hobby king orange receivers    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,999.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> hobby king orange receivers
Page: [1]
Login
hobby king orange receivers - 4/17/2012 3:12 AM
muskyman64
Score: 100
Last Login: 4/20/2012
Status: offline
i have a few of these for my super 8 (15) and have read many good reports, i programmed 1 plane and then used the copy function to start changing out my receivers (had jr spectrum previously) and bound each plane one at a time and set them up.
to my surprise i accidently left one of the other planes on and found out that my transmittter was controlling both planes at the same time, i started turning on all the other planes and they were all operating at the same time. what am i doing wrong????
Hide Signatures
       Post #: 1
RE: hobby king orange receivers - 4/17/2012 3:22 AM
heinzulrich
Score: 105
Last Login: 5/15/2013
Status: offline
 curious, have you got a Futaba
Hide Signatures
(in reply to muskyman64)
       Post #: 2
RE: hobby king orange receivers - 4/17/2012 3:27 AM
ElectricFlyGuy
Score: 100
Status: offline
If I am not mistaken, your radio is unique to that receiver. I do not think that your radio randomly picks a new wave/ch. for a receiver. I do believe that all of our recievers will be unique to our particular radios BUT>>>> NOT anyone elses radio can interfer with our programmed receiver 'married' to our radios. I have the Spectrum DX5e and I also program the ORANGE HK receivers to it. Remember you can only fly one plane at a time BUT, no other radio can mess with a reciever that you programmed with your 2.4 gig system. This is from reports I have been told and from my own experience. Downside is, you cannot loan a friend one of your planes to go fly with you. HE would need your radio to do so with that orange receiver. I am curious as to other responses because what you describe is the same with me. Thanx for bringing this up. I guess we would never have know, had we shut off our othe planes. Scott V.
Hide Signatures
       Post #: 3
RE: hobby king orange receivers - 4/17/2012 6:48 AM
electricpete
Score: 100
Last Login: 5/5/2013
Status: offline
I sometimes leave model switched on at a flying session, in one case the rx is under a damaged canopy which is cellotaped secure, so would be difficult to remove after each flight.
Peter
Hide Signatures
(in reply to ElectricFlyGuy)
       Post #: 4
RE: hobby king orange receivers - 4/17/2012 10:21 PM
AirTech
Score: 100
Last Login: 5/19/2013
Status: offline
Obviously if you "bind" all these receivers to the same transmitter, all these receivers will operate simultaneously when they are all on at the same time. That's completely normal; since your transmitter is the only one "bound" to those receivers no other transmitter will interfere with your receivers. Now you must be very careful to make sure you choose the correct matching model program from your transmitter because these receivers don't care which model is running.
Hide Signatures
(in reply to electricpete)
       Post #: 5
RE: hobby king orange receivers - 4/18/2012 6:27 PM
Slow and Steady
Score: 105
Last Login: 5/18/2013
Status: offline
Spectrum has model match, meaning the transmitter has to have the correct model selected to control each plane. Futaba doesn't, as you have witnessed. Still prefer Futaba, but thats just personal preference.
Hide Signatures
(in reply to AirTech)
       Post #: 6
RE: hobby king orange receivers - 4/18/2012 9:30 PM
Rafael23cc
Score: 122
Last Login: 5/17/2013
Status: offline
So ALL you guys are expecting a JR /Spectrum function to work with a Hobby King CLONE receiver? Where did you get that idea?
The OP did not say which radio is being used. Model Match only works with radios that DO NOT utilize a module, so if the radio uses a module, you cannot rely on the model match feature to "save" your model. But then again it is pointless to discuss this as we are talking about a CLONE receiver and I would not expect this feature to work here.
Rafael
_____________________________
Keep your eyes on the sky but your feet on the ground!
Team Heliproz.com / AMA # 8109
Hide Signatures
(in reply to Slow and Steady)
       Post #: 7
RE: hobby king orange receivers - 4/18/2012 10:05 PM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: Rafael23cc
The OP did not say which radio is being used. Model Match only works with radios that DO NOT utilize a module, so if the radio uses a module, you cannot rely on the model match feature to ''save'' your model. But then again it is pointless to discuss this as we are talking about a CLONE receiver and I would not expect this feature to work here.
Rafael
I have not used any of the Hobby King Orange receivers. Since Spektrum first offered the 2.4 Module for my XP9303, I have been using JR/Spektrum 2.4 receivers. As such, I have not been able to take advantage of Model Match. There was a version of the JR 12X that was Modular and was compatible with Model Match, but that was discontinued after a year.
I was under the impression that JR/Spektrum transmitters that supported Model Match would support Model Match with any JR/Spektrum receiver. I had not heard that the Orange receivers were an exception. Are you sure that Model Match does not work with the Orange receivers?
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Rafael23cc)
       Post #: 8
RE: hobby king orange receivers - 4/19/2012 2:28 AM
AirTech
Score: 100
Status: offline
quote:
ORIGINAL: BuschBarber
Rafael
I don't know if the model match function works with Spektrum transmitters and Orange receivers, but that's a non issue for me. As I said if you are careful and make sure you have the correct model in your transmitter you will not have any problems.
The fact that Orange receivers are CLONES is not an issue either. Some "ground tests" conducted with Orange receivers show that compared with Spektrum receivers the Orange receivers have less range (1056ft versus 792ft). In any case the range of the Orange receivers is more than adequate for any type of sport flying since at 790ft a 30% model is quite a small spec beyond human eyesight. With a difference in cost of about 400% I'll take the "CLONES" anytime. Note that Horizon have lowered the cost of the Spektrum Carbon Fuse 9 channel DSM2 receivers from $219.99 to $99.99 to keep up with the competition.
Hide Signatures
(in reply to BuschBarber)
       Post #: 9
RE: hobby king orange receivers - 4/19/2012 3:17 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: AirTech
Rafael
The fact that Orange receivers are CLONES is not an issue either. Some ''ground tests'' conducted with Orange receivers show that compared with Spektrum receivers the Orange receivers have less range (1056ft versus 792ft). In any case the range of the Orange receivers is more than adequate for any type of sport flying since at 790ft a 30% model is quite a small spec beyond human eyesight. With a difference in cost of about 400% I'll take the ''CLONES'' anytime. Note that Horizon have lowered the cost of the Spektrum Carbon Fuse 9 channel DSM2 receivers from $219.99 to $99.99 to keep up with the competition.
I have a DX8 now, as well as the 9303's. The DX8 has Model Match. In 34 years of RC, I have not had Model Match in any transmitter, until now. I think I only lost one foamie because I forgot to change the Model Memory and if I wasn't in a hurry and checked the controls, I would have known I had the wrong Model Memory. Still it could have been a $5000 aircraft in a pile. Model Match is a good thing.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 10
RE: hobby king orange receivers - 4/19/2012 9:26 AM
electricpete
Score: 100
Status: offline
quote:
ORIGINAL: AirTech
Rafael
I don't know were the carbon safe 9channel rxs (Ar9310)are $99 dollars they are still 159 on the horizon site
Hide Signatures
       Post #: 11
RE: hobby king orange receivers - 4/19/2012 2:46 PM
AirTech
Score: 100
Status: offline
I agree, Model Match is a good thing but I'm not going to miss it if I don't have it. BTW I will not mount an Orange receiver in a $3000 plane, might as well invest a couple of hundred dollars in a power safe receiver system.
See this LINK for the Spektrum Carbon Safe 9 channel DSM receiver.
Hide Signatures
       Post #: 12
RE: hobby king orange receivers - 4/19/2012 2:52 PM
Rafael23cc
Score: 122
Status: offline
It seem like the thread is deviating from its subject because some people are not understanding the problem... Let me put it back on track.
I am too under that impression. JR/Spektrum working with JR/Spektrum. My question is why are we expecting a CLONE to work with JR/Spektrum?
Since my 2.4 radios are module based, Obviously I do not have the means of testing if it works or not. I'm just not expecting it to work by the reasoning of being a CLONE. I do not see why this is hard to comprehend.
The Oragne receivers have their place in the market. I own a couple of them. They are isntalled in indoor, slow, light models.
If it works, it is the icing on the cake, if it does not (which seems to be the case) then I did not expect it anyway so I'm not surprised.
Rafael
Hide Signatures
       Post #: 13
RE: hobby king orange receivers - 4/19/2012 3:04 PM
BuschBarber
Score: 104
Status: offline
If it works it is the icing on the cake, if it does not (which seems to be the case) then I did not expect it anyway so I'm not surprised.
Rafael
Since a Clone is not supported by JR/Spektrum, I would not expect any guarantees that it would work at all. Some people are willing to take the risk and save some money. I have not done that. Reports are that these Orange Clones have been working reliably.
I would think that if they work at all, Model Match still works, as well, but I have not received confirmation on that. It would be easy to test. Bind one to Model Memory 1, switch to Model Memory 2, and see if it works.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 14
RE: hobby king orange receivers - 4/19/2012 3:09 PM
AirTech
Score: 100
Status: offline
Rafael
Raf I don't see why not. These clones support all the functions of Futaba FASST transmitters, they may as well work the same with Spektrum. The problem is that JR doesn't support most of Spektrum options. That's why JR non-module transmitters aren't fully compatible with new DSM2 systems. I have a 9303 with a 2.4 Spektrum module which works fine with JR, Spektrum and Orange receivers but doesn't support Model Match or Range Check audio alarm functions. On the other hand Orange receivers support both of these options when you use a Spektrum transmitter.
Hide Signatures
       Post #: 15
RE: hobby king orange receivers - 4/19/2012 8:27 PM
Slow and Steady
Score: 105
Status: offline
Just to clarify, I looked at the orange receiver offered for Futaba transmitters and noted that it said it did not provide a fail safe mode. While they are not identical to the brand name receiver, they are likley alright for smaller, less expensive planes - though fail safe to me is necessary before I would buy it. My Futaba 2.4 receivers have lasted along time, none having failed yet, and the savings is not that great considering the life of the Futaba product.
Hide Signatures
       Post #: 16
RE: hobby king orange receivers - 4/19/2012 8:50 PM
AirTech
Score: 100
Status: offline
quote:
ORIGINAL: Slow and Steady
I stand corrected........I'm not too familiar with the new Futaba stuff. I did view a video test from on YouTube [LINK HERE] that seems like most Futabe functions works OK.
Hide Signatures
       Post #: 17
RE: hobby king orange receivers - 4/19/2012 8:52 PM
Slow and Steady
Score: 105
Status: offline
It was a while ago and they may now have fail safe. Just thought I would put it out there if anyone is interested.
Hide Signatures
       Post #: 18
RE: hobby king orange receivers - 4/19/2012 9:09 PM
AirTech
Score: 100
Status: offline
By the way I just viewed these video [LINK HERE]comparing Brown Out levels for the 6 channel Orange receiver, the Spektrum AR6210, and a legacy 2.4 receiver from HobbyKing and I was quite surprised.
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
