (vp=0.01 -0.00 1.60) (ambient=0.08 0.11 0.08) (diffuse=0.95 1.02 0.98) (sphereambient=0.25 0.20 0.20)
tmxgltext: 162 textures using 72 MB
tmcollision: init = (tris=37843, 7871344 bytes) (-3418.63 -3427.69 -44.78 - 3928.93 3919.87 63.55) (time=0.17s)
tmcollision: (214 input objects) (1 base objects) (1 instance objects) (0 dynamic objects) (time=0.00s)
tmfile: loading tmfile 'config/scenery-us-lincoln-sky-knights.tmc' = (903 bytes) done
tmcollision: creating static collisionobjects quadtree = (objects=1) (-3418.64 -3427.70 -44.79) - (3928.94 3919.88 63.56)
tmscene: scene bounding box = (-4529.83 -4648.07 12.66) (4701.53 4634.13 665.75)
tmscene: max objects per cell = 76
tmscene: shadowmap = 2048x1024 sp=2 (20.00 80.00 0.00 0.00 0.00 0.00 0.00)
sim: done loading scenery (t=5.59s objects=333)
sim:
sim: windfieldinfo 0: resolution=3.00 min=(-750.00 -750.00 0.00) max=(750.00 750.00 100.00)
tmwindfield: Setup Windfield with origin = (-750.0, -750.0, 0.0), size_xy = (1500.0m, 1500.0m), Grid relation (x:y): 1:1, MipMapLevels: 9, Resolution: (2.9m, 2.9m)
tmwindfield: Windfield Map Load from file 'scenery/us-lincoln-sky-knights/windfield0.twd' successful
tmscene: statistics = (objects=335) (transparent=0) (graphics=2) (graphicsbb=0) (dynamic=0) (decals=0) (water=0) (tris=0) (shadow faces=0) (btrees=0) (trees=0)
tmfile: loading tmfile 'config/player0.mcf' = (2359 bytes) done
sim: loading model 'f16'...
sim: path='aircraft/f16' geometry='f16' physics='f16' paintscheme=' ...
tmmodelmanager: assigning controller to receiver
tmmodelmanager: model input channel Throttle Aileron Elevator Rudder Flaps Wheel-Brake Retractable-Gear Smoke Cockpit Airbrake
sim: done loading model (t=0.96s, n=96, id=8)
sim:
tmfile: loading tmfile 'config/player1.mcf' = (2294 bytes) done
tmfile: loading tmfile 'menu/settings.mcf' = (97683 bytes) done
tmmodelmanager: (0:airfoil) (1:airfoil) (2:airfoil) (3:airfoil) (4:airfoil) (5:airfoil)
tmmodelmanager: (6:airfoil) (7:airfoil) (8:airfoil) (9:airfoil) (10:airfoil) (11:airfoil) (12:airfoil) loading tmfile 'config/rc0-ce3bce7e.tmc' = (73461 bytes) done
sim_update: connecting to server www.aerofly.com= FAIL(-13,43)
tmxgltext: 483 textures using 135 MB
sim:
sim: FUNC RenderOpen END = 15.407233 sec
sim:
macosx-cocoa: compute thread started
tm: calibrating radio deviations= 0 3 6 9 -16 25 -36 88
license: license: tml file 'af5-c010.tml' = C010 0000 0507 0109 'aerofly5' 'C010-CE3BCE7E.lic' (activated=1)
sim: loading model 'visa'...
sim: path='aircraft/visa' geometry='visa' physics='visa' paintscheme=' ...
tmmodelmanager: model input channel Throttle Aileron Elevator Rudder Airbrake
sim: done loading model (t=0.81s, n=63, id=8)
sim:
sim: path='aircraft/visa' geometry='visa' physics='visa__000' paintscheme=' ...
sim: done loading model (t=0.77s, n=63, id=8)
sim:
sim: loading model 'yak55'...
sim: path='aircraft/yak55' geometry='yak55' physics='yak55__competition' paintscheme=' ...
tmmodelmanager: model input channel Throttle Aileron Elevator Rudder Smoke
sim: done loading model (t=1.27s, n=63, id=8)
sim:
sim: loading model 'su29'...
sim: path='aircraft/su29' geometry='su29' physics='su29' paintscheme=' ...
sim: done loading model (t=1.00s, n=63, id=8)
sim:
sim: loading model 'edge540t'...
sim: path='aircraft/edge540t' geometry='edge540t' physics='edge540t' paintscheme=' ...
sim: done loading model (t=1.11s, n=67, id=8)
sim:
tmsysthread: ERROR: failed to terminate thread ('renderthread', 0x10425dbb0)
_____________________________
Chad Northeast
Hide Signatures
       Post #: 1
RE: Aerofly 5 choppiness - 4/7/2012 6:41 AM
rajul
Score: 105
Last Login: 5/25/2013
Status: offline
Hi Chad, does the fps drop continuously when you're not doing anything (i.e. not flying at all), or while you're flying?
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
Hide Signatures
(in reply to can773)
       Post #: 2
RE: Aerofly 5 choppiness - 4/8/2012 7:29 PM
can773
Score: 105
Status: offline
Hi Mike,
Usually its good for the first 5-10 minutes after I start up the sim, then it goes into this cycle of 30-40 to 15-20, and is very noticeable. Once it does this it never stops regardless of what your are doing, either flying or just letting the plane sit there on the runway.
I have no other programs running, but maybe something is in the background that could cause this?
Chad Northeast
Hide Signatures
(in reply to rajul)
       Post #: 3
RE: Aerofly 5 choppiness - 4/9/2012 12:28 AM
rajul
Score: 105
Status: offline
Hi Chad, by "cycling", do you mean that the fps goes up and down? If you just let the model sit on the runway, what is the time duration between each cycle? Yes, I would check for any applications running in the background and disable them, as a first step.
Mike Marks
RCU Moderator
Hide Signatures
       Post #: 4
RE: Aerofly 5 choppiness - 4/9/2012 2:48 AM
can773
Score: 105
Status: offline
Hi Mike,
Once it starts its every few seconds, 20fps to 40fps to 20 to 40 and on and on...really annoying!
There does not seem to be anything running that should be working the computer, here is a list, (firefox and activity monitor are obviously not running while the sim is on)
373 prl_naptd 0.0 3 6.1 MB Intel (64 bit)
237 MagicPrefs 0.2 7 15.7 MB Intel (64 bit)
699 mdworker 0.0 3 7.9 MB Intel (64 bit)
220 UserEventAgent 0.0 3 6.6 MB Intel (64 bit)
37 loginwindow 0.0 2 8.4 MB Intel (64 bit)
700 Firefox 0.0 23 196.6 MB Intel (64 bit)
706 Activity Monitor 1.4 2 24.1 MB Intel (64 bit)
227 AirPort Base Station Agent 0.0 3 5.6 MB Intel (64 bit)
712 aerofly5 42.9 12 526.0 MB Intel (64 bit)
228 BBLaunchAgent.app 0.3 6 2.9 MB Intel
205 Dock 0.0 3 14.9 MB Intel (64 bit)
211 pboard 0.0 1 840 KB Intel (64 bit)
235 WD Quick View 0.0 7 17.4 MB Intel
206 SystemUIServer 1.2 4 18.5 MB Intel (64 bit)
212 fontd 0.0 2 3.5 MB Intel (64 bit)
260 iStatLocal 0.0 3 4.6 MB Intel (64 bit)
201 launchd 0.0 2 936 KB Intel (64 bit)
207 Finder 0.0 6 16.8 MB Intel (64 bit)
31 usbmuxd 0.0 3 2.1 MB Intel (64 bit)
169 coreaudiod 0.0 3 1.9 MB Intel (64 bit)
164 WindowServer 8.4 4 68.9 MB Intel (64 bit)
19 mDNSResponder 0.0 3 1.9 MB Intel (64 bit)
16 distnoted 0.0 2 1.2 MB Intel (64 bit)
0 kernel_task 2.5 66 361.0 MB Intel
71 nmbd 0.0 1 1.4 MB Intel (64 bit)
12 notifyd 0.0 2 564 KB Intel (64 bit)
36 mds 0.0 5 26.1 MB Intel (64 bit)
54 iStatLocalDaemon 0.8 3 2.1 MB Intel
1 launchd 0.0 3 1.2 MB Intel (64 bit)
13 syslogd 0.0 4 680 KB Intel (64 bit)
43 dynamic_pager 0.0 1 740 KB Intel (64 bit)
49 autofsd 0.0 2 900 KB Intel (64 bit)
185 prl_diservice 0.0 16 16.8 MB Intel (64 bit)
173 prl_naptd 0.0 4 7.1 MB Intel (64 bit)
55 coreservicesd 0.0 4 14.1 MB Intel (64 bit)
14 configd 0.0 6 3.0 MB Intel (64 bit)
26 ntpd 0.0 1 1.1 MB Intel (64 bit)
38 KernelEventAgent 0.0 3 960 KB Intel (64 bit)
15 diskarbitrationd 0.0 2 1.4 MB Intel (64 bit)
27 cupsd 0.0 3 6.2 MB Intel (64 bit)
708 activitymonitord 0.6 1 1.2 MB Intel (64 bit)
10 kextd 0.0 2 3.0 MB Intel (64 bit)
28 krb5kdc 0.0 2 1.8 MB Intel (64 bit)
40 hidd 0.0 3 1.6 MB Intel (64 bit)
188 cvmsServ 0.0 1 832 KB Intel (64 bit)
52 BBDaemon 0.0 4 1.0 MB Intel
11 DirectoryService 0.0 5 4.6 MB Intel (64 bit)
17 blued 0.0 3 4.9 MB Intel (64 bit)
23 securityd 0.0 2 2.2 MB Intel (64 bit)
41 fseventsd 0.0 13 1.9 MB Intel (64 bit)
53 sh 0.0 1 812 KB Intel (64 bit)
Chad Northeast
Hide Signatures
(in reply to rajul)
       Post #: 5
RE: Aerofly 5 choppiness - 4/9/2012 2:54 PM
nonstoprc
Score: 110
Status: offline
Hi Chad,
I did not notice fps rate dropping with my setup (Aerofly usb game commander, and aerofly 5.7.1.1). In full-screen mode, the fps ranges from 30 to 60 and the simulation is smooth.
5.7.1.1 is the version I online upgraded to. The original CD is for mac, and I am running mac os X 10.6.8 on a MBP with the following
Model Identifier: MacBookPro5,4
Processor Speed: 2.53 GHz
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Boot ROM Version: MBP53.00AC.B03
SMC Version (system): 1.49f2
Sudden Motion Sensor:
State: Enabled
Type: GPU
Bus: PCI
You may adjust the "graphics quality" to "low" under Aerofly simulation dialog window to see if helps. There are other parameters to adjust, such as texture, shadow, anti-aliasing etc.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
       Post #: 6
RE: Aerofly 5 choppiness - 4/9/2012 3:25 PM
rajul
Score: 105
Status: offline
nonstop, thanks for sharing your experience with the 9400M. What graphics quality are you running in full screen mode?
The 9400M does not have a dedicated memory and shares the main memory. Its performance will depend on the main memory speed e.g. DDR3 will perform much faster than DDR2. In any case, the 9400M is not a very powerful graphics processor with only 256MB of vram, and it is not recommended for AF5 http://www.aerofly.com/requirements_en.html You could try to reduce the quality settings, but this might not help. You should also check if VSYNC is enabled and disable it.
< Message edited by rajul -- 4/13/2012 12:50 PM >
Mike Marks
RCU Moderator
Hide Signatures
(in reply to nonstoprc)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
