Home Brew After-Run Oil    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> Home Brew After-Run Oil
Page: [1] 2   next >   >>
Login
Home Brew After-Run Oil - 4/11/2012 1:55 AM
william hanshaw
Score: 100
Last Login: 1/23/2013
Status: offline
I've heard recently that some guys make their own after-run oil by mixing some ratio of Marvel Mystery Oil and good-quality Valvoline transmission fluid.  The expensive after-run oil I purchased some time back looks just like MMO with its red color and odor.  Does someone agree with this, and if so, what's the best ratio of MMO and transmission fluid to mix?
Anyone?
Hide Signatures
       Post #: 1
RE: Home Brew After-Run Oil - 4/11/2012 2:02 AM
Diesel Die-hard
Score: 100
Last Login: 5/8/2013
Status: offline
Interesting suggestion!  I've been using ordinary air tool oil for some years now with very good results.  Any other experiences to add??  I've heard that Rizlone works OK too, but have never tried it.
Hide Signatures
(in reply to william hanshaw)
       Post #: 2
RE: Home Brew After-Run Oil - 4/11/2012 2:09 AM
william hanshaw
Score: 100
Status: offline
Thanks, Diesel Die-Hard!   Will you please see my latest posting about my Russian Elfin 149 ABC, and comment?
Hide Signatures
(in reply to Diesel Die-hard)
       Post #: 3
RE: Home Brew After-Run Oil - 4/11/2012 3:05 AM
ffkiwi
Score: 105
Last Login: 5/18/2013
Status: online
A number of experienced modellers in NZ swear by ATF-automatic transmission fluid, as an afterrun oil/preservative...........
ChrisM
'ffkiwi'
Hide Signatures
       Post #: 4
RE: Home Brew After-Run Oil - 4/11/2012 3:26 AM
Recycled Flyer
Score: 101
Last Login: 5/17/2013
Status: offline
I too like ATF because it has high detergent content.
The detergent will hold in suspension any fluids that have settled on the engines internals ready for expulsion upon the next startup.
It will also stop castor from congealing if left too long and (just my opinion here) probably cut down on the amount of castor based varnish that can occur with high percentage castor oil fuels.
Hide Signatures
(in reply to ffkiwi)
       Post #: 5
RE: Home Brew After-Run Oil - 4/11/2012 3:34 AM
AMB
Score: 110
Last Login: 5/19/2013
Status: online
ATF/MARVEL MYSTERY 50/50 MY BREW- MARTIN
Hide Signatures
(in reply to Recycled Flyer)
       Post #: 6
RE: Home Brew After-Run Oil - 4/11/2012 3:35 AM
soarrich
Score: 136
Status: offline
I use ATF or Air Tool oil both work well.
A 50/50 mix of acetone and ATF works better than Liquid Wench for freeing thing up.
_____________________________
Rich Border AMA 77727
Sig Kadet Brotherhood #2
Hide Signatures
       Post #: 7
RE: Home Brew After-Run Oil - 4/11/2012 11:21 AM
pe reivers
Score: 646
Status: offline
ATF is the best kept secret for after run oil. No additives needed.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to soarrich)
       Post #: 8
RE: Home Brew After-Run Oil - 4/11/2012 1:20 PM
maxtenet
Score: 100
Last Login: 5/15/2013
Status: offline
ATF and Marvel are both good. After run oil is nowhere near as critical for diesels as for glows, though. The alchohol and nitro attract water. Kerosene and castor are water repellant. I only use it for long term storage on a diesel.
Max
Hide Signatures
(in reply to pe reivers)
       Post #: 9
RE: Home Brew After-Run Oil - 4/11/2012 1:34 PM
controlliner
Score: 100
Status: offline
quote:
ORIGINAL: maxtenet
Max
Correction, Methyl alcohol is hydroscopic but nitromethane has nothing to do with water. The byproduct of burned nitromethane is nitric acid. Hence using fuel with synthetic oil and nitro will require after run oil. One point when making fuel, nitromethane has 2% methanol added as a stabilizer so it must be calculated in the percentages.
"Keep it clean and not too lean" Duke Fox
Hide Signatures
(in reply to maxtenet)
       Post #: 10
RE: Home Brew After-Run Oil - 4/11/2012 6:31 PM
Lou Crane
Score: 100
Last Login: 5/14/2013
Status: offline
I've been using Rislone for storage, as GMA recommended.
The lighter 'oils' seem to dry away more quickly. even in a sealed coffee can. Picked up some industrial grade air-tool oil, which is very thick. Haven't given it a good try, yet.
With diesels, three days with ports open for airing out the nitrate residues, of course.
I'll also try ATF, to see how durable it is in our relatively air-exposed use.
For diesels, air tool oil may be a slight hindrance to the first start after storage. I expect they are compounded to deter ignition in an air tool... That should flush out on that first start.
Of the lighter oils, sewing machine oil has some good points. If it handles the relaxed mechanical sensitivities of the ladies, there's something good about it.
\BEST\LOU
Lou Crane, Sierra Vista, AZ
Hide Signatures
(in reply to controlliner)
       Post #: 11
RE: Home Brew After-Run Oil - 4/11/2012 7:18 PM
Jim Thomerson
Score: 160
Status: offline
I use Rislone, and get some green exhaust for a few seconds after I start the engine. Joe Wagner, in one of his engine colums, said that after run oil would keep a diesel from starting. He was referring to the liquid gold the hobby shop sells in a small bottle. Rislone works fine. Incidentally, a friend uses a small percentage of Marvel Mystery Oil in his diesel fuel mix.
Hide Signatures
(in reply to Lou Crane)
       Post #: 12
RE: Home Brew After-Run Oil - 4/11/2012 9:21 PM
Sport_Pilot
Score: 233
Status: offline
quote:
ORIGINAL: Recycled Flyer
Detergent does not hold fluids in suspension, though some may also do that.  By definition detergent removes and keeps solids in suspension, not fluids.
http://www.termwiki.com/EN:detergent_oil
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 13
RE: Home Brew After-Run Oil - 4/11/2012 10:16 PM
geeter
Score: 108
Status: offline
go to wal-mart and get remington spray gun oil. in the green and yellow can. used for firearms. spray it into the carb on two stroke and into the breather tube on four strokes. one good shot of 2 seconds using the little tube and it's protected from rust...........RON
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 14
RE: Home Brew After-Run Oil - 4/11/2012 10:31 PM
larryak
Score: 105
Last Login: 3/24/2013
Status: offline
Thanks AMB. I have been tempted for a long time. Now I'm gonna try it.
Hide Signatures
(in reply to AMB)
       Post #: 15
RE: Home Brew After-Run Oil - 4/11/2012 10:40 PM
spaceworm
Score: 143
Status: offline
quote:
ORIGINAL: pe reivers
Been using it for over twenty years, now. Never a frozen engine or bad bearings. W8YE did say a few years ago that one of the ATFs, maybe one of Fords, was to be avoided for a reason I have forgotten. W8YE??. I use Dextron.
Hide Signatures
       Post #: 16
RE: Home Brew After-Run Oil - 4/11/2012 11:43 PM
ddd
Score: 100
Status: offline
Marvel Mystery air tool Oil is what you buy when you order those little bottles of red stuff that smells like mint. Its Marvel with a rust inhibitor comes in a a white quart can in any auto parts store.
Bob Davis, Owner - Davis Diesel Development
Hide Signatures
       Post #: 17
RE: Home Brew After-Run Oil - 4/11/2012 11:56 PM
Recycled Flyer
Score: 101
Status: offline
quote:
ORIGINAL: Sport_Pilot
The link provided quotes "An oil which keeps particles and contaminants in suspension and has ability to neutralize acids resulting from combustion process. "
And you don't see that 'contaminants' could be fluids?
Detergent by definition is a surfactant - just have a look at what that means.
Hide Signatures
       Post #: 18
RE: Home Brew After-Run Oil - 4/12/2012 2:13 AM
Prop_Washer2
Score: 115
Status: offline
 I believe you meant "Hygroscopic", not "Hydroscopic" which is not a word...just sayin'....
quote:
ORIGINAL: controlliner
quote:
ORIGINAL: maxtenet
Max
"I ran out of ideas and altitude at the same time..."
Hide Signatures
       Post #: 19
RE: Home Brew After-Run Oil - 4/12/2012 2:44 AM
mike31
Score: 114
Status: offline
Corrosion X. Online or at a marine supply store.
Hide Signatures
       Post #: 20
RE: Home Brew After-Run Oil - 4/12/2012 2:51 AM
rrragmanliam
Score: 111
Status: offline
crap ,thought this was a beer thread..
rrragman
"Half a bee, philosophically, must ipso facto half not be. But half the bee has got to be, vis-à-vis its entity - d''you se
Hide Signatures
       Post #: 21
RE: Home Brew After-Run Oil - 4/12/2012 7:57 AM
gene737
Score: 100
Last Login: 5/12/2013
Status: offline
Oh crap,
Been saying it wrong for 45 years. You be right Dancer man!!
Hide Signatures
(in reply to rrragmanliam)
       Post #: 22
RE: Home Brew After-Run Oil - 4/12/2012 8:23 AM
guille2006
Score: 109
Status: offline
quote:
ORIGINAL: william hanshaw
Anyone?
Well; 7 to 5 year ago I used to sell an after run oil made of 98% hydraulic transmission oil + 2% molycote oil (basically a bi-sulfide of molybdenum + oil mixture). Result were EXCELENT!!!!!.
I carried on several test on the hydraulic transmission only wit two engines for comparison (supertigre 40); one with after run treatment, nothing for the other. Results were that, after some time (I have no the records here) the after runned one started as good as new while the second needed more handflips... there was a small rpm decrease too (maybe 200 rpm or so). Glow plug was substancially more clean on the first engine while the second one was more black.
Conclusion: Hydraulic oil is as good as any after run oil.
Hope my expereince it helps the the thread.
Cheers
Exocet Engineering & Design.
Hide Signatures
       Post #: 23
RE: Home Brew After-Run Oil - 4/12/2012 1:53 PM
franchi
Score: 100
Status: offline
ATF!!!!!!!!!!
Hide Signatures
(in reply to guille2006)
       Post #: 24
RE: Home Brew After-Run Oil - 4/12/2012 4:11 PM
Antares100
Score: 105
Status: offline
I used Marvel Mystery Oil on an OS FP .40 in the mid 80's. Just getting back into the hobby, found the engine, and it still has compression and turns easily! Guess I'll find out for sure if MMO works when I start it up.
Hide Signatures
(in reply to franchi)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Everything Diesel >> Home Brew After-Run Oil
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
