Eletronic ignition wire thru firewall    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Eletronic ignition wire thru firewall
Page: [1]
Login
Eletronic ignition wire thru firewall - 4/6/2012 2:19 AM
comanche260c
Score: 107
Last Login: 3/17/2013
Status: offline
I purchased a electronic ignition from RCEXL for my zenoha g38 to relpace my magneto. My question is I was told byRCEXL that I have to cut  a large hole in belly behind fire wall to insert the sparkplug cap thru so I can get it to the engine.I dont want to make a large hole like that.Is there a way I can take the cap off and insert the wire thru the fire wall?? Than insert the cap?  Are all electronic ignition wires like this,To bad i couldnt unscrew the wire from the spark plug cap and run it thru the fire wall than  hook  cap   back on allowing hole to be small thru  firewall
Hide Signatures
       Post #: 1
RE: Eletronic ignition wire thru firewall - 4/6/2012 2:46 AM
w8ye
Score: 318
Last Login: 5/24/2013
Status: offline
The braid on the spark plug wire will ruin in no time if it touches shomething hard while the engine is running.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to comanche260c)
       Post #: 2
RE: Eletronic ignition wire thru firewall - 4/6/2012 4:13 AM
dirtybird
Score: 173
Status: offline
Do you have space to mount the ignition in front of the firewall? If you do you will just need a small hole for wires to go to the battery.
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: Eletronic ignition wire thru firewall - 4/6/2012 4:30 AM  1 votes
tkg
Score: 657
Status: offline
Make a big hole, leave the plug wire intact. Make a plug with a notch in for the wire add a grommet and glue it in.
TKG
Too much power is just about right.
Hide Signatures
(in reply to dirtybird)
       Post #: 4
RE: Eletronic ignition wire thru firewall - 4/6/2012 6:01 AM
Octopus RC
Score: 100
Last Login: 4/18/2013
Status: offline
It`s a good method to use RCexl " High-voltage wire repair kits ".
1.Drill a 6-7mm diameter hole on your firewall ,
2.cut your high-voltage wire
3.Use " High-voltage wire repair kits " to repair your high-voltage wire .
We Offer XYZ / B&D / TGY / TMM Online Support and offer factory price replacement parts .Wherever and whenever you brought your engine from . Please check www.octopusrc.com . Big Save !!!!
Hide Signatures
       Post #: 5
RE: Eletronic ignition wire thru firewall - 4/6/2012 10:21 AM
comanche260c
Score: 107
Status: offline
no I dont want  that thing hanging on fire wall  it willnot look good
Hide Signatures
(in reply to Octopus RC)
       Post #: 6
RE: Eletronic ignition wire thru firewall - 4/6/2012 1:39 PM
acdii
Score: 155
Last Login: 5/20/2013
Status: offline
 Here is what I did with mine.
http://www.facebook.com/pages/B-17e-Desert-Rat-Restoration-Project/218159428244374
Hide Signatures
       Post #: 7
RE: Eletronic ignition wire thru firewall - 4/6/2012 2:16 PM
darrolair
Score: 100
Status: offline
I don't care who you are, that's funny there!!!!
Hide Signatures
(in reply to acdii)
       Post #: 8
RE: Eletronic ignition wire thru firewall - 4/6/2012 2:50 PM
Zeeb
Score: 111
Last Login: 5/22/2013
Status: offline
As noted, just use a rubber grommet. Cut the hole just big enough for the cap and you'll need a little notch for the ridge in the cap, put in the grommet and you're in business....
Zeeb
Hide Signatures
(in reply to darrolair)
       Post #: 9
RE: Eletronic ignition wire thru firewall - 4/6/2012 3:39 PM
Truckracer
Score: 304
Status: online
I just line the hole with split foam tubing or something similar. Protects the cable from damage and closes the hole. What could be simpler.
Regarding the ignition for the G38, did you get the one for 5/8" hex plugs or 3/4"? The one for 5/8" would take a much smaller hole. You could even downsize to a CM -6 size plug with an adapter and the cap would be even smaller.
Worse case .... just remove and replace the plug cap. New ones are not that expensive.
Hide Signatures
(in reply to Zeeb)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Eletronic ignition wire thru firewall
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
