H9 TWIST 60    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Piper J-3 Cub 40 ARF / Saito 90 twin - RTF
Seller:  Hill202
Details:   $450.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> H9 TWIST 60
Page: [1]
Login
H9 TWIST 60 - 4/12/2012 3:04 AM
Crazy4Flight
Score: 110
Last Login: 5/22/2013
Status: offline
I bought it second hand from a guy who was going BIG 100cc 3D planes.
I did not recheck his CG as he stated it was in the limits... well it was AFT over 1.25" tailheavy
Shut down the OS 90FX to deadstick it into the tall grass and tore off thelanding gear.
Finally I got around to fixing it..
cut out the junk glue tabs for interlock.
make a new plate and test fit
added tri stock & epoxied a new plate in place.
should be good to go this weekend.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: H9 TWIST 60 - 4/12/2012 1:41 PM
outdoorhunting
Score: 351
Status: online
I've had a couple of Twist 40s. If the "60" flies anything close to the 40s, you're in for the time of your life !! They are fun in a strong wind too. Head it into a strong wind & it'll actually fly backwards. With a little practice, you'll be "parking" it not landing !!  Good luck & have fun !!
_____________________________
Too much horsepower- Just right !!!
Hide Signatures
(in reply to Crazy4Flight)
       Post #: 2
RE: H9 TWIST 60 - 5/24/2012 1:29 AM
Bobhend
Score: 100
Last Login: 12/1/2012
Status: offline
I love my Twist 60; it has a WCL [wing cube load] of 5.8. This puts it close to the low end of what is available. It is electrified, I use a 6S 5000 battery. This battery is about twice what I need but the Twist 60 tends to come out tail heavy, as you discovered. I needed this 26 oz battery to balance and had to cut a relief pocket in the wing to fit it. Typical  3D planes with gas engines in the 70 -80" range have WCL's  around 9.3. These planes have about the same wing area as the T60.
I have my CG at 5 1/2" which is outside the range 5 7/8 to 6 1/2". It is a real squirrel with the CG aft, I may try moving it back as I get better but can't imagine landing at 6 1/2". The tail will drop, plane will pop and stall and hit hard. You would have to land at a good speed to have a prayer.
Hide Signatures
(in reply to outdoorhunting)
       Post #: 3
RE: H9 TWIST 60 - 5/24/2012 1:42 AM
Crazy4Flight
Score: 110
Status: offline
It was the aft battery location that made it tail heavy.
in fact the builder had 1 1/2 oz lead added to the nose on the inside of the "cheeks".
I may get to fly it saturday If theweatyher holds.
The CG is at the foward limit with battery moved forward and 3/4 oz of lead out of the nose.
Hide Signatures
(in reply to Bobhend)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
