Will the Eclipse 7 work with my dragonfly?
Tower Hobbies
Logged in as Guest
  Printable Version
Ikarus ECO 8 - EP - ARF
Seller:  gilweiss
Details:   $450.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Will the Eclipse 7 work with my dragonfly?
Page: [1]
Login
Will the Eclipse 7 work with my dragonfly? - 8/31/2003 11:38:55 PM
mikefoy6
Status: offline
hi all
i recently got an eclipe 7 for my piccolo pro and i was wondering if can work with my feda dragonfly. Also, if it will work, can some one tell me how to set the tx up.
thanks
mike
       Post #: 1
Will the Eclipse 7 work with my dragonfly? - 9/1/2003 5:44:11 AM
astronut30
Status: offline
yes it'll work...
just set the throttle trim linear... 0-25-50-75-100
if you have a hh gyro or a mixing board just set revo mixing to zero, that's about it pretty basic and straight forward.
Of course make sure the swash setting is for normal..
_____________________________
--aloha-- Chad
(in reply to mikefoy6)
       Post #: 2
Will the Eclipse 7 work with my dragonfly? - 9/1/2003 9:02:38 PM
mikefoy6
Status: offline
thanks for the quick reply
but my problem is setting up the tx so that the rx will recieve it. i have the spectra model for the eclipse so i know it is not a problem with the crystals. i dont know how to make the tx and rx work together.
mike
       Post #: 3
Will the Eclipse 7 work with my dragonfly? - 9/2/2003 1:24:53 AM
astronut30
Status: offline
Well, just make sure it's a 72mhz receiver and that it's negative shift. From there all you have to do is dial in on the crystal channel the receiver's on.
--aloha-- Chad
       Post #: 4
Will the Eclipse 7 work with my dragonfly? - 9/2/2003 1:46:36 AM
mikefoy6
Status: offline
i did every thing you said and it is still not working. i have the latest model of the eclipse 7 and it has 2 modes, ppm or qpcm. could this be the problem? my original tx was just pcm not qpcm. any help is appreciated
mike
       Post #: 5
Will the Eclipse 7 work with my dragonfly? - 9/2/2003 2:04:24 AM
astronut30
Status: offline
You're using the stock Feda receiver?? If so, I don't think it's pcm, try putting your radio in ppm mode...
--aloha-- Chad
       Post #: 6
Will the Eclipse 7 work with my dragonfly? - 9/2/2003 6:13:42 AM
jeffs555
Status: offline
If your original dragonfly transmitter was PCM then you are probably out of luck. PCM is different from manufacturer to manufacturer, so with PCM, the transmitter and receiver generally have to be from the same manufacturer. The Hitec PCM probably won't work with the drgonfly receiver. If your dragonfly has a separate receiver, you could replace just that, but if it has an all in one board, you would have to replace everything.
Jeff
       Post #: 7
Will the Eclipse 7 work with my dragonfly? - 9/2/2003 4:52:56 PM
mikefoy6
Status: offline
Ok that makes sense then. i wasn't working in either pcm or ppm modes.
thanks a lot for the info
mike
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
