rcexl tach for troubleshooting    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> rcexl tach for troubleshooting
Page: [1] 2   next >   >>
Login
rcexl tach for troubleshooting - 4/19/2012 4:48 AM
72
Score: 100
Last Login: 5/16/2013
Status: offline
I was reading an airplane review in one of the magazines and one of the pics showed an rcexl tach with a caption that said it could be used to troubleshoot ignition problems. Anyone know how?
Click to see fullsize image.
Click for fullsize
_____________________________
Club Saito #614/Ultimate Brotherhood #57
Ultra Sport Brotherhood #34
Hide Signatures
       Post #: 1
RE: rcexl tach for troubleshooting - 4/19/2012 5:39 AM
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
If it doesn't show somewhere between 1500 and 10,000 rpms, your engine is not running and you should investigate why.
Sorry, couldn't resist!
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to 72)
       Post #: 2
RE: rcexl tach for troubleshooting - 4/19/2012 1:02 PM
pe reivers
Score: 646
Last Login: 5/20/2013
Status: online
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to av8tor1977)
       Post #: 3
RE: rcexl tach for troubleshooting - 4/19/2012 1:46 PM
RCVFR
Score: 141
Status: offline
Maybe the one who made the statement knows how?
Sometimes, things are exactly as they appear to be.
Hide Signatures
(in reply to 72)
       Post #: 4
RE: rcexl tach for troubleshooting - 4/19/2012 3:16 PM
72
Score: 100
Status: offline
Can't locate him.
Hide Signatures
(in reply to RCVFR)
       Post #: 5
RE: rcexl tach for troubleshooting - 4/19/2012 3:36 PM
Turk1
Score: 108
Status: offline
My short experience, that tach doesnt work smooth. Sometimes displays for several seconds then goes crazy.Then begins to display again then goes mad.I dont know what all those means but you need luck to be able to catch the RPM when you throw a look at it.
Hide Signatures
(in reply to 72)
       Post #: 6
RE: rcexl tach for troubleshooting - 4/19/2012 3:37 PM
pe reivers
Score: 646
Status: online
replace it.
Hide Signatures
(in reply to Turk1)
       Post #: 7
RE: rcexl tach for troubleshooting - 4/19/2012 5:34 PM
dirtybird
Score: 173
Status: offline
The one I have works OK but you need to be in a dark room to read it.
Hide Signatures
(in reply to pe reivers)
       Post #: 8
RE: rcexl tach for troubleshooting - 4/19/2012 6:31 PM
pe reivers
Score: 646
Status: online
Since you spent a fortune on it, send it back for warranty.
Hide Signatures
(in reply to dirtybird)
       Post #: 9
RE: rcexl tach for troubleshooting - 4/19/2012 8:44 PM
Turk1
Score: 108
Status: offline
Send which one?RCEXL unit or tach?I will try to test some others from friends.
Hide Signatures
       Post #: 10
RE: rcexl tach for troubleshooting - 4/19/2012 11:01 PM  1 votes
pe reivers
Score: 646
Status: online
Turk1,
Try a tach from your friends and see if it's better or the cause is in your setup, then talk to the seller of the device about what to do. If the engine runs fine the Ignition seems OK.
Hide Signatures
(in reply to Turk1)
       Post #: 11
RE: rcexl tach for troubleshooting - 4/20/2012 12:06 AM
rexbirk
Score: 105
Last Login: 5/18/2013
Status: offline
RcExcel makes an ignition tester. I have used it and it seems to work.
Is being a Circle Flyer a bad thing?
Rex Birkinbine
Hide Signatures
       Post #: 12
RE: rcexl tach for troubleshooting - 4/20/2012 12:07 AM
earlwb
Score: 584
Status: online
About all one can do is use it to monitor the engine RPMs and if the RPMs change noticeably from what they have been showing, then you have a problem of some sort. Such as the engine was always turning 6,800 RPMs and now it suddenly only turns 5,200 RPMs, then what happened or changed just then?
Now with electronic tachs hooked up to a engine. I have noticed on some motorcycle or scooter engines, that when the tach starts behaving weird and displaying odd RPMs as you are riding along, that the spark plug boot or cable has come loose or worse the ignition coil is going bad. What happens with the modern engines is they use something like a COP system (coil on plug) for the ignition. This entails using a really small ignition coil and running a higher voltage through the primary windings to generate the high voltage to fire the spark on the spark plug. Something like 80 volts or more us used on these things to drive the coil with. The higher the coil drive voltage the smaller you can make the coil. Now the coil doesn't have to be placed on the spark plug, it can be separate too. But the same methods apply.
What happens with the lower voltage COP systems, say using 80 volts or so, is when the spark plug boot comes loose or something, the spark gap increases a lot, causing the high voltage side of the coil to generate a huge voltage increase of a 100,000 volts or more. That causes the insulation on the secondary wire windings inside the coil to break down and short out. But it tends to be a delayed action with the lower voltage systems, so it is later before the coil goes bad as the windings short out more and more, even after you put the cable back on tight. With the higher voltage systems the coil burns out almost instantly. I remember BMW manuals stating to never pull a spark plug unit off the engine while it is running, or it will kill it immediately.
So anyway if the tach is any good and seems to be working OK, and then it suddenly goes bonkers you want to check your wire connections closely for loose ones. Hopefully it is the tach unit going bad instead.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 13
RE: rcexl tach for troubleshooting - 4/20/2012 3:03 AM
72
Score: 100
Status: offline
quote:
ORIGINAL: earlwb
Thanks Earl, that pretty much answers what I was looking for. My engine was running fairly well on the stand but before I could tune it to the point where I was going to fly it, started
running erratic like the needles had changed, wouldn't accelerate properly, sounded like it was missing. This was without changing any settings, just doing it on it's own. The tach was indicating what seemed like proper rpm, but would cut out to zero intermittently and then back to normal. I will try a new ignition and see if that is it.
Hide Signatures
(in reply to earlwb)
       Post #: 14
RE: rcexl tach for troubleshooting - 4/20/2012 3:19 AM
OliverJacob
Score: 110
Status: offline
I have one like that. Very useful to tune your engine. As far as troubleshooting goes - not so much.
The only thing I can think of is that you can test your ignition sensor, when you turn the prop you should get some reaction on the display.
Hide Signatures
(in reply to 72)
       Post #: 15
RE: rcexl tach for troubleshooting - 4/20/2012 2:18 PM  1 votes
pe reivers
Score: 646
Status: online
If the tach shows it, it probably is just the hall sensor. The tach is completely driven off the hall signal.
See the post of JediJodi on RCexl testing in the sticky gas beginners thread. I believe post #29. I also linked to it from my web page.
Hide Signatures
(in reply to OliverJacob)
       Post #: 16
RE: rcexl tach for troubleshooting - 4/25/2012 12:07 PM  1 votes
pe reivers
Score: 646
Status: online
Here is a quote from the tachometer manual indicating the other check function:
If there is interference from the ignition system, tachometer displays 0 or arbitrary values, this can be check for ignition system RFI
Hide Signatures
       Post #: 17
RE: rcexl tach for troubleshooting - 4/25/2012 1:41 PM
72
Score: 100
Status: offline
That is what I was looking for, but I have not been able to locate a manual for it. Thanks.
quote:
ORIGINAL: pe reivers
Hide Signatures
       Post #: 18
RE: rcexl tach for troubleshooting - 4/25/2012 4:10 PM  1 votes
pe reivers
Score: 646
Status: online
It's included with every new tachometer!
Click for fullsize
Hide Signatures
(in reply to 72)
       Post #: 19
RE: rcexl tach for troubleshooting - 4/25/2012 4:29 PM
Turk1
Score: 108
Status: offline
Thank you Pe,great info.
Hide Signatures
       Post #: 20
RE: rcexl tach for troubleshooting - 4/25/2012 5:08 PM
72
Score: 100
Status: offline
I must have bought the discount version because mine didn't have instructions! Thanks for posting this. I have printed them out.
Hide Signatures
       Post #: 21
RE: rcexl tach for troubleshooting - 4/25/2012 5:15 PM
pe reivers
Score: 646
Status: online
or you bought a cheap copy.
Hide Signatures
(in reply to 72)
       Post #: 22
RE: rcexl tach for troubleshooting - 11/4/2012 9:29 AM
gadix
Score: 100
Status: offline
Gents
i have the newest version V2.1
when the Tach is connected i get NO SPARK at all!!!
but i do see some readings on the display as i rotate the shaft over the the hall sensor few times...
when i disconnect the Tach from the Y connector , i get a spark again...
any ideas??
thx in advance
GADI,
ISRAEL
Hide Signatures
       Post #: 23
RE: rcexl tach for troubleshooting - 11/4/2012 7:58 PM
pe reivers
Score: 646
Status: online
Get a new tach.
Hide Signatures
(in reply to gadix)
       Post #: 24
RE: rcexl tach for troubleshooting - 11/5/2012 10:48 AM
gadix
Score: 100
Status: offline
just got a nice email from the HK seller that he will mail me a new TACH
GADI,
ISRAEL
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> rcexl tach for troubleshooting
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.580RCU1
