RE: Dirty Birdy ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Dirty Birdy ARF
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: Dirty Birdy ARF - 5/4/2012 10:38 PM
PatternPilot
Score: 125
Last Login: 5/24/2013
Status: offline
JAS,
Are you going to make it to Andersonville CPA contest ?
Scott
_____________________________
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
(in reply to AllTheGoodNamesAreTaken)
       Post #: 351
RE: Dirty Birdy ARF - 5/5/2012 1:05 AM
ChiefK
Score: 100
Last Login: 5/18/2013
Status: offline
OK... I give up. I really tried to keep the tank formers as installed. Popped them out, real easy as you described, and pushed in a 12oz Kavan tank that fit perfectly. Movin' on....
ChiefK
Opinions based on thin air will always carry little weight.
Hide Signatures
       Post #: 352
RE: Dirty Birdy ARF - 5/5/2012 4:42 AM
rogera
Score: 100
Last Login: 5/22/2013
Status: offline
Strange to relate, I also found a Kavan 12oz tank in my "come in handy one day box" and thought it looked as though it should fit, so that is what it will be. A 9oz tank will be gone in a very short time and don't fancy having a Dirty Birdy shaped glider on my hands !!
Not sure of all this talk about formers being easily removed is a good thing, hope the firewall is glued in a bit better !!
Hide Signatures
(in reply to ChiefK)
       Post #: 353
RE: Dirty Birdy ARF - 5/5/2012 5:43 AM
Ralph White
Score: 100
Status: offline
Looks to me like removing the two front formers takes out the support for the retract nose wheel mounting rails.
I recieved the Hayes 16 oz tank today and it appears to me that it will work fine. I slide it up to the #2 former which is about 3 1/2" from the back side of the firewall. I am using an OS 61 RF with pump so I can mount the tank back without worrying about fuel draw. I may move the tank even further back to be closer to the CG. I don't know if 3 1/2" back from the firewall will work without a fuel pump. If you remove some or all of the #2 bulkhead the tank may go in closer to the firewall. I don't plan to remove the bulkhead as I believe the nose gear mounting rails are supported by the bulkheads.
Here are some pictures. The 3rd picture is looking from the front into the firewall hole seeing the tank up against the 2nd bulkhead. I was holding the fuselage upside down in the picture.
Ralph White
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Original AMA # 5646
Hide Signatures
(in reply to rogera)
       Post #: 354
RE: Dirty Birdy ARF - 5/5/2012 11:19 PM
BuzzKill78
Score: 100
Last Login: 6/5/2012
Status: offline
Can anyone give me a positive ID of the covering material so I can get a perfect match? I plan on putting strips over covering over the seams where the horizontal stabs meet the fuselage.
Hide Signatures
(in reply to Ralph White)
       Post #: 355
RE: Dirty Birdy ARF - 5/5/2012 11:20 PM
BuzzKill78
Score: 100
Status: offline
Can anyone give me a positive ID of the covering material so I can get a perfect match? I plan on putting strips of covering over the seams where the horizontal stabs meet the fuselage.
Hide Signatures
       Post #: 356
RE: Dirty Birdy ARF - 5/6/2012 2:29 AM
maukaonyx
Score: 133
Last Login: 5/23/2013
Status: online
I received mine yesterday and am pleased enough. I do wish they had not hinged the flight surfaces. My ailerons are not centered in the middle of the trailing edge of the wing. On one wing, the ailerons are high. On the other they are low. I am picky about stuff like this, so I will cut the CA hinges and remount to my satisfaction. I will do the same to the elevators. Only the rudder is centered on the fin enough to leave it alone. There are the usual few wrinkles on the elevators and ailerons. Haven't tried to iron or heatgun them out yet. Jon
Carl Goldberg Ultimate 10-300 Brotherhood #01
Club Saito #707
Hide Signatures
(in reply to BuzzKill78)
       Post #: 357
RE: Dirty Birdy ARF - 5/6/2012 12:27 PM
ChiefK
Score: 100
Status: offline
Jon,
I guess I got a better hinge installer than you did. Mine are OK, and the ailerons are straight. Initially (when I unpacked the box) the covering was very good. No wrinkles to speak of. After sitting in my house for a couple of weeks now, the wrinkles just kept coming. I ironed out a huge number of wrinkles yesterday. Hopefully they'll stay gone. Also trying to match the shade of red in photoshop as a background for my AMA number decals.
I've just printed out a test sheet with five sets of numbers on a red background with minor variations of red shading. If they all miss the mark, I'll try a larger color test strip to locate the correct shade. I print these on white decal paper (rather than clear) so that the darker wing covering doesn't dilute the color I want in the numbers. This one might be close...
ChiefK
Click for fullsize
< Message edited by ChiefK -- 5/6/2012 3:51 PM >
Hide Signatures
(in reply to maukaonyx)
       Post #: 358
RE: Dirty Birdy ARF - 5/6/2012 2:33 PM
maukaonyx
Score: 133
Status: online
Thanks for the headsup on wrinkles over time. I usually go over the whole plane and I expect to do the same with the gun and iron. Nice numerals...dude you have a low AMA#, I am proud of mine too...40239. BTW, I might go cheap and simple on you guys and use a 4 stroke engine I have (several to choose from) as well as fixed gear. Nobody crucify me! Most discussion here is on what 2 stroke with pipe to use, and retracts fitment, as well as fuel tank enlargement and fitment. I don't compete and don't need to last a whole routine, I just fly my own sport pattern as I call it, and typically take 7 or 8 minute flights. I do enjoy reading what you guys are doing though! Jon
Club Saito #707
Hide Signatures
       Post #: 359
RE: Dirty Birdy ARF - 5/6/2012 3:04 PM
ChiefK
Score: 100
Status: offline
Cheap and simple is my way too. I will be using a Webra .61 with a regular Macs Muffler (I have three Webra's), and fixed gear. I do have a World Models Intruder with a Saito .91, and I flew my first SPA event last summer. Lots of fun and planning to go back again. I didn't like the 8.8oz tank that came with the DB, mostly because I like 10 minute flights plus a little reserve ...just in case, hence the 12oz substitute I mentioned earlier. I doubt that you'll get 7-8 minutes out of your 4-stroke with a 8.8oz tank.
< Message edited by ChiefK -- 5/6/2012 3:50 PM >
Hide Signatures
       Post #: 360
RE: Dirty Birdy ARF - 5/6/2012 3:38 PM
hook57
Score: 120
Status: offline
quote:
ORIGINAL: maukaonyx
Jon,
I have the same issue with mine, although the elevators are okay, the tips trailing edges are angled upwards slightly. I may or may not cut the ailerons off, but I will be CA'ing a strip of carbon to them to straighten and hold em straight. Other than that I'm pretty happy with the DB.
Mark
Hide Signatures
       Post #: 361
RE: Dirty Birdy ARF - 5/6/2012 5:37 PM
vasek
Score: 147
Status: offline
quote:
ORIGINAL: ChiefK
ChiefK
Nice work Chief! You might want to double-check the spacing between the no. 2&5 and 0&1
Remember: Speed is life!
Hide Signatures
       Post #: 362
RE: Dirty Birdy ARF - 5/6/2012 9:45 PM
ChiefK
Score: 100
Status: offline
Simply a test example. I wasn't concerned about kerning for this part, but I appreciate hearing from people as detail oriented as I am. Here's the final numerals with the correct background color. The "artifacts" you can see in the red portion are not on my hi-res version.
ChiefK
Click for fullsize
< Message edited by ChiefK -- 5/7/2012 5:00 PM >
Hide Signatures
(in reply to vasek)
       Post #: 363
RE: Dirty Birdy ARF - 5/7/2012 9:55 PM
BuzzKill78
Score: 100
Status: offline
Has anyone applied the decals yet? I'm debating whether or not I should put them on, but haven't see a picture of the plane with them on.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 364
RE: Dirty Birdy ARF - 5/7/2012 10:51 PM
ChiefK
Score: 100
Status: offline
You may see a lot of that (ignoring the "stickers"). As you can see in some earlier posts, I'm making my own decals.....
ChiefK
Click for fullsize
Hide Signatures
       Post #: 365
RE: Dirty Birdy ARF - 5/7/2012 10:55 PM
rv7driver
Score: 105
Status: offline
Go to tower web sight they show pic's of it with Decals....
the old saying in aviation is keep the dirty side down!; how Boring!
Hide Signatures
       Post #: 366
RE: Dirty Birdy ARF - 5/7/2012 11:07 PM
BuzzKill78
Score: 100
Status: offline
quote:
ORIGINAL: rv7driver
You're going to have to show me that one. I'm not seeing it. And I've been looking at these pages since a few days before Toledo. NEVER have I seen a picture of it with decals.
I've looked 3 places (4 if you include the manual)
HERE (no decals)
-and-
HERE (no decals)
-and-
HERE (no decals)
Hide Signatures
(in reply to rv7driver)
       Post #: 367
RE: Dirty Birdy ARF - 5/8/2012 1:02 AM
BuzzKill78
Score: 100
Status: offline
I think I know why Tower doesn't show a picture of the plane with the decals on. Because the decals are ugly and RUIN the appearance of the plane.
I did a quick photoshop of the plane with the decals in various locations. Decals aren't necessarily to scale, but they're close.
Click for fullsize
Hide Signatures
       Post #: 368
RE: Dirty Birdy ARF - 5/8/2012 1:16 AM
ChiefK
Score: 100
Status: offline
quote:
ORIGINAL: BuzzKill78
Amen!
I guess that I just didn't want to say that so bluntly.... but it's true.
ChiefK
Hide Signatures
       Post #: 369
RE: Dirty Birdy ARF - 5/8/2012 1:50 AM
jet22b
Score: 110
Status: offline
Hey Guys,
Just finish with the wings!! Now on to the fuse. I look at the decals when I open the box and file them away!! Now the only decal I would like to put on my D.B., is the one in the lower left of Chiefk picture. I think I will stay with the stock tank on my D.B. Short flight for me is okay!! But when I was young, I would drain every drop of fuel out of the tank!!
Be back with pictures!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 370
RE: Dirty Birdy ARF - 5/8/2012 3:11 AM
BuzzKill78
Score: 100
Status: offline
Don't get me wrong.. I like the decals. They would really look their part on a plane from this era. The problem is, they don't really work at all with this trim scheme. Besides, this plane looks so good butt-nekkid without any decals or graphics it's a shame to ugly it up.
Hide Signatures
(in reply to jet22b)
       Post #: 371
RE: Dirty Birdy ARF - 5/8/2012 4:24 AM
doxilia
Score: 136
Status: online
Nothing wrong with decals, but this trim scheme is not suited to "modern" graphics.
The font choice and design is simply wrong - too square for a rooound and looong model...
David
Hide Signatures
       Post #: 372
RE: Dirty Birdy ARF - 5/8/2012 11:59 AM
patternflyer76
Score: 100
Status: offline
Got mine last week and have been getting ready for setting this bird up electric. I started by pulling the main components out and weighing them. I too have a problem with the ailerons not being hinged on center. The left wing is up near the tip and the right wing is down near the tip. Maybe this will wash each other out. This could be a real problem, but I refuse to cut them off and re-do them until I can prove it is causing a severe trim problems or I can not mix it out with my radio. Some pics of the weights. More to come as I get the time to weigh.
Electric set up so far on my test stand is as follows:
GP RimFire .80 500kv
Gene Ace 6s 4000 Mah 25c Lipo
80 ESC (Cheap One)
APC 13.5x10,11,12,13
APC 13x6,8
On the 13.5x13 I am just at the 1400 watt limit. I will post more of my test results as I have time to test each prop.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to doxilia)
       Post #: 373
RE: Dirty Birdy ARF - 5/8/2012 2:52 PM
vasek
Score: 147
Status: offline
MAN you're organized! (me jealous) I'm sure you don't eat "SloppyJoes"
I'm an artist, looking for my tools all the time...
Cheers, V.
Hide Signatures
(in reply to patternflyer76)
       Post #: 374
RE: Dirty Birdy ARF - 5/8/2012 5:26 PM
JAS
Score: 111
Last Login: 4/24/2013
Status: offline
Seems Santa came early... either that or I am supposed to build this thing for testing our E-Tracts. Seems they will fit with only needing to do a little relief work for the nubs on the sides of the E-Tract. Only pulled out the right panel and the aileron looks straight.
Click for fullsize
Click for fullsize
Uncle JAS x 2
Shulman Aviation
Check us ^^^ out for US Team stuff
Hide Signatures
(in reply to vasek)
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.063RCU1
