SuperBee making backfire    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> Jet Central Turbines - Artes Jet >> SuperBee making backfire
Page: [1]
Login
SuperBee making backfire - 4/13/2012 11:06 PM
leopaul
Score: 100
Last Login: 5/19/2013
Status: offline
I started my engine that came back at 0hres from JC. It make a strange noise at idle, like backfire, or pouf.......pouf.pouf.............pouf.....................pouf.pouf.pouf...... I have never seen this before....At higher throttle, up to top rpm, it sound OK....
Do someone have an idea of what is going on??
Alex
< Message edited by leopaul -- 4/14/2012 12:13 AM >
_____________________________
Jetcentral Superbee, Rabbit, Cheetah
Wren 44 in my Bergen Magnum44
Hide Signatures
       Post #: 1
RE: SuperBee making backfire - 4/14/2012 4:13 AM
furycham
Score: 100
Last Login: 5/4/2013
Status: offline
Are you using fresh fuel? That symptom is very common when fuel has some water in it!
Vic
SM Viper 2M with JC Cheetah/SM F-86 with JC Rabbit 100
Hide Signatures
(in reply to leopaul)
       Post #: 2
RE: SuperBee making backfire - 4/14/2012 4:27 AM
leopaul
Score: 100
Status: offline
Well, this is the first time i heard this...I'm using last summer fuel (around 10l) mixed with a new 10l....
I will try this weekend with fresh fuel to see if there any improvements...
Hide Signatures
(in reply to furycham)
       Post #: 3
RE: SuperBee making backfire - 4/14/2012 2:50 PM
BluFox
Score: 100
Last Login: 5/7/2013
Status: offline
leopaul:
It is possible the fuel is contaminated with algae or similar. I remember a few years ago when flying with Todd (Dreamworks) everytime he started the take off roll, pop pop then flame out. Turned out to be bad fuel.
Also, we only require 2.5% oil ratio for mix. The Bee may be sensitive to 5% if this is what you are using.
You said it was recently serviced. Which of our facilities performed the service? Did you receive a document of what was done? Please let me know.
Eric
Managing Director
Hide Signatures
       Post #: 4
RE: SuperBee making backfire - 4/15/2012 9:05 PM
leopaul
Score: 100
Status: offline
Put fresh fuel today with precisely 2.5% dte light
Still backfire at idle....
Clogged injector will do something similar?
Hide Signatures
(in reply to BluFox)
       Post #: 5
RE: SuperBee making backfire - 4/16/2012 12:21 AM
Gonzalo38
Score: 100
Last Login: 5/18/2013
Status: offline
I used to have a Jetcentral Turboprop that is based on the same turbine. Mine did make the same noise at idle but it would stopped as soon as soon as I would move the throttle. The hotter the day, the more noise (if you could call it that way...) it would make. Don't recall having that noise on winter days.
My Gallery http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=314761
Hide Signatures
       Post #: 6
RE: SuperBee making backfire - 4/16/2012 12:27 AM
leopaul
Score: 100
Status: offline
That is true, as soon as i exceed around 100k , it doesn't make it anymore....
But the strange thing is that my other Bee or even all my others JC had never done that...??
Hide Signatures
(in reply to Gonzalo38)
       Post #: 7
RE: SuperBee making backfire - 4/20/2012 12:50 AM
leopaul
Score: 100
Status: offline
Someone else had another idea of what can cause the backfire??
Hide Signatures
       Post #: 8
RE: SuperBee making backfire - 7/23/2012 6:35 PM
leopaul
Score: 100
Status: offline
Engine is back to Mexico for analysis.
Will post update soon
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.219RCU1
