Max voltage for a Hitec servo    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> Max voltage for a Hitec servo
Page: [1]
Login
Max voltage for a Hitec servo - 4/15/2012 3:27 PM
mofosheee
Score: 100
Last Login: 3/26/2013
Status: offline
Dear Sirs:
My question regards the maximun voltage that a Hitec 7955TG servo (non high voltage) should be ran at. I'm am wondering if a Li-ion at 8 volts would be too much. Thanks in advance.
Jerry
Hide Signatures
       Post #: 1
RE: Max voltage for a Hitec servo - 4/15/2012 3:40 PM
ByLoudDesign
Score: 105
Last Login: 5/25/2013
Status: offline
You will run the risk of burning it up! That is a 33% increase over it's recommended operating voltage. Because the motor resistance remains constant the current drawn will mostly double. Not knowing the normal operating current makes it impossible to calculate. If you plane mean anything to you I wouldn't run the risk of having the servo fail!!!
_____________________________
Kits: F11C-2 1:4, Do-24T 1:8, P-3 1:10, Howard 500 1:5, XFY-1 1:4, SR-9 1:4, V-22 1/6, B-25J 1:4, F+W C3603 1:5
Hide Signatures
(in reply to mofosheee)
       Post #: 2
RE: Max voltage for a Hitec servo - 4/15/2012 4:23 PM
NikolayTT
Score: 100
Last Login: 5/23/2013
Status: offline
There are in general couple different ways to make this in a safe manner:
1. Use an effcient integrated DCDC Converter. Cost is about 10-15 USD per servo and
that leads people to abandon the use of old servos and purchase the new so called
'high-voltage' servos; many makers have them in the catalogs. This is indeed the best
especially if you are aiming at high speed servo performance, for example for F3A or
similar demands.
2. The cheapest what I use is on the attached file and it cost about 1-2 USD per servo
by using linear regulators '7806' and couple capacitors. It will take you couple hours to
solder those components. NOTE: There isn't any circuit here which checks now low the
voltage of the LiPo has gone; it is god t keep the LiPo aways charged and ballanced
so to void their damage ineed frm overdscarge.
BR, Nick
Click to see the file in new window.Attachment.pdf
Hide Signatures
       Post #: 3
RE: Max voltage for a Hitec servo - 4/15/2012 4:36 PM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
Or you could listen to the source... That would be Hitec..
and according to them, unregulated LiPo or LiIon (2S) is absolutely fine
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to NikolayTT)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
