servo dynamo effect/reverse voltage    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> servo dynamo effect/reverse voltage
Page: [1]
Login
servo dynamo effect/reverse voltage - 4/15/2012 9:33 AM
Countryboy
Score: 114
Last Login: 5/13/2013
Status: offline
Ran across a thread on another forum discussing servo dynamo effect, and the OP in that thread seems to think that a quick movement of an control surface created a reverse voltage spike...hence taking out his ECU. I see Emcotec makes a device to combat this phenomenon in the form of the DPSI OCP http://shop.rc-electronic.com/downloads/pdf/produktbeschreibungen/Flyer_OCP_EN.pdf
Curious about this, so I had a go at a little testing using an Hitec 5955 servo. Quick/rapid movements of the servo arm produced voltage readings approaching 1.9v or 1.18 amps . Wondering if this backfeed would take out an ECU or receiver.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: servo dynamo effect/reverse voltage - 4/15/2012 1:27 PM
Dr Honda
Score: 100
Last Login: 5/19/2013
Status: online
Are you pushing the servo? Also... there is a small ESC in the servo, so I'm not sure how the voltage would be coming back, since the transistors would be "open" when not in use.
Also... I seriously doubt 1.9v would cause any damage since the servo is connected to the Rx, and the feed voltage is 4.8v or higher.
Personally, the guys saying his ESC was damaged from servo back-feed is just reaching for straws.
Lastly... if the "Dynamo Effect" was a real issue... we would all know about it, since servo's aren't a new development in the RC word.
_____________________________
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to Countryboy)
       Post #: 2
RE: servo dynamo effect/reverse voltage - 4/15/2012 3:07 PM
HarryC
Score: 100
Last Login: 5/18/2013
Status: offline
According to some radio manufacturers the dynamo effect does exist but is only a potential problem under certain circumstances and the device you linked to at Emcotec is not the right one. Multiplex says it can only be a problem with certain high power servos when the battery is blocked from absorbing voltage spikes by diode battery backers
www.multiplex-rc.de/en/products/categories/products/details/productgroup/miscellaneous/productcategory/cockpit/product/peakfilter-1.html?tx_lwshopitems_pi1%5Baction%5D=show&tx_lwshopitems_pi1%5Bcontroller%5D=Product&cHash=3c348c3d59f829e2805c757e9973c3bf
http://shop.rc-electronic.com/e-vendo.php?shop=k_emcotec_e&SessionId=&a=article&ProdNr=A18000&t=6&c=67&p=67
Hide Signatures
(in reply to Dr Honda)
       Post #: 3
RE: servo dynamo effect/reverse voltage - 4/15/2012 3:13 PM
seflyer
Score: 105
Status: offline
one of my 40% planes exhibited this, when forceably moving one control surface one or more of the others would move towards an end of there travel. I would not be to concrened about it and find it highly unlikely that it did any damage to the ecu.
Kevin
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
