inverted 4 stroke    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> inverted 4 stroke
Page: [1]
Login
inverted 4 stroke - 4/14/2012 2:09 AM
iflircaircraft
Score: 123
Last Login: 6/11/2013
Status: offline
I'm building (assembling) a P51 Mustang. This is the first time I'll be installing an engine inverted (OS95v 4 Stroke). I have 20% nitro 18% synthetic fuel. Are there any tips to setting up an inverted installation?
Fuel tank level,fuel lines, etc
Tom
_____________________________
"Where there''s a WILL, There''s a WAY"
Hide Signatures
       Post #: 1
RE: inverted 4 stroke - 4/14/2012 2:37 AM
w8ye
Score: 318
Last Login: 6/19/2013
Status: offline
Keep the fuel tank as level with the needle valve as you can get it.
Have plenty of cooling
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to iflircaircraft)
       Post #: 2
RE: inverted 4 stroke - 4/14/2012 3:22 AM
earlwb
Score: 599
Status: offline
That is it, what w8eye said.
I also suggest when not at the flying field is to keep flip the plane inverted and keep the engine upright or pointed nose down. This is to prevent the oil from oozing into the combustion chamber and drowning out the glow plug, Which would cause the glow plug to fail the next time you go to start the engine.
The other trick is to be careful priming the 4 stroke engine when inverted as the fuel does not dribble out of the carb, so a big prime could cause hydraulic lockups or blow out the glow plug on you.
But other than that it is no big deal using them inverted.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: inverted 4 stroke - 4/14/2012 4:09 AM
SrTelemaster150
Score: 229
Status: offline
I have an FA 150 mouted inverted. I'm running C&H electronic ignition, but fouling the sparkplug is juat as much a concern as a glow plug.
I rotated the engine slightly to have the exhaust valve @ 6:00 o'clock when the plane is sitting level. W/the exhaust pipe running down out of the bottom of the cowl, any oil tends to collect @ the exhaust valve & it is expelled as soon as the engine is turned over.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to earlwb)
       Post #: 4
RE: inverted 4 stroke - 4/14/2012 3:27 PM
aguisribob@msn.com
Score: 105
Last Login: 6/17/2013
Status: offline
I have a P51 also and I'm using a Saito 56 inverted , never had a minutes trouble , as was said , just be careful not to over prime and flood the engine Fly and enjoy
BobA Saito club mem 705
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 5
RE: inverted 4 stroke - 4/14/2012 3:29 PM
earlwb
Score: 599
Status: offline
Here is a pic of my Frenzy 100 with a OS .91 inverted on it. Before I put the cowl on I was flight testing it and breaking in the engine good. I flew it like that for a year or so, then I converted it to electric instead. it needed a little more power, but I didn't have a Saito 1.25 at the time, but I did have a powerful big brushless motor though.
AMA # 928076
Hide Signatures
       Post #: 6
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> inverted 4 stroke
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
