TF Contender 60 build thread.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> TF Contender 60 build thread. Page: [1] 2   next >   >>
Login
TF Contender 60 build thread. - 4/9/2012 10:57 PM
jquid
Score: 105
Last Login: 5/3/2013
Status: offline
Hi all,
Here is the beginning of my TF Contender build.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: TF Contender 60 build thread. - 4/10/2012 12:35 AM
outdoorhunting
Score: 351
Last Login: 5/18/2013
Status: offline
Keep us posted. You're gonna love the way it flies. A buddy has one & absolutely loves it.
_____________________________
Too much horsepower- Just right !!!
Hide Signatures
(in reply to jquid)
       Post #: 2
RE: TF Contender 60 build thread. - 4/10/2012 2:18 AM
DavidAgar
Score: 146
Last Login: 5/21/2013
Status: offline
Yes indeed, keep us posted on your progress. It will be a sweet flying plane on completion. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
Hide Signatures
(in reply to outdoorhunting)
       Post #: 3
RE: TF Contender 60 build thread. - 4/12/2012 4:29 PM
klord125
Score: 100
Last Login: 5/20/2013
Status: offline
I have one sitting in the rack waiting to be built. Looking forward to your build!!!!
Hide Signatures
(in reply to DavidAgar)
       Post #: 4
RE: TF Contender 60 build thread. - 4/12/2012 7:17 PM
Mustangman40
Score: 181
Status: offline
Memory lane.. Man that was the go to plane back in the day, really loved the several I had... Looking forward to the build, might even have to pick one up for a OS60 I have laying around..
Jimbo
Ultra Sport Brotherhood #92
Hide Signatures
(in reply to klord125)
       Post #: 5
RE: TF Contender 60 build thread. - 4/13/2012 3:09 AM
jp_boud
Score: 105
Last Login: 5/6/2013
Status: offline
You are going to love the Contender, it is the one plane that always goes to the field with me. The only complaint that I could muster up if I had to, is the shape of the rudder causes pretty bad adverse roll coupling. Some people have changed the shape to fix that, others just learn to fly it as it is. Mine is a rocket with a HB .61. What are you planing on using for power?
My "build thread" HERE: http://www.rcuniverse.com/forum/m_10448191/mpage_1/key_/tm.htm
Click for fullsize
"that''''s not flying, that''''s Falling with style!"
Ultra Sport Brotherhood #108
Hide Signatures
(in reply to jquid)
       Post #: 6
RE: TF Contender 60 build thread. - 4/13/2012 4:39 PM
zippome
Score: 100
Status: offline
I currently have one on my building table right now. I'm just about to build the ailerons and the wingtips. Then on to the fuse. I'm thinking about a side or inverted engine installation, but an unsure on how to proceed. How about you, any mods planned?
Thanks, Zip.
Hide Signatures
(in reply to jp_boud)
       Post #: 7
RE: TF Contender 60 build thread. - 4/13/2012 5:12 PM
smithcreek
Score: 159
Status: offline
I modded it into a taildragger with retracts, also added 1" to the rudder but kept the original shape. The rudder does cause some serious adverse roll, but I also found that with the flap down it doesn't. You can cruise around with the flap down right on the deck just above idle and it handles great doing all rudder turns. I wonder if that was intentional or just lucky. Two other friends that built them at the same time as me enlarged their rudders and made them like a Cap rudder. They said it helps a bit but does not solve the issue of adverse roll. I'm not sure if it has any effect, good or bad, with the flap down.
Click for fullsize
Click for fullsize
For a kit you are, and to a kit you shall return.
Hide Signatures
(in reply to zippome)
       Post #: 8
RE: TF Contender 60 build thread. - 4/13/2012 5:42 PM
klord125
Score: 100
Status: offline
Great looking plane smithcreek. That thing must of picked up with the retracts. Its pretty hot with out them.
Hide Signatures
(in reply to smithcreek)
       Post #: 9
RE: TF Contender 60 build thread. - 4/15/2012 3:53 PM
iAlex
Score: 100
Last Login: 5/19/2013
Status: offline
Here is my Contender that I completed several years ago. Powered by a Jett .46, which is more than enough for this aircraft. The upturned wingtips apparently help with the roll-coupling though I haven't played around enough with it to determine how much of an affect they really have.
Click for fullsize
Hide Signatures
       Post #: 10
RE: TF Contender 60 build thread. - 4/15/2012 7:55 PM
oldtyme
Score: 148
Status: offline
quote:
ORIGINAL: smithcreek
I modded it into a taildragger with retracts, also added 1'' to the rudder but kept the original shape. The rudder does cause some serious adverse roll, but I also found that with the flap down it doesn't. You can cruise around with the flap down right on the deck just above idle and it handles great doing all rudder turns. I wonder if that was intentional or just lucky. Two other friends that built them at the same time as me enlarged their rudders and made them like a Cap rudder. They said it helps a bit but does not solve the issue of adverse roll. I'm not sure if it has any effect, good or bad, with the flap down.
The adverse roll was taken care of by the upswept wingtips in the instructions. I built mine that way and it was solid as a rock. This was a known problem with the original design and that's why they suggested building with the upswept wingtips if you didn't want the roll coupling. Mine met with a different problem. I was flying one day and a fellow club member turned on his radio and it happened to be the same frequency that I was flying. I had the pin but he made a mistake and my plane paid the ultimate price..........it went straight in at full throttle.............
AMA 16066
Hide Signatures
       Post #: 11
RE: TF Contender 60 build thread. - 4/16/2012 2:00 AM
outdoorhunting
Score: 351
Status: offline
Did he do the right thing & get you another plane ?? THAT is an unwritten rule at our club !!
Hide Signatures
(in reply to oldtyme)
       Post #: 12
RE: TF Contender 60 build thread. - 4/16/2012 3:35 AM
jp_boud
Score: 105
Status: offline
I built mine with the upturned wingtips, The adverse roll is still there though. The "meat" of the rudder is so far above the thrust line, the wingtips just can't remove it all. If you know that it's there and fly coordinated you will never notice it. Either way, I still wouldn't trade away my Contender for anything!
Hide Signatures
       Post #: 13
RE: TF Contender 60 build thread. - 4/16/2012 5:04 AM
oldtyme
Score: 148
Status: offline
quote:
ORIGINAL: outdoorhunting
Yes he did!!! He stood there with a blank look on his face, looked down at his transmitter and saw his mistake and then said........"looks like I owe you a plane". He asked me what I wanted and in a couple of weeks I got a call from the LHS that my plane was there.
AMA 16066
Hide Signatures
       Post #: 14
RE: TF Contender 60 build thread. - 4/18/2012 4:28 AM
mred33
Score: 108
Last Login: 3/31/2013
Status: offline
I loved every Contender I ever built. I sold one, crashed two and now have one that is ready for the first flight. Haven't flown it yet, but it is going out soon. I put a new OS55 in this one and it sould move out nicely. Can't say as I ever saw a bad Contender. The second best plane I ever had next to the Kaos......................
Ed
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
Hide Signatures
       Post #: 15
RE: TF Contender 60 build thread. - 4/22/2012 1:22 AM
zippome
Score: 100
Status: offline
How's it coming along jquid? I hope we didnt chase you off!
Zip
Hide Signatures
(in reply to mred33)
       Post #: 16
RE: TF Contender 60 build thread. - 5/1/2012 1:01 AM
radfordc
Score: 100
Status: offline
The adverse roll/yaw coupling is due to the perfectly flat low wing. Raising the wingtips does the same thing as adding a few degrees of dihedral. This problem can't really be fixed by shaping the rudder although any rudder area below the wing will help a little.
Charlie
Hide Signatures
       Post #: 17
RE: TF Contender 60 build thread. - 5/9/2012 10:14 PM
sideng
Score: 100
Last Login: 5/16/2013
Status: offline
Has anyone tried programming a little aileron mixed in with the rudder to counteract the roll effect? Does it work, and if so, how much aileron?
Hide Signatures
(in reply to radfordc)
       Post #: 18
RE: TF Contender 60 build thread. - 3/20/2013 7:07 PM
LawnDartMike
Score: 100
Status: offline
Did the build ever get finished? Pics?I just received my kit in the mail yesterday and will start building tonight. I'll try to post pics along the way and I'm sure I'll have a bunch of questions. My only other kit build was an Uproar converted to electric. That build was quite simple so I thought the Contender would be a good second kit.
Hide Signatures
(in reply to jquid)
       Post #: 19
RE: TF Contender 60 build thread. - 3/21/2013 4:00 PM
Bax
Score: 169
Status: offline
The original Contender was designed to be extremely fast to build. The original kit could have the "bare bones" assembled in 8 labor hours! The wing was flat because you could use 48" pieces for the wing spars and leading and trailing edges. That made it simple and light!. The thick wing made it stronger as well as made it have good low-speed handling. A lot of good ideas went into the original design.
The more-recent kit was re-engineered because all of the original tooling had been worn to the point of uselessness when Top Flight was acquired by Hobbico so many years ago.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to LawnDartMike)
       Post #: 20
RE: TF Contender 60 build thread. - 3/21/2013 4:12 PM
smithcreek
Score: 159
Status: offline
quote:
ORIGINAL: sideng
I've tried it. Doesn't not work well. If you can add enough aileron to keep it level you find out you also need a considerable amount of up elevator to keep the nose from dropping. Aerodynamically I don't know what the term is, but you have to add so much opposing control surface that the plane gets really wonky. The plane then slows down with all that drag and the forces change and what you programmed for one speed does not work, so the plane starts getting out of whack again and eventually stalls or snaps. I'm going to cut off my straight wingtips some day and try to raised ones. Two friends tried enlarging the bottom of their rudders and that helped but did not even come close to curing the issue.
Hide Signatures
(in reply to sideng)
       Post #: 21
RE: TF Contender 60 build thread. - 3/21/2013 9:47 PM
WacoNut
Score: 175
Status: offline
When I built my Contender I had read about the issues with the adverse roll so I built the upswept tips and added to the bottom of the rudder. This seems to have corrected the adverse yaw problem. I can jab the rudder stick back and forth and the plane will just wagg it's tail and no tendency to drop a wing. Rolls are nice as well.
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 22
RE: TF Contender 60 build thread. - 3/21/2013 10:31 PM
LawnDartMike
Score: 100
Status: offline
Can you be more specific on the rudder mod? Did you make it like current 3d capable planes?
Hide Signatures
(in reply to WacoNut)
       Post #: 23
RE: TF Contender 60 build thread. - 3/21/2013 10:42 PM
WacoNut
Score: 175
Status: offline
Here are a few pics,
I left the top of the rudder the same chord and doubled the chord at the bottom of the rudder. The problem with the original rudder design is there is 70+% of the rudder above the thrust line, as rudder is applied the plane will roll opposite of the rudder input(left rudder=rolls right). The change I made in the rudder brings the surface area lower on the rudder and closer to the thrust line.
I just drew the change out on the plans before building. I sent my plans to a buddy who is supposed to put them into CAD and laser cut 2 of them in a 30cc size.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 24
RE: TF Contender 60 build thread. - 3/21/2013 10:44 PM
WacoNut
Score: 175
Status: offline
BTW: I put approx 100 flights on my Contender last summer, it is a blast to fly.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.030RCU1
