motor wont throttle up    Gallery
Logged in as Guest
    Search This Thread
Printable Version
42% Radiocraft Extra 330 with DA 150 and mufflers - RTF
Seller:  hatstien
Details:   $1,750.00   |  5/8/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> motor wont throttle up
Page: [1]
Login
motor wont throttle up - 4/13/2012 8:07 PM
jeffk464
Last Login: 5/16/2013
Status: offline
I just put together the cmp katana SR plugged in the battery and for some reason the motor wont spool up. The servos all seem to work and the ESC is goes through its beeps and the motor pulses slightly with the beeps. I flipped the idle up and throttle hold switches on my futuba 6ex transmitter and run the throttle up and get nothing. Anyways I was hoping someone with more experience with electric RC can help out, I starting make the switch over from glow.
Does this particular esc need to be programmed, the last few I have used worked out of the box.
Hide Signatures
       Post #: 1
RE: motor wont throttle up - 4/13/2012 8:43 PM
cubaneight
Status: offline
It's possible that you need to reverse the throttle channel as Futaba's throttle signal works in reverse to most other makes. You'll also need to teach the ESC the max & min settings of the throttle channel (instructions?) Don't have a prop on the motor until you've sorted out the problem....safety first!!
Not sure why you are trying to use throttle hold and idle up with a fixed wing model as you'd be using aero mixing rather than heli.
Hope this helps.
C8
Hide Signatures
(in reply to jeffk464)
       Post #: 2
RE: motor wont throttle up - 4/13/2012 8:49 PM
BarracudaHockey
Last Login: 5/17/2013
Status: offline
Reverse the throttle channel.
CB the 6Ex has a built in throttle hold function for electrics so you don't chop your fingers off. Lots of folks do it with mixes but the 6ex has a built in one.
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to cubaneight)
       Post #: 3
RE: motor wont throttle up - 4/13/2012 9:02 PM
jw357_23043
Last Login: 1/5/2013
Status: offline
quote:
ORIGINAL: jeffk464
Is this an airplane we are talking about? If so why are you using the throttle hold? Check your endpoint adjustments. They should be set at 100% on low and high.
Hide Signatures
       Post #: 4
RE: motor wont throttle up - 4/13/2012 9:13 PM
jeffk464
Status: offline
quote:
ORIGINAL: cubaneight
Hope this helps.
C8
Ok the motor throttles up now but only when at about 3/4 throttle and then it spools up to full and isn't really adjustable. I guess I need to figure out how to teach the esc max and min without instructions.
Hide Signatures
       Post #: 5
RE: motor wont throttle up - 4/13/2012 9:19 PM
jeffk464
Status: offline
quote:
ORIGINAL: jeffk464
Hope this helps.
C8
Ok I got it setup works great thanks. Plug it in at full throttle wait for beeps, drop it to closed throttle and wait for beeps. CMP really needs to work on their manuals.
Hide Signatures
       Post #: 6
RE: motor wont throttle up - 4/14/2012 5:38 AM
allelectric
Last Login: 5/18/2013
Status: offline
Dido on cubaneight I have flown nothing but futaba and Electrics futaba MUST be reversed. (End points at 100% as said in other post)
Jeff
May All Your Landings Be Smoooooth!
Hide Signatures
       Post #: 7
RE: motor wont throttle up - 4/14/2012 4:34 PM
BarracudaHockey
Status: offline
Why use a feature that will keep you from accidently advancing the throttle on an armed ESC?
To keep you from bumping the throttle stick with the plane in your hand?
www.JaxRC.com
Hide Signatures
(in reply to allelectric)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
