Kit for twin Saito 62's?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Kit for twin Saito 62's?
Page: [1]
Login
Kit for twin Saito 62's? - 4/19/2012 9:31 PM
Rv7garage
Score: 128
Last Login: 4/26/2013
Status: offline
Howdy folks. Is there a kit out there that would lend itself to twin Saito 62's? I already have the engines, have built several kits, but have yet to tackle a twin. My building and flying skills are good. Let me know what you think? Thanks!
_____________________________
#26 Club Saito ***CUB BROTHERHOOD*** #86
My full-scale build: www.rv7garage.blogspot.com
Hide Signatures
       Post #: 1
RE: Kit for twin Saito 62's? - 4/19/2012 9:41 PM
korvette
Score: 100
Last Login: 5/17/2013
Status: offline
  Hi,
I have the same engines...and just bought a Hangar 9 twin otter....great looking plane...
You have to make some small modifications to make the engines fit...
Look here for more info.
http://www.rcuniverse.com/forum/m_10591608/tm.htm
Kor
Hide Signatures
(in reply to Rv7garage)
       Post #: 2
RE: Kit for twin Saito 62's? - 4/19/2012 9:46 PM
fledermaus
Score: 105
Last Login: 3/4/2013
Status: offline
The Twotter from H9 is a great plane, but I don't think it would benefit from the bigger engines. It flies in a beautiful scale fashion with the EVO 36 2-strokes that are recommended. If you have to mess up the cowlings just to stuff in bigger engines it seems a waste. People have put in smaller 4-strokes but I don't see the point in over-powering this bird.
Hide Signatures
(in reply to korvette)
       Post #: 3
RE: Kit for twin Saito 62's? - 4/20/2012 12:59 AM
R8893
Score: 100
Last Login: 5/19/2013
Status: offline
My first twin was a "bash" of the old Midwest Strikemaster to a twin after having flown it for a long time as a single. Cut the wing in half, added a foot of 16" of new center section and nacelles. Two Super Tigre .35's. Flew great. Next was a Super Kaos modified similarly with 2 .46's. Then a Direct Connection Sea Fury with 2 OS .52 4 stokes that looks like a Russian WWII dive bomber. If you like aerobatics you could do the same with a Dirty Birdy kit from Bluejay models. Picture of the bashed Kaos and Sea Fury flying together.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to fledermaus)
       Post #: 4
RE: Kit for twin Saito 62's? - 4/20/2012 4:56 PM
korvette
Score: 100
Status: offline
 Piper twin comanche from topp is also a good idea...
https://ssl-id.de/rc-tronics-topp-rippin.de/Shop/product_info.php?products_id=158&osCsid=553ehcjndujarsn1b7g9tn1j30
@fledermaus. ( bat.  :-)   ...the 4 strokes in the twin otter are great...the sound of 2 four strokes is so much better than the 2 strokes.
The .62 saito fits inside the cowlings...no problem...and they don't have to run at full power...just half throttle and it flies  just fine. The fuel consumption is also very low...so you fly longer, and with better/less noise as with the 2strokes. :-)
< Message edited by korvette -- 4/20/2012 5:58 PM >
Hide Signatures
(in reply to R8893)
       Post #: 5
RE: Kit for twin Saito 62's? - 4/22/2012 2:02 AM
fledermaus
Score: 105
Status: offline
@korvette - fair enough as long as the 0.62s fit in the cowl. I had the 2-strokes sitting in the shop when I did my Twotter, so I stayed with them. No argument about the sound.
Hide Signatures
       Post #: 6
RE: Kit for twin Saito 62's? - 4/22/2012 6:52 AM
P-Y
Score: 105
Last Login: 5/16/2013
Status: offline
Are you looking for an ARF or a kit to build ?
Hobbistar 60 / SIG SE (†) / TF Cessna 310 / OMP ProYak / TF Spitfire MKIX (†) / Parkzone Radian / Royal C-47
Hide Signatures
       Post #: 7
RE: Kit for twin Saito 62's? - 4/23/2012 12:30 AM
Rv7garage
Score: 128
Status: offline
Would prefer a kit, definitely. I was thinking the Top Flite DC-3, but would love to hear suggestions for kits that might be a little more rare. Thanks for the input so far guys, keep it coming! Any good KITS out there for two homeless Saito 62's?
Hide Signatures
(in reply to P-Y)
       Post #: 8
RE: Kit for twin Saito 62's? - 4/23/2012 3:57 PM
P-Y
Score: 105
Status: offline
So far, the only twin kits I've found are for bigger engines except the TF DC-3 and the Royal C-47 which is almost the same plane than the TF DC3 (btw they recommend two .40 to .52 cu. in. 4-stroke for the DC-3).
It looks like there's many ARF and only few kits on the market. I hope someone will be able to provide you a better choice.
Hide Signatures
       Post #: 9
RE: Kit for twin Saito 62's? - 4/25/2012 9:14 PM
kthmarks
Score: 100
Last Login: 5/9/2013
Status: offline
*** Edit: just saw korvette's post with the link.....Sorry for the duplication
I took the twin otter and reworked it to suit my own taste. I striped the covering, glassed and painted it and converted it from A DHC6-300 to a -100 (1966 snub nose). The model came in just under 15lbs (+/- 3lbs over the standard arf) The FA62's are a perfect match for the heavier airframe. Although, I had to do quite a bit of rework to the nacelles to fit them in.
A short video.....it was getting late so the quality isn't great.
http://youtu.be/kdffK5v5fJM
PS....The TF DC3 is on my list as well.
Click for fullsize
Keith Marks
AMA 49064
Hide Signatures
(in reply to P-Y)
       Post #: 10
RE: Kit for twin Saito 62's? - 4/27/2012 6:45 PM
SIMCO
Score: 100
Last Login: 5/13/2013
Status: offline
How about a duallist that's on AD pages right now. Will fly fine on 62's
Hide Signatures
(in reply to kthmarks)
       Post #: 11
RE: Kit for twin Saito 62's? - 4/27/2012 6:53 PM
SIMCO
Score: 100
Status: offline
Duallist again-here's your retracts http://www.robart.com/air-models/duelist from Robart It's a sanding kit i will admit,However a real go getter. lot's of threads to build from.
Hide Signatures
(in reply to SIMCO)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
