Balsa USA 1/4 Scale Nieuport 28 Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Balsa USA 1/4 Scale Nieuport 28 Build
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Balsa USA 1/4 Scale Nieuport 28 Build - 4/13/2012 4:26 AM
SunDevilPilot
Score: 147
Last Login: 5/24/2013
Status: offline
Having recently completed a somewhat long term build on a highly modified kit I am looking forward to starting my next project, a Balsa USA 1/4 Scale Nieuport 28.
I will, of course, make some modifications as I go but I am hoping to build the kit more or less stock.  I will be going over the plans for the next week or so and after my review I will make a decision on how to power the model.  I have a new in box Zenoah G-26 purchased but not used on my last build vs. an electric powered model.  I am growing really attracted to the electric side of the hobby so I will likely look at how I can get an electric system into the plane first and if I determine electric is not an option then I will default to the Zenoah as a second plan.
Here is what the kit looked like when it arrived....  Contents of the box are in good shape and were packed nicely.  I'm not sure how the cat got in there.
Stay tuned!
SunDevilPilot
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
       Post #: 1
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/13/2012 6:07 AM
HoundDog
Score: 178
Last Login: 5/23/2013
Status: offline
On Board Thanks
Remember ... Every one of these Things we fly has a Termination date, The more expensive The bigger the tears.
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 2
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/13/2012 12:02 PM
VincentJ
Score: 145
Status: offline
Me as well! Good luck SDP...Buy a plane and get a cat, good deal.
< Message edited by VincentJ -- 4/13/2012 3:22 PM >
VJ
Hide Signatures
(in reply to HoundDog)
       Post #: 3
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/13/2012 2:39 PM
roncannell
Score: 103
Last Login: 5/20/2013
Status: offline
Subscribed
Hide Signatures
(in reply to VincentJ)
       Post #: 4
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/13/2012 8:22 PM
EJWash1
Score: 130
Last Login: 5/25/2013
Status: offline
Subscribed - of course!
EJWash
Hide Signatures
(in reply to roncannell)
       Post #: 5
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/13/2012 11:48 PM
Bob Howard
Score: 100
Status: offline
Subscribed
Hide Signatures
(in reply to EJWash1)
       Post #: 6
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/14/2012 7:44 PM
malitape
Score: 100
Last Login: 5/19/2013
Status: offline
Subscribed and anxious to continue to learn.
pete
pete
Cub Brother #129
Hide Signatures
       Post #: 7
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/14/2012 11:19 PM
box car
Score: 100
Status: offline
 another good build on the way
< Message edited by box car -- 4/15/2012 8:36 AM >
Ken
Wherever conversion engines are outlawed, only outlaws will have conversion engines.
Hide Signatures
(in reply to malitape)
       Post #: 8
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 1:37 AM
SunDevilPilot
Score: 147
Status: offline
After looking over the plans and after I played with some battery configurations on top of the plans I decided an electric variant is a possible choice for this model.
If I install the batteries in a vertical configuration they will fit easily into the cowl.  If I make the top portion of the cowl removable then I will be able to access the batteries.  This will also leave the sides available for mounting the cowl.  My initial plan is to incorporate a stop block into the removable portion of the cowl.  This stop block will act as a keeper for each battery which will be secured to trays slid into some vertical rails.  All this will be on the firewall where I am sure some weight will be needed.
The model already has a "Cooling Tunnel" built into the fuselage at the bottom of the firewall.  In the photo the batteries are all the way down to this "Tunnel".  My plan is to make a secondary firewall that will have the mounting rails for the batteries and the actual motor mounted to it.  This secondary firewall will bolt onto the firewall built into the model.  The stock formers in the area of the firewall are balsa and not up to the task of holding the weight of the batteries.
If you look at the photo of the batteries you can see the curved area just above them.  This is the section I plan to have removable to access the batteries.
The second to last photo, of the ruler on the plans, show there is easily enough ground clearance for just about any prop.
Decisions, Decisions!
SunDevilPilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 4/15/2012 1:59 AM >
SunDevilPilot
Hide Signatures
(in reply to box car)
       Post #: 9
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 1:51 AM
rye
Score: 110
Status: offline
hi
what about weight would she be very nose heavy?
Hide Signatures
       Post #: 10
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 2:00 AM
SunDevilPilot
Score: 147
Status: offline
From what I have seen you need everything up to the firewall plus a good amount of lead (In Most Models)
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to rye)
       Post #: 11
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 4:14 AM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: rye
hi
Pretty much any plane that the full scale had a round engine in will come out tail heavy in a model, just a fact of life builders should know in advance. Most WWI planes have very short nose moments.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to rye)
       Post #: 12
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 4:18 AM
roncannell
Score: 103
Status: offline
Rick had his Batts up forward of the Firewall on his WW1 Electric DR1. When you make your next BUSA order go ahead and order a second, or even third set of landing gear wire. They sell the replacement for a reasonable price, about $10. While your doing your structural soldering you can make a spare set. It can be changed in five minutes.
A few guys do the bungee suspension, but some that have gone to all the trouble say its not worth the effort.
Hide Signatures
       Post #: 13
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 4:25 AM
roncannell
Score: 103
Status: offline
Manfred and Lothar say they are looking forward to having some WW1 company at the field.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 14
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 4:41 AM
roncannell
Score: 103
Status: offline
The optional Aluminium Cowl should add a little weight.
Hide Signatures
       Post #: 15
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 2:57 PM
SunDevilPilot
Score: 147
Status: offline
Here is what the gas motor installation would look like, simple with no issues to work around.....
What do you guys think?  Gas or Electric?  What would you rather see?
SunDevilPilot
Click for fullsize
Click for fullsize
< Message edited by SunDevilPilot -- 4/15/2012 8:12 PM >
SunDevilPilot
Hide Signatures
       Post #: 16
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 3:47 PM
soarrich
Score: 136
Status: offline
Gasser.
Rich Border AMA 77727
Sig Kadet Brotherhood #2
Hide Signatures
       Post #: 17
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 4:40 PM
WacoNut
Score: 175
Status: offline
I would go gas, with the G-26 side mounted carb you will not have the issue of recessing the firewall I had on the DRI. I am guessing you will still be mounting everything else up against the back of the firewall for balance.
I will be watching with interest.
Anthony
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
(in reply to soarrich)
       Post #: 18
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 8:19 PM
SunDevilPilot
Score: 147
Status: offline
So far that is two votes for gas....  I am starting to think the Zenoah is the right choice.
I just ordered a new backplate for my Zenoah because the one that is on the motor now was modified (Cut) to fit my Cub prior to changing that build into an electric.  The motor was never run on that model because I change to electric mid-build.
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to WacoNut)
       Post #: 19
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 8:28 PM
Edshepherd
Score: 100
Last Login: 3/24/2013
Status: offline
Gas for sure!!!!
Hide Signatures
       Post #: 20
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 8:45 PM
G8er
Score: 105
Last Login: 3/2/2013
Status: offline
if it were me choosing between gas or electric, I would go with gas.
Hide Signatures
(in reply to Edshepherd)
       Post #: 21
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 9:00 PM
jkpape
Score: 100
Status: offline
I think it needs one of these: 7 Cyl 77cc 4 Stroke Glow Radial Engine by Evolution Engines:-)
Hide Signatures
(in reply to G8er)
       Post #: 22
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 9:01 PM
Mako17
Score: 100
Last Login: 5/18/2013
Status: offline
Gasser
Richard
Hide Signatures
(in reply to G8er)
       Post #: 23
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 9:43 PM
SunDevilPilot
Score: 147
Status: offline
Looks like gas wins!!!
I'll go with the Zenoah G-26 (Electronic Ignition).
SunDevilPilot
SunDevilPilot
Hide Signatures
(in reply to Mako17)
       Post #: 24
RE: Balsa USA 1/4 Scale Nieuport 28 Build - 4/15/2012 10:15 PM
knucklebutt
Score: 100
Last Login: 5/22/2013
Status: offline
Shoot I know I'm late but my vote is certainly electric NOT !!!! some noise might be nice for this one
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
