Diesel    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Diesel
Page: [1] 2   next >   >>
Login
Diesel - 4/16/2012 5:05 PM
Couch Potato
Score: 105
Last Login: 5/15/2013
Status: offline
So what's going to happen to a Jetcat P-20 P-120, Munts K90 K140 or Wren SS turbines if I run them on diesel & 5% oil ?
Hide Signatures
       Post #: 1
RE: Diesel - 4/16/2012 5:13 PM
madmodelman
Score: 110
Last Login: 5/18/2013
Status: offline
They are gonna get a lot more expensive to run
_____________________________
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
(in reply to Couch Potato)
       Post #: 2
RE: Diesel - 4/16/2012 6:26 PM
bluescoobydoo
Score: 105
Status: offline
probably nothing, kero and diesel are not that different in fact some makes say you can run them on diesel, i wish they all did it finding fuel would be a lot easyer.
just not been brave enough to try it myself
I just ran out of talent !!!!!!!!
Hide Signatures
(in reply to madmodelman)
       Post #: 3
RE: Diesel - 4/16/2012 7:39 PM
Henke Torphammar
Score: 100
Status: offline
We are trying Diesel in alot of diffrent engines, they do run fine. K170 Kerostart works great, even the little Lambert Kolibri(9oz engine) runs perfect on Diesel. Only noticable diffrence is a bit of white smoke when shutting down.
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
(in reply to bluescoobydoo)
       Post #: 4
RE: Diesel - 4/16/2012 7:48 PM
Flynstuff
Score: 100
Status: offline
I can't speak for the other manufacturers, however lv been ruunning diesel in my K80 and k170 for well over a year with no issues.
I love it.
J. Tolomeo
KingTech-USA Rep & Team Pilot
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 5
RE: Diesel - 4/16/2012 10:50 PM
aquaskiman
Score: 100
Status: offline
I tried it in one of my Wren MKIII and it worked fine. I also run it in my Kingtech's.
George
Hide Signatures
(in reply to Flynstuff)
       Post #: 6
RE: Diesel - 4/17/2012 12:20 AM
Couch Potato
Score: 105
Status: offline
I might try it then.
Gary, I have 3 wheelie bins full of diesel !
Hide Signatures
(in reply to aquaskiman)
       Post #: 7
RE: Diesel - 4/17/2012 3:36 AM
ira d
Score: 123
Status: offline
I see no reason why any model turbine wont run on diesel the $64,000 question is what is the long term effect on running diesel in a engine not made to do so. Just
to be clear i'm not refering to Kingtech because they are made to run diesel.
< Message edited by ira d -- 4/17/2012 6:09 AM >
Ira d
Hide Signatures
       Post #: 8
RE: Diesel - 4/17/2012 8:37 AM
Rush!
Score: 100
Status: offline
I tried bio diesel and wasnt really happy with it.  Diesel also makes a stickier mess than Kero/JetA when spilled.
Anyone else tried biodiesel?
Hide Signatures
(in reply to ira d)
       Post #: 9
RE: Diesel - 4/17/2012 8:46 AM
madmodelman
Score: 110
Status: offline
I suspected that mate! wasn't sure about the colour though.
I take it your car runs on gas.
Hide Signatures
       Post #: 10
RE: Diesel - 4/17/2012 10:49 AM
Dave Wilshere
Score: 108
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: Couch Potato
They will all run rough! The P-20 will be the worst, will also run for least amount of time before the sooty Diesel cloggs the tiny needles with carbon deposits, the pump Diesel also has other additives for car use...JetCat for sure will offer no warrantee...
The combustion chamber needs to be re designed, fuel needles filters all need changes.
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
       Post #: 11
RE: Diesel - 4/17/2012 10:59 AM
aquaskiman
Score: 100
Status: offline
My Wren ran perfect at 5448 ft with Diesel. I can fix it my self if needed, but I think it will be ok with the ULS Diesel in the states.
George
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 12
RE: Diesel - 4/17/2012 4:13 PM
FalconWings
Score: 121
Status: offline
quote:
ORIGINAL: Dave Wilshere
Then Jetcat needs to do just that. No big deal. Keep up to date.
David.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 13
RE: Diesel - 4/17/2012 4:51 PM
Dave Wilshere
Score: 108
Status: offline
Nope Diesel is $9.24 a US (3.9ltr) Gallon....
Highest grade Parafin, no smell or mess is cheaper...
Hide Signatures
(in reply to FalconWings)
       Post #: 14
RE: Diesel - 4/17/2012 4:58 PM
Henke Torphammar
Score: 100
Status: offline
But you only need half the oil, if any in Diesel...
/Henke
Hide Signatures
       Post #: 15
RE: Diesel - 4/17/2012 5:31 PM
Dave Wilshere
Score: 108
Status: offline
I won't run Jet1A because of the smell...Diesel..Urgh. Plus the black cr**p coming out of buses and lorries would be great
Not for me...
Hide Signatures
       Post #: 16
RE: Diesel - 4/17/2012 5:38 PM
Robrow
Score: 100
Status: offline
I'm with you Dave, although we can run multi fuel if required in full size military aviation it's not the fuel of choice.
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
       Post #: 17
RE: Diesel - 4/17/2012 8:08 PM
ira d
Score: 123
Status: offline
From what I hear most engines run diesel just fine not rough at all but it's the long term use and how it will effect relaiblty that is the concern.
Ira d
Hide Signatures
       Post #: 18
RE: Diesel - 4/17/2012 11:23 PM
marquisvns
Score: 115
Status: offline
quote:
ORIGINAL: ira d
There's no reliability nor long term effect to be concern about with KingTech turbines running on Diesel. Today's Ultra Low Sulpher pump Diesel we have around the corner is a fantastic alternative fuel for our engines other than Kerosene, in fact, Diesel mixed with 3 to 5% oil is all we use.
Barry
www.kingtechturbines.com
kingtechturbines@gmail.com
Hide Signatures
(in reply to ira d)
       Post #: 19
RE: Diesel - 4/18/2012 12:38 AM
ChrisPetersen
Score: 115
Status: offline
Personally, I grew up on a farm and the last thing I want my jets to smell like is a John Deere! Lol
Hide Signatures
(in reply to marquisvns)
       Post #: 20
RE: Diesel - 4/18/2012 1:13 AM
marquisvns
Score: 115
Status: offline
For me, there's a major difference between a piston driven John Deer burning Diesel versus turbine burning Diesel.
However, sense of smell is highly subjective, and personally I think Jet A is of all.
Hide Signatures
(in reply to ChrisPetersen)
       Post #: 21
RE: Diesel - 4/18/2012 4:28 AM
ira d
Score: 123
Status: offline
quote:
ORIGINAL: marquisvns
quote:
ORIGINAL: ira d
Barry
Barry please read post #8 in this discussion. So far no one has said anything negtive about Kingtech or their ability to run diesel.
Ira d
Hide Signatures
       Post #: 22
RE: Diesel - 4/18/2012 6:53 AM
marquisvns
Score: 115
Status: offline
No worries and thank you Ira d, I only thought it was appropriate to express that there's no concerns with KingTech on this subject is all.
Hide Signatures
(in reply to ira d)
       Post #: 23
RE: Diesel - 4/18/2012 9:31 AM
highhorse
Score: 116
Status: offline
I don't remember what Europe's standards are, but diesel is NOT "dirtier" than Kero here in the US. It is, in fact, cleaner.
RCU Rocks, I''d hate to be without it !!
Hide Signatures
       Post #: 24
RE: Diesel - 4/18/2012 10:52 AM
grbaker
Score: 115
Status: offline
Guys out at the field are always very surprised when I tell them that have been burning diesel for a year and a half. My jets don't smell any different than the other guys using kero.
There is a big difference between the diesel of several years ago and the low sulfur diesel at the pumps today (at least here in the US)
Gary Baker
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
