Wing Bolts?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Wing Bolts?
Page: [1] 2   next >   >>
Login
Wing Bolts? - 4/10/2012 2:53 AM
Tony Gag Jr.
Score: 100
Last Login: 5/11/2013
Status: offline
What are you guys using for wing bolts on your large scale warbirds? I have a Yellow Zero and I am just wondering if I should use nylon or metal for the wing bolts.
Tony
Hide Signatures
       Post #: 1
RE: Wing Bolts? - 4/10/2012 3:02 AM
Ram-bro
Score: 156
Last Login: 5/20/2013
Status: online
remember the purpose bhind the nylons is to shear off in event your rentry to terra firma is not as controlled as it could be. They do save damages. I use the nylon myself
Hide Signatures
(in reply to Tony Gag Jr.)
       Post #: 2
RE: Wing Bolts? - 4/10/2012 3:06 AM
All Day Dan
Score: 151
Status: online
Tony, I use 1/4 X 20 nylon bolts in my 20 pound 50cc planes. Dan.
_____________________________
Dan
Hide Signatures
       Post #: 3
RE: Wing Bolts? - 4/10/2012 3:11 AM
ccostant
Score: 100
Status: offline
Hi Tony,
I'm still using nylon bolts on everything. Typically 1/4-20 bolts. If you're using the stock YA bolts they are actually a little beefer than 1/4-20 bolts. They are 5/16-18 bolts. I'll be getting my YA zero ready to go this month. I'm thinking I may do the maiden at Bridgewater vs Woodstock. I think Bridgewater may be more forgiving in case of an emergency.
Carl
Hide Signatures
(in reply to All Day Dan)
       Post #: 4
RE: Wing Bolts? - 4/10/2012 3:21 AM
denoferth
Score: 105
Status: offline
Long time ago when the earth was still green we used to simmer all our nylon props in water with a little Rit dye mixed in to restore the water content and match the airframe. Seems dried out nylon gets brittle. Just sayen'
I have seen things you people wouldn’t believe.
Hide Signatures
(in reply to ccostant)
       Post #: 5
RE: Wing Bolts? - 4/10/2012 3:52 AM
big max 1935
Score: 100
Status: offline
From my experence about one of the few things that survive the crash are the nylon bolts that are most of the time still bolted to the blocks that are ripped out of the fuselage. Small planes I use SMALLER nylon ones but the big IMAA ones I use steel. My opinion , Max H.
Hide Signatures
(in reply to denoferth)
       Post #: 6
RE: Wing Bolts? - 4/10/2012 4:18 AM
denoferth
Score: 105
Status: offline
Logic tells me that if the frangible bolts survived than they were too strong for the purpose. I also have had that happen so for the smaller birds I have switched to magnets, although I have to admit that does make me a bit nervous.
Hide Signatures
(in reply to big max 1935)
       Post #: 7
RE: Wing Bolts? - 4/10/2012 5:54 AM
A6TEXAN
Score: 100
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: denoferth
lmao
Hide Signatures
       Post #: 8
RE: Wing Bolts? - 4/10/2012 12:21 PM
scale only 4 me
Score: 314
Status: offline
Nylon bolts might break reducing damage in a crash, they never did for me,, but the main purpose is to not vibrate out as easily as metal can.
good luck
Hide Signatures
(in reply to A6TEXAN)
       Post #: 9
RE: Wing Bolts? - 4/10/2012 3:32 PM
BobH
Score: 116
Status: offline
There is a method to make your nylon bolts shear as they are supposed to. Cut through them say 30-40 percent and then insert them.
The tensile strengh for a nylon 1/4-20 bolt is about 300lbs and shear is about 400lbs.
BobH.
Hide Signatures
(in reply to scale only 4 me)
       Post #: 10
RE: Wing Bolts? - 4/10/2012 3:54 PM
BarracudaHockey
Score: 280
Status: online
Metal bolts + metal blind nuts = asking for trouble
Don't ask me how I know.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to BobH)
       Post #: 11
RE: Wing Bolts? - 4/10/2012 5:53 PM
alanc
Score: 105
Status: offline
5-8mm nylon ones for me,     we dont have those strange imperial sizes you all love so much,
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 12
RE: Wing Bolts? - 4/10/2012 8:41 PM
Tony Gag Jr.
Score: 100
Status: offline
Thanks for all the help. Nylon bolts it is.
Carl, I am not sure if the bolts I have are from Yellow or not. Mine has metal blind nuts installed and I am pretty sure they are 1/4-20. I think my test flight will be at Woodstock. Jesse will be doing the test flight so it will be at his field of choice. All I have to do is balance mine and it will be ready to go.
Tony
Hide Signatures
(in reply to alanc)
       Post #: 13
RE: Wing Bolts? - 4/10/2012 9:24 PM
Scalenut-RCU
Score: 100
Status: offline
Mama always told me I was different!
I guess ya'll proved it.  I use, and always have used, metal bolts on all my 50cc and bigger gas models.  I figure with the side loads imposed by long legged retracts on these beasts coupled with 30lbs or more on most of them that nylon heads would be  popping off left and right if I staid with that method.  As to vibrating loose,  that has happened to one bolt in 10+ years so it has not really been an issue for me.   I do tend to stick with metal bolts tapped into cherry or oak hardwood blocks and try to avoid blind nuts all the time.
To each his own I guess.
Forest
Hide Signatures
       Post #: 14
RE: Wing Bolts? - 4/10/2012 9:48 PM
jessiej
Score: 144
Status: offline
quote:
ORIGINAL: alanc
If we went metric we would have a tough time replacing all our standard three foot doors. BTW, I have some old BSF nuts and bolts in the shop too.
jess
Hide Signatures
(in reply to alanc)
       Post #: 15
RE: Wing Bolts? - 4/11/2012 12:57 AM
ccostant
Score: 100
Status: offline
Hey Tony let me know when the maiden will be. I'd like to see the 1st flight.
Carl
Hide Signatures
       Post #: 16
RE: Wing Bolts? - 4/11/2012 2:25 AM
ckreef
Score: 105
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: BobH
All that is good until you pull out of a dive a little too hard and your wing shears off in mid flight due to the bolts breaking.  Just some food for thought.
Hide Signatures
(in reply to BobH)
       Post #: 17
RE: Wing Bolts? - 4/11/2012 2:54 AM
Tony Gag Jr.
Score: 100
Status: offline
Will do Carl. Just waiting for Darrell at Sierra to get me my spinner back and I will be all set.
Hide Signatures
(in reply to ckreef)
       Post #: 18
RE: Wing Bolts? - 4/11/2012 4:34 AM
Ken Kehlet
Score: 110
Last Login: 5/18/2013
Status: offline
Hi Tony,
I like the 1/4 -20 X 2" NYLON Wing Bolts
Put each one into a Pencil Sharpener and you won't have a problem tring to find that Blind Hole.
70 years of modeling, over 50 years in R/C
Ken AMA 1528
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
kbkopy
Hide Signatures
       Post #: 19
RE: Wing Bolts? - 4/11/2012 11:45 AM
deatonbt
Score: 100
Status: offline
Repeat of previous comment.
Bloch MV-152 Brotherhood #1 thru Omega. Vive Renault Le Car
Hide Signatures
       Post #: 20
RE: Wing Bolts? - 4/11/2012 12:52 PM
BarracudaHockey
Score: 280
Status: online
If the nylon bolts hold up to the abuse dispensed upon them by 50 and 100cc aerobatic 3D planes, they will work fine on any warbird.
www.JaxRC.com
Hide Signatures
(in reply to deatonbt)
       Post #: 21
RE: Wing Bolts? - 4/11/2012 1:17 PM
nine o nine
Score: 105
Status: offline
Rather than point sharpening the bolt heads I cut them at a 45 if nylon and grind if metal. It works on all sizes and makes stripping or misalignment a non event. Mitch
Hide Signatures
       Post #: 22
RE: Wing Bolts? - 4/11/2012 2:16 PM
Check6
Score: 105
Status: offline
quote:
ORIGINAL: Tony Gag Jr.
Tony
Hey Tony,
Good luck with the maiden. I remember when I used to do all test flights for everybody. Tough when you don't trust your eyes anymore.
Later,
Fred
Hide Signatures
       Post #: 23
RE: Wing Bolts? - 4/11/2012 7:11 PM
JeffH
Score: 114
Status: offline
I would not use nylon bolts with blindnuts or in a siutation where you have 4 bolts w/out dowels or rear dowels and front bolts(ala TF P-51 kit). If I have front dowels, then nylon is no problem as long as it is going into thread wood.
Personally I use nylon on sub 15-17 pound planes and metal on larger than that.
Hide Signatures
(in reply to Check6)
       Post #: 24
RE: Wing Bolts? - 4/12/2012 12:43 AM
Tony Gag Jr.
Score: 100
Status: offline
Thanks Fred. I miss those days in a big way. Really wish you were still flying!!!
Hide Signatures
(in reply to JeffH)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
