Anylink problem with 9C    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Tactic & AnyLink Support Forum >> Anylink problem with 9C
Page: [1]
Login
Anylink problem with 9C - 4/7/2012 4:10 AM
Eindecker_pilot
Last Login: 5/19/2013
Status: offline
The issue I'm having is that the throttle control on the plane (a micro super-cub) is mapped the aileron stick on the transmitter. This is with the normal default channels on the tx. When I turn the anylink on and try to get it to map into the "alternative channel map" mode, I'm supposed to get 3 beeps but I only get two & it never goes to the alternate channel mapping. It's pretty much useless in this configuration. What could the problem be?
_____________________________
http://www.bealmear.com/dawn_patrol/
Hide Signatures
       Post #: 1
RE: Anylink problem with 9C - 4/17/2012 8:53 PM
Bax
Last Login: 5/17/2013
Status: offline
The 9C can pose a difficulty. Don't use the on/off switch of the transmitter. With the 9C transmitter turned on, unplug the AnyLink cable from the module, itself; hold the stick like you normally would, and then plug the cord back into the module. It should now configure normally.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to Eindecker_pilot)
       Post #: 2
RE: Anylink problem with 9C - 12/22/2012 7:31 AM
Macymastiff
Last Login: 4/3/2013
Status: offline
I'm basically having the same problem, but with the Heli-Max Axe 100 FP. I'm sure I put  it in the alternate mode because when I held tihe left throttle to the lowest position and holding it to the  left I  heard the 3 beeps and then  2 beeps after that, I then removed  the adaptor from the trainer port and plugged it back in and tryed to bind it with my DX6i, but the mapping was really messed up, the left throttle stick was operating the right and left cyclic  and the right stick was operating the collective or throttle. I  took it to my LHS and they tried to reverse it back to the default settings and they had the same problem, they thought  I put it in either mode 3 or 4 and couldn't change it.
Any help would be much appreciated,
Macymastiff
< Message edited by Macymastiff -- 12/22/2012 7:32 AM >
Hide Signatures
(in reply to Bax)
       Post #: 3
RE: Anylink problem with 9C - 12/27/2012 8:46 PM
Bax
Status: offline
If the AnyLink module is giving you the alternate channel mapping, repeat the process to change the mapping. It should return to the regular mapping, per the instructions. That is, you hold the throttle stick to low and in one corner and plug the unit in to give it power. It will work a bit and then give you the tones. Then cycle the power as per normal. When you turn back on, you should get the single tone.
You may want to check your transmitter's mode. Look in the instructions for that its stick mode programming.
Hide Signatures
(in reply to Macymastiff)
       Post #: 4
RE: Anylink problem with 9C - 1/9/2013 10:52 PM
pappy 883
Status: offline
quote:
ORIGINAL: Bax
is that a one time deal or do you have to do it each time you fly ?
I'm scared, don't want to loose another aircraft.
< Message edited by pappy 883 -- 1/9/2013 10:57 PM >
____________AIRSPEED IS LIFE_____________
Hide Signatures
(in reply to Bax)
       Post #: 5
RE: Anylink problem with 9C - 1/10/2013 4:02 AM
Macymastiff
Status: offline
 Thanks Bax, I'll give it a try!
Hide Signatures
(in reply to Bax)
       Post #: 6
RE: Anylink problem with 9C - 1/10/2013 3:09 PM
Bax
Status: offline
Pappy, you set the stick mode once. Not every time you fly.
Hide Signatures
       Post #: 7
RE: Anylink problem with 9C - 1/10/2013 3:28 PM
pappy 883
Status: offline
Thanx Bill , just received my new plane and want to get it right this time.
Hide Signatures
(in reply to Bax)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
