RE: Dirty Birdy ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> RE: Dirty Birdy ARF
Page: <<   < prev  19 20 21 22 23 24 [25] 26 27 28   next >   >>
Login
RE: Dirty Birdy ARF - 8/1/2012 12:38 AM
pitstop000
Score: 105
Last Login: 6/16/2013
Status: offline
Ralph,
I use a torch to heat it up until it’s easily bendable.
I use metal bars inside and or on the outside of the tubing to make it bend.
I use oak hardwood pieces with a bored hole to clamp in the vise as not to mar the header.
Here are the two torches that I use; if you’re not careful with the heat from the torches you can melt the aluminum.
I have on occasion ruined a header or two using this process ............................
quote:
ORIGINAL: Ralph White
Paul, How did you go about re-bending the header? I was afraid the header might kink if I tried re-bending it.
Ralph White
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Paul Pappas, AMA 42520
www.NECPO.org
Hide Signatures
(in reply to Ralph White)
       Post #: 601
RE: Dirty Birdy ARF - 8/1/2012 12:52 AM
pitstop000
Score: 105
Status: offline
Ben, the header ends up being too close to the fuse so I needed to tweak it so the pipe could be mounted on the side of the fuse.
I put in a balsa block and contoured it for the header fit, then glassed over that. I also contoured the back of the block so you can still fit the stock tank,
but I’m using a 2 oz tank in the location of the stock tank with a 16oz behind that. The NovaRossi 61 is a very thirsty engine when running high rpm.
quote:
ORIGINAL: Strega1
Hey Paul
Thanks for the pics and the info on the DB and Rossi. I'm at a loss on the header. Why did you have to bend it? Was there an obstruction? Does all this grinding weaken the firewal? How are you going to reinforce it and with what? When you are done with this project, please furnish more pics and a blow by blow on how you did this particular cut to the firewall. I'll be doing the same with my project, either the side exhaust w/ Performance Specialties tune muffler, or the RE Rossi and modifications. I'll furnish plenty of photos
Thanks for all the info and the photos.
Ben Cubillos
El Paso, Texas
Click for fullsize
Click for fullsize
www.NECPO.org
Hide Signatures
(in reply to Strega1)
       Post #: 602
RE: Dirty Birdy ARF - 8/1/2012 12:57 AM
PatternPilot
Score: 125
Last Login: 6/20/2013
Status: offline
Paul,
Looks good..... with the header tank are you going to put the main tank on the CG ?
scott
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
(in reply to pitstop000)
       Post #: 603
RE: Dirty Birdy ARF - 8/2/2012 6:59 PM
pitstop000
Score: 105
Status: offline
Scott, I’m still working out my fuel system on the Test stand, but aiming to put the 16 oz close to the CG if possible with my setup.
“HEADER UPDATE”
Even after tweaking the stock NovaRossi header, the clearance that I was looking for could not be achieved, so I cut the exhaust flange off a strait header and bent a new pipe and welded it together. Now I’m back in business, just need to clean up the weld and polish her up. Everything good to go as far as the exhaust.
Click for fullsize
www.NECPO.org
Hide Signatures
(in reply to PatternPilot)
       Post #: 604
RE: Dirty Birdy ARF - 8/3/2012 4:59 AM
pitstop000
Score: 105
Status: offline
header done!!, this has put me behind schedule but worth the power the NOVAROSSI 61 produces
Click for fullsize
www.NECPO.org
Hide Signatures
       Post #: 605
RE: Dirty Birdy ARF - 8/3/2012 1:30 PM
JeffH
Score: 114
Status: offline
Did you TIG the header together?
Hide Signatures
       Post #: 606
RE: Dirty Birdy ARF - 8/3/2012 3:01 PM
PatternPilot
Score: 125
Status: offline
looks like paul is going into the header bussiness.....
Hide Signatures
(in reply to JeffH)
       Post #: 607
RE: Dirty Birdy ARF - 8/3/2012 8:21 PM
pitstop000
Score: 105
Status: offline
Ben, more pics of the glassing and how it turned out before paint.
It came out better than I thought for working with a painted fuse, TAPE is your friend!!
I used UFO thin and some accelerator to do the glassing instead of epoxy, very quick and light process.
quote:
ORIGINAL: Strega1
Hey Paul
Ben Cubillos
El Paso, Texas
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.NECPO.org
Hide Signatures
       Post #: 608
RE: Dirty Birdy ARF - 8/4/2012 3:33 AM
pitstop000
Score: 105
Status: offline
Hey Jeff,
Yes this one was done by Heli Arch/TIG, but I’ve also done them with the aluminum welding rods.
quote:
ORIGINAL: JeffH
Scott, need a lot more equipment for such an endeavor.
I can do them if I run out of options.
I just need a more precision bender which I finally have found though.
quote:
ORIGINAL: PatternPilot
www.NECPO.org
Hide Signatures
(in reply to JeffH)
       Post #: 609
RE: Dirty Birdy ARF - 8/5/2012 4:07 PM
pitstop000
Score: 105
Status: offline
NovaRossi REX CX61 installation pics.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.NECPO.org
Hide Signatures
       Post #: 610
RE: Dirty Birdy ARF - 8/5/2012 5:09 PM
Harv2828
Score: 100
Last Login: 5/14/2013
Status: offline
I have flown my Phoenix 7 arf with the 65 OS and standard muffler. Today's engines are so much better that I really don't think I need a tuned pipe. Goes fast and flys great with eflite electric retracts.
Hide Signatures
(in reply to THERCAV8R)
       Post #: 611
RE: Dirty Birdy ARF - 8/5/2012 5:23 PM
jet22b
Score: 110
Status: offline
pitstop000
Very nice setup!!! I wish I still Had my Rossi CX61.
Have fun and we want a flight report, please!!
Sonny
aka
jet22b
Spitfire Brotherhood #12
P-40 Brotherhood #52
Hide Signatures
       Post #: 612
RE: Dirty Birdy ARF - 8/5/2012 5:36 PM
Ralph White
Score: 100
Last Login: 6/19/2013
Status: offline
Paul, What ball links are you using on the throttle and mixture controls at the engine end? How are they connected to the cables?
Ralph
Original AMA # 5646
Hide Signatures
(in reply to jet22b)
       Post #: 613
RE: Dirty Birdy ARF - 8/5/2012 8:34 PM
landeck
Score: 137
Status: offline
quote:
ORIGINAL: Harv2828
Harv, how did you mount the E-Flite nose gear? I have read that people were having problems with the gear electronics failing because of vibration.
Bruce
Bruce L. AMA# 54227
Ultra Sport Brotherhood #15
Hide Signatures
(in reply to Harv2828)
       Post #: 614
RE: Dirty Birdy ARF - 8/5/2012 8:37 PM
pitstop000
Score: 105
Status: offline
Thanks Sonny,
"Flight Report" sure, that's comming up.
This NovaRossi DB and the other OS powered DB will both be at the NECPO event on Sept 8, 2012 in
Farmington CT
Any qualified pilot will have a chance to fly either one at the event.
quote:
ORIGINAL: jet22b
pitstop000
Sonny
aka
jet22b
Ralph, I used Sullivan's #508 flexible cable which includes the brass couplers with 2-56 threads, just silver solder them on and they fit the ball links.
For the Ball links I use the Dubro 181 for the trotle and the Dubro 190 on the mixture control, they also come with solder on 2-56 couplers.
Ralph
www.NECPO.org
Hide Signatures
       Post #: 615
RE: Dirty Birdy ARF - 8/5/2012 8:51 PM
pitstop000
Score: 105
Status: offline
FINALLY DONE !! More pics Guys.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.NECPO.org
Hide Signatures
       Post #: 616
RE: Dirty Birdy ARF - 8/5/2012 9:23 PM
jet22b
Score: 110
Status: offline
Again, very sweet setup!! Thanks for sharing!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 617
RE: Dirty Birdy ARF - 8/6/2012 2:04 AM
AllTheGoodNamesAreTaken
Score: 118
Status: offline
Paul, that looks fantastic!!!
Don''t just stand there, go get some glue!
Hide Signatures
       Post #: 618
RE: Dirty Birdy ARF - 8/6/2012 4:55 AM
KLXMASTER14
Score: 105
Status: offline
Paul,
Buckle up buddy! That thing is going to haul A$$!! I had the opportunity to fly a ten pounder with the NovaRossi up front. Didn't feel like ten pounds to me. Best of luck on your maiden. Very clean job, by the way.
-Robert
2012 NSRCA D7 Intermediate Champion
West Coast Regional Director- Classic Pattern Assn
Hide Signatures
(in reply to AllTheGoodNamesAreTaken)
       Post #: 619
RE: Dirty Birdy ARF - 8/6/2012 5:31 PM
hrrcflyer
Score: 127
Status: offline
Hey Pitstop000,
You have INCREDIBLE skills..... How are you going to attach the pipe to the fuse for support, or are you?
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to KLXMASTER14)
       Post #: 620
RE: Dirty Birdy ARF - 8/6/2012 7:35 PM
Gene Margiotti
Score: 100
Status: offline
Paul,
What spinner are you using?
Thanks, Gene
Hide Signatures
(in reply to hrrcflyer)
       Post #: 621
RE: Dirty Birdy ARF - 8/6/2012 11:18 PM
pitstop000
Score: 105
Status: offline
Thanks Guys for all the compliments!
“Pipe mount”
I’m using a regular DaveBrown tune pipe mount, not the Hush-clamp, I don’t trust O rings for retaining a pipe and rather strap it with a metal zip tie.
“Spinner”
Custom moded 2 ¼ Tru-Turn FAI spinner.
Here are some pics of the OS 65 AX powered Dirty Birdy, “BD 1”
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
www.NECPO.org
Hide Signatures
(in reply to Gene Margiotti)
       Post #: 622
RE: Dirty Birdy ARF - 8/7/2012 5:50 AM
jet22b
Score: 110
Status: offline
pitstop000,
Another sweet setup!!! Can I come and hangout in your worshop??? Now that I see how the OS 65AX look in this bird, I will have to make the move get get DB #2, ( when Tower get them back in-stock,), I will go with that setup. I just my buy two DB's and set up #3 with the Evo 60nx with a Jett pipe. I have that setup in a Hangar 9 Jackal and its a blast!!!
Thanks, again for sharing!!!
Sonny
aka
jet22b
Hide Signatures
       Post #: 623
RE: Dirty Birdy ARF - 8/8/2012 4:02 AM
pitstop000
Score: 105
Status: offline
Anytime Bud!
quote:
ORIGINAL: jet22b
pitstop000,
Sonny
aka
jet22b
www.NECPO.org
Hide Signatures
       Post #: 624
RE: Dirty Birdy ARF - 8/9/2012 3:34 AM
pitstop000
Score: 105
Status: offline
Going back to wing joiner, forgot to post this at the time.
Here are pics of it all done, used G-flex epoxy for putting it together. One to one by volume or 1.1 to 1 by weight, this epoxy can take flex without cracking like other epoxies once stressed. This was the heavier of the 2 wing joiners so it went into the OS powered Dirty Birdy.
Click for fullsize
Click for fullsize
www.NECPO.org
Hide Signatures
       Post #: 625
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.843RCU1
