Ailerons used as flaps or spoilers    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> Ailerons used as flaps or spoilers
Page: [1]
Login
Ailerons used as flaps or spoilers - 4/12/2012 1:23 PM
thinano
Score: 100
Last Login: 6/5/2013
Status: offline
Hi guys,
I have got a vintage glider equipped with only two ailerons (no flap)
I would like to use both ailerons to reduce the speed during the final approach procedure. I'm hesitating between puttting the ailerons up or fully down.
What do you recommend to me, please ?
Thanks !
Thierry
Hide Signatures
       Post #: 1
RE: Ailerons used as flaps or spoilers - 4/12/2012 2:17 PM
BarracudaHockey
Score: 280
Last Login: 6/18/2013
Status: offline
Try it up high.
If the ailerons are out on the tips I wouldn't put them down at the same time, that gives you wash in and will help induce tip stalling.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to thinano)
       Post #: 2
RE: Ailerons used as flaps or spoilers - 4/12/2012 2:51 PM
thinano
Score: 100
Status: offline
Thanks your your answer !
My glider's model is a german Bergfalke MU 13 and my ailerons stretch from the last 1/3 of the wing to the tip.
I'm surprised because my opinion was : if I put the ailerons down, I increase the lift (and increase the drag as well), so the stall is reduced.
Do I do a mistake ?
Thierry
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 3
RE: Ailerons used as flaps or spoilers - 4/12/2012 3:07 PM
GarySS
Score: 100
Status: offline
The theory is with the ailerons drooped out on the tips the stall is more accentuated out there..........at the tips, hence the wings are more sensitive to dropping to what ever side the wind is hitting, or gravity is pulling, etc. One might be just more naturally sensitive than the other although you don't have engine torque in this case.
Hide Signatures
       Post #: 4
RE: Ailerons used as flaps or spoilers - 4/12/2012 3:09 PM
BarracudaHockey
Score: 280
Status: offline
Yes you do a mistake.
Washout .. http://en.wikipedia.org/wiki/Washout_(aviation)
http://www.propdesigner.co.uk/html/washout_and_washin.html
You want the root to stall first so you still have aileron control
www.JaxRC.com
Hide Signatures
       Post #: 5
RE: Ailerons used as flaps or spoilers - 4/12/2012 3:44 PM
thinano
Score: 100
Status: offline
Thank you !
So I'm going do put up my ailerons ...
How much degrees do you recommend ?
Hide Signatures
       Post #: 6
RE: Ailerons used as flaps or spoilers - 4/12/2012 4:16 PM
BarracudaHockey
Score: 280
Status: offline
The only thing I can tell you is to give it a try at a comfortable height and see what happens. Start small, work your way up.
www.JaxRC.com
Hide Signatures
       Post #: 7
RE: Ailerons used as flaps or spoilers - 4/12/2012 6:50 PM
fudi50
Score: 100
Last Login: 1/12/2013
Status: offline
I agree with last post however if you have a programable TXI would advise adding compensation on elevator just as full house or RES models somewhere 3-8 degrees up. Try at safe altitude.
Hide Signatures
       Post #: 8
RE: Ailerons used as flaps or spoilers - 4/17/2012 10:00 PM
beckerp360
Score: 100
Last Login: 4/27/2012
Status: offline
We used to use "CROW" which was ailerons up and flaps down...produced big drag under control when on an aux switch for killing speed with no pitch up...
UP on both  will kill lift on the outer part of the wing...but like they say try it at a safe altitude...the particular airfoil you have will also make a difference ...and some change root to tip so this can work well...
Hide Signatures
       Post #: 9
RE: Ailerons used as flaps or spoilers - 4/19/2012 3:18 AM
BMatthews
Score: 247
Status: offline
Up for spoilerons is certainly the way to go.
You'll likely be limited to the angle by the hinges. Seldom are aileron hinges set to allow a healty 45 to 60 degrees of up angle for spoilerons if they were intended as ailerons only when originally done. Even 20 degrees up would help but you won't get the full benifit at that shallow an angle. 30 to 45 is nice and 60 would be darn near ideal.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to beckerp360)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
