RE: Dirty Birdy ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Dirty Birdy ARF
Page: <<   < prev  19 20 21 [22] 23 24 25 26 27 28   next >   >>
Login
RE: Dirty Birdy ARF - 6/10/2012 4:13 PM
hook57
Score: 120
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: ChiefK
Slows down and lands quite nicely if you balance it correctly. With a Webra .61 2-stroke engine up front, mine needed 1.25oz of lead weight in the tail. Obviously more tail weight would be needed with a heavier engine.
ChiefK
Thanks for all of the detailed info Chief!  I'm pretty sure my side exhaust Speed .61 does not have the factory drilled holes so the muffler strap adapter would be needed. I'll likely go two-stroke on it, no sense in buying another engine when the drawer has plenty in it to choose from. I've used Mac's mufflers before and have always been pleased with their performance so likely that's what I'll use. Going to start getting it ready for assembly today and hopefully maiden her in early July. Thanks again Chief.
Mark
Hide Signatures
(in reply to ChiefK)
       Post #: 526
RE: Dirty Birdy ARF - 6/10/2012 7:30 PM
ChiefK
Score: 100
Status: offline
Glad to help Mark... as an update, I decided I need a little more ballast in the tail, based on how much down elevator I need when inverted. Added .25oz (total: 1.5oz) after todays flying. We'll see how that works next week.
ChiefK
_____________________________
Opinions based on thin air will always carry little weight.
Hide Signatures
(in reply to hook57)
       Post #: 527
RE: Dirty Birdy ARF - 6/12/2012 2:37 AM
patternflyer76
Score: 100
Last Login: 5/19/2013
Status: offline
I am really close to test flying this thing. Some pics of my pull pull rudder modification to the belly of the craft. I just have to lock tight every thing and I will be ready to try it out this Sunday!!!!
Kevin
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 528
RE: Dirty Birdy ARF - 6/12/2012 8:25 PM
SanJoseDale
Score: 100
Last Login: 5/20/2013
Status: offline
Kevin, curious why you run the pull pull on the outside of the fuse? Also, I think I read earlier that you are going to use 6s battery? What is your all up weight? I am anxious to hear how this goes. I just finished an electric Kaos and would like to try this dirty birdy next.
Dale
< Message edited by dolstinske -- 6/12/2012 8:51 PM >
Hide Signatures
(in reply to patternflyer76)
       Post #: 529
RE: Dirty Birdy ARF - 6/13/2012 12:20 AM
patternflyer76
Score: 100
Status: offline
I simply did not want to try and fit a servo behind the tray I made for the elevator servo to get center line geometry. Also I knew the rudder servo had to go aft my CG point with the battery slightly forward of the CG. This is where it ended up balancing out. With the tri-gear I should not have to worry about a snag unless the grass gets really long. The wire is coated and protected. Also the pull-pull is in-line now with the rudder. If inside the the fuse I would have been at a large angle up to the rudder horn per the stock placement of the horns.
All up weight last measured with everything in is 7.62 pounds.....
Kevin
Hide Signatures
(in reply to SanJoseDale)
       Post #: 530
RE: Dirty Birdy ARF - 6/13/2012 4:31 AM
jet22b
Score: 110
Status: offline
Kevin;
Can not wait to hear your flight report!!! A video will be sweet too!!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 531
RE: Dirty Birdy ARF - 6/16/2012 4:16 PM
patternflyer76
Score: 100
Status: offline
I decided to put cooling holes in to vent the batteries after some ground testing.
Kevin
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to jet22b)
       Post #: 532
RE: Dirty Birdy ARF - 6/16/2012 5:31 PM
jet22b
Score: 110
Status: offline
Kevin;
Your DB is looking good!!! Can't wait to hear your flight report!! Oh well, my DB is packed in the suv for a fun day of flying1
Just hung the sgin on the workshop door, " Gone Flying "!!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 533
RE: Dirty Birdy ARF - 6/18/2012 10:30 PM
Cobra1
Score: 100
Status: offline
I have really enjoyed reading through this thread and feeling the enthusiasm for this aircraft. I always wanted one way back when but did not believe I had the building talent to get it right so I never built one. I did build a Sig King Kobra and flew it for many years and love the way a pattern type airplane flies. I still have the motor and retracts from the King Kobra. I just got the DB ARF and starting installing my old YS-60 and Spring Air retracts. I will be installing a 16oz tank right in front of the servo tray as the YS does like its fuel. I can’t wait to see this plane low and fast right down the middle of the runway – woopee!
Hide Signatures
       Post #: 534
RE: Dirty Birdy ARF - 6/19/2012 1:07 AM
hrrcflyer
Score: 121
Status: offline
Hey Cobra,
I'm glad someone else is putting a YS 2 stroke in their DB. Is yours a FS or FR? I'm going to put a 60FS in mine, and it should really haul the mail. Would you be so kind to add a few pics of your motor and pipe installation? I would greatly appreciate it .......
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to Cobra1)
       Post #: 535
RE: Dirty Birdy ARF - 6/19/2012 1:22 AM
ChiefK
Score: 100
Status: offline
quote:
ORIGINAL: ChiefK
ChiefK
I'm up to 2oz of weight at the tail now, but it still drops the nose in inverted a little more than I'd like. Probably will fly it a bit more before going any further, but will advise if/when I do.
ChiefK
Click for fullsize
Hide Signatures
       Post #: 536
RE: Dirty Birdy ARF - 6/19/2012 1:42 AM
Cobra1
Score: 100
Status: offline
quote:
ORIGINAL: hrrcflyer
Hey Cobra,
David
Pipe on order. Old one was loud. Going with a quiet pipe this time. Will post pics once complete. Most likely another week or two before ready to fly.
Hide Signatures
(in reply to hrrcflyer)
       Post #: 537
RE: Dirty Birdy ARF - 6/19/2012 5:49 PM
jet22b
Score: 110
Status: offline
quote:
ORIGINAL: ChiefK
quote:
ORIGINAL: ChiefK
ChiefK
ChiefK
ChiefK,
One quick question, if I may ask?? Is your CG as per manual?? I was flying my DB this past weekend and I was holding down elevator to keep her level. Also, did you add the weight in or outside the fuselage at the tail?? Thank for the info, Chiefk.
BTW: Sweet picture of your DB upside down!!
Thanks again!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 538
RE: Dirty Birdy ARF - 6/24/2012 6:44 PM
patternflyer76
Score: 100
Status: offline
(Test Flight Report)
Take off was great with little effort. Balance was great and it flew very true and strait. IT was very smooth as well. The smoothest flyer I have had yet, and I am sure it was because it is electric. Very little vibration. It climbed with little effort and did not run out of steam until I was ready to let off the throttle. First flight was 5 minutes long. After landing the motor, ESC, and battery was cool and not even warM in the least bit. I had only used 1/4 of the battery and I was on the throttle a lot.
Second flight was 9 minutes long and I used 1/2 of the 4000 Mah battery. I had flown the whole SPA Expert routine and some, but I could tell the volts had started dropping and decreasing my verticals near the end (less Watts).
I would compare this set up to a 5-6 pound plane with an OS 91 4stroke on it.
The other thing is that when I got done I put the plane right in the vehicle and home I went. No cleaning, no wiping off oil and so on. No hauling around nitro fuel and so on. Its a wonderful life.
This is the hot set up!!!!!!!!!!!!!!!!!!!
Kevin Clark
AMA 340037
SPA 427
< Message edited by patternflyer76 -- 6/24/2012 10:10 PM >
Hide Signatures
       Post #: 539
RE: Dirty Birdy ARF - 6/24/2012 7:34 PM
pjwright
Score: 100
Last Login: 4/24/2013
Status: offline
I'm mounting a Saito FA-82 on mine, with a 12 oz. Kavan fuel tank. The fuel line is roughly 1/4" below the fuel nipple on the engine, and just a smidge above the center of the carb air intake (as shown). Any thoughts on fuel draw issues before we brace everything in place?
PJ
Click for fullsize
Hide Signatures
       Post #: 540
RE: Dirty Birdy ARF - 6/24/2012 8:24 PM
jet22b
Score: 110
Status: offline
Kevin;
Congrat on your maiden flight with your DB. Sound like you are happy and that's what count!!!
I have to pickup two more when Tower have them back in-stock!!
Again, congrat on your maiden and have many more good flight with her!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 541
RE: Dirty Birdy ARF - 6/24/2012 10:07 PM
ChiefK
Score: 100
Status: offline
Sonny,
I'm not sure exactly where the CG is supposed to be by plan... (I think, 7 inches from the trailing edge) just adjusting based on the way the DB is flying. Added another 1/4oz (total 2.25oz now), "stick-on" weight on the bottom of the stabilizer. I think it's real close to the way I want it to fly now. I'm going to leave it alone for a while. If you need down elevator for straight and level upright flight, I'd guess that you have an incidence issue. Make sure you don't have a servo cable or some other object preventing the wing from seating properly. Measure the incidence of the wing vs. the stabilizer. Should be zero-zero. If you're talking about straight and level inverted flight, then a small amount of down elevator is normal.
Thanks for your comment about the picture of inverted flight.
Has anyone besides me noted that the wing dowels at the leading edge are not glued in. Mine have become loose enough to twist and pull out! Since they appear to be nylon rather than wood, I'm not sure what kind of adhesive to use. I'm thinking maybe CA.
ChiefK
Hide Signatures
       Post #: 542
RE: Dirty Birdy ARF - 6/24/2012 10:13 PM
ChiefK
Score: 100
Status: offline
PJ - I've got the same tank and setup for my 2-stroke .61. No fuel draw problems with 30-some flights on the airplane. You gonna be in Asheville next month? Barring some kind of disaster between now and then, I'll be there..
Greg
(ChiefK)
SPA444
Hide Signatures
(in reply to pjwright)
       Post #: 543
RE: Dirty Birdy ARF - 6/24/2012 10:54 PM
pjwright
Score: 100
Status: offline
Thanks for the encouragement, Greg I'm hoping to get this thing together in time to practice for the SPA event here in Chattanooga in August. I'm strictly "novice" at this point ... so don't have the "bug" to travel around the circuit yet. Mike Robinson is working with me (or on me?).
PJ
Hide Signatures
       Post #: 544
RE: Dirty Birdy ARF - 6/25/2012 1:19 AM
lfinney
Score: 105
Status: offline
CA glue may be safe for the nylon dowels, but the CA kicker will cause brittleness and weakness...tried it after reading thread on rcu about it,,scarey
Hide Signatures
       Post #: 545
RE: Dirty Birdy ARF - 6/25/2012 2:01 AM
jet22b
Score: 110
Status: offline
quote:
ORIGINAL: ChiefK
Sonny,
I'm not sure exactly where the CG is supposed to be by plan... (I think, 7 inches from the trailing edge) just adjusting based on the way the DB is flying. Added another 1/4oz (total 2.25oz now), ''stick-on'' weight on the bottom of the stabilizer. I think it's real close to the way I want it to fly now. I'm going to leave it alone for a while. If you need down elevator for straight and level upright flight, I'd guess that you have an incidence issue. Make sure you don't have a servo cable or some other object preventing the wing from seating properly. Measure the incidence of the wing vs. the stabilizer. Should be zero-zero. If you're talking about straight and level inverted flight, then a small amount of down elevator is normal.
ChiefK
Chiefk;
Flew my DB today and had a blast!!! This baby take me back to the mid 70's when I had my first one. I just my have to pickup 2 more DB's wihen Tower has them back in-stock I also had the wing dowels not glue in. I use epoxy on the dowels with no problem.
Again, thanks for the info.
Have a great week!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 546
RE: Dirty Birdy ARF - 6/25/2012 11:50 AM
rv7driver
Score: 105
Last Login: 5/16/2013
Status: offline
Attended the SPA meet this past week in @ Hodges, 3 DB ARFs were in the mix. Jeff Owens won the Senior Expert, OS 61 SF pump, The DB really groved! Jeff had a lot to do with it also he's really good on the sticks. I ordered one but back ordered hope to get it soon. Pete
the old saying in aviation is keep the dirty side down!; how Boring!
Hide Signatures
       Post #: 547
RE: Dirty Birdy ARF - 6/25/2012 12:06 PM
ChiefK
Score: 100
Status: offline
Chattanooga is a little further than I want to drive. Asheville and Knoxville are probably going to be "IT" for me. I'm also flying "novice" and I'm really hoping to fly better than I did last year. Having an experienced "coach" should help you a lot. I've gotten some help this time around too. I think this "Birdy" is an excellent airplane, but I'm also currently building a replacement Deception fuselage to go with my salvaged Deception wing, stabilizer, rudder assembly and canopy.
ChiefK (Greg)
Click for fullsize
Hide Signatures
       Post #: 548
RE: Dirty Birdy ARF - 6/25/2012 12:14 PM
ChiefK
Score: 100
Status: offline
Is Jeff Owens on this RCU thread? I'd really like to know about his "trimming" process.
ChiefK
Hide Signatures
(in reply to rv7driver)
       Post #: 549
RE: Dirty Birdy ARF - 6/25/2012 12:34 PM
rv7driver
Score: 105
Status: offline
Greg, Jeff uses, Skylane. Pete
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.843RCU1
