RE: The Official Thunder Tiger MT4 G3 thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Slash 4x4 roller with TQ 2.4GHz Traxxas Link - Kit
Seller:  Callifas38
Details:   $150.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> RE: The Official Thunder Tiger MT4 G3 thread
Page: <<   < prev  1 2 3 4 5 6 [7] 8 9 10   next >   >>
Login
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 8:24 AM
Foxy
Score: 2012
Last Login: 5/26/2013
Status: offline
German guy may be right, there are quite a few ESCs which don't like 5S. If you have the option to specify total voltage to cut off, simply set it at 3.2*5=16v, rather than specifying how many cells explicitly, this is an effective workaround for quite a few ESCs. Of course knowing that your cutoff should be 16v, you can leave it in 4S mode and set the cutoff at 4v per cell. That will work too, as the ESC will only look at the total volts, it can't inspect individual cell voltage through a deans plug.
_____________________________
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
(in reply to HerrSavage)
       Post #: 151
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 12:18 PM
HerrSavage
Score: 318
Last Login: 5/23/2013
Status: offline
Just hooked up the Hobbywing program card. Only reads up to Item 5. So I guess I need a more advanced ESC to use the other stuff?
My LVC was set at 3.0V?!!... Changed it to 3.4V. Guess that's why I was getting decent run times....
I also changed the brake power or whatever to %50, since I think I've heard people say to do that...
Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
Hide Signatures
(in reply to Foxy)
       Post #: 152
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 1:46 PM
Foxy
Score: 2012
Status: offline
50% is a lot of brake power in a 1/8th.
By the way, I run all my LVCs at 3v, recommendations for high cutoffs stem from the fact that lipo used to be dangerous and short-lived. This is no longer the case. Setting the LVC to more than 3.2 is just wasting runtime if you ask me.
Hide Signatures
       Post #: 153
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 2:05 PM
Haddi Taha
Score: 183
Last Login: 5/11/2013
Status: offline
quote:
ORIGINAL: Foxy
+1 I use 3.0v and have never had any issues and all my celles end up around 3.5v when I put them on the charger if the lvc kicks in
But one of his packs always has a cell that finishes at 2.9v so it may be better if he sets his lvc at 3.2v just in case, and it will probably make 2 minutes difference in runtime
For 5s you just have to set the lvc to 2.8v so it recognises the 5s as a 6s but if you want to run 4s or 6s afterwards, you must change it back to 3.0v or more
Thunder Tiger MT4- Hobbywing 4274sd 2200kv motor- Savox 1256tg Servo
Hide Signatures
(in reply to Foxy)
       Post #: 154
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 2:08 PM
HerrSavage
Score: 318
Status: offline
Just went and checked - I had set it to 3.2, not 3.4. In any case, at least I've learned how easy it is to set the ESC for 5s - just go to Item 3 on the program card and change it from setting 5(3.2) to setting 3(2.8)..
What I'd still like to know is to what extent running 5s with a 14T pinion is a bad idea. Nobody ever mentions 13t pinions? Surely 13 would be a compromise between 4s and 5s, and would be fine for both? Would be nice to not have to change the pinion, and have one that worked for both...
Hide Signatures
(in reply to Haddi Taha)
       Post #: 155
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 3:04 PM
Foxy
Score: 2012
Status: offline
I use a 13 when I don't know what batteries I'll be using as it is the best middle ground, keeps the car in one piece on 6S and is quick enough (just about) on 4S. That's 13/46 on the Xray XT8 which also has a high final drive, so it would be like a 14 on other cars. However, your tires are bigger, so no real difference. If I knew I was going to be running 4S only, I'd bring along a 16 and an 18.
Also, this setting you mention for 5S...what do you mean change it from 3.2 to 2.8? You mean when the esc thinks it has 6S attached? The important thing is how many cells the ESC thinks it has connected at any given time. Assuming you want a 3.2 cutoff, if the ESC thinks it has 4S, set it to 4.0v per cell, if the esc thinks it has 6S, then 2.7, not 2.8 (assuming that's an option, of not, 2.8 will be ok)
Hide Signatures
       Post #: 156
RE: The Official Thunder Tiger MT4 G3 thread - 1/4/2013 8:25 PM
Maj_Overdrive
Score: 120
Last Login: 5/19/2013
Status: offline
As you know the bigger the pinion the higher the top speed will be with slower acceleration because of the increased load on the motor. This is just like nitro, and the electric motor will pull more amps with a bigger pinion just like a nitro will suck more fuel. The difference is the electric motor will heat up under increased load.
Now, an electric motor will draw a certain amount of amps according to vehicle weight, gearing, tire size etc. Multiply amps by voltage and you get watts. Assuming nothing is changed except you increase voltage (ie 4s to 5s) the motor will gain rpms, increasing top speed which increases load and heat. If your truck was geared for say 40mph on 4s and 40mph on 5s though, the load hasnt changed and the wattage used will be the same. But since you increased voltage the amps will decrease and the temps should be lower on the 5s setup. This is because the load on the motor is the same and the 5s setup has more power to work against the load.
This is generalization of course just to explain the concept. I'm sure there are cases where you can increase voltage without changing the gearing and be fine, but there's too many variable for me to say you'll be fine with x voltage and y gearing, maybe a fellow G3 owner can chime in with personal experience. My personal experience with 1/8 and motors similar to yours says that 50mph is going to be kinda borderline with heat. You'll probably be ok now, but maybe not so much in warmer weather. Try it out on 5s with 14t and check the motor temps every couple minutes on the first pack or two.
Hide Signatures
(in reply to Foxy)
       Post #: 157
RE: The Official Thunder Tiger MT4 G3 thread - 1/6/2013 9:04 PM
echthelion
Score: 120
Last Login: 5/22/2013
Status: offline
about the LVC u could buy one of these http://www.amainhobbies.com/product_info.php/cPath/1574_1727/products_id/183759/n/Team-Integy-LiPo-Voltage-Checker-w-Warning-Alarm its alittle better because it plugs into your balance connector and there no need to reprogram your esc each time you change you lipo cell count
My Model''''s
Losi XXL, HPI Firestorm 10T, OFNA CD3, Jammin CRT.5(Brushless), AE RC18MT
Hide Signatures
(in reply to Maj_Overdrive)
       Post #: 158
RE: The Official Thunder Tiger MT4 G3 thread - 1/6/2013 9:16 PM
HerrSavage
Score: 318
Status: offline
Thanks.. I think I'm good with the charging, checking, etc.. now. (Hope so anyway...)
Changed from 50k to 100k in the middle diff today - WHAT AN AWFULL PIA.................... Stripped out a few screws, it wasn't meshing, sticky silicon oil everywhere, etc...
So anyway, keen to go check it now - new steering servo in , 100k in the center, and a 14t pinion. Would have tested today, but the weather has been unrelentingly horrendous..........
I think I'm going to order a 13T pinion now, and then just leave it at that for both 4s and 5s..
Also want to order some HPI/HB hinge pins, as these are apparently the weak point on the truck.. And a spare spur gear, if I can find one...
Hide Signatures
(in reply to echthelion)
       Post #: 159
RE: The Official Thunder Tiger MT4 G3 thread - 1/8/2013 1:33 AM
Haddi Taha
Score: 183
Status: offline
quote:
ORIGINAL: HerrSavage
Don't you have good access to associated spare parts?
Hide Signatures
       Post #: 160
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 1:04 AM
Haddi Taha
Score: 183
Status: offline
My new Jconecepts Illuzion Ford Raptor SVT for Revo 3.3 body shell on my mt4. I accidently sprayed lots of black where there was suppose to be white but I used dot 4 brake fluid to clean it up. You wouldn't ven know I made a mistake if I didn't tell you
Hide Signatures
       Post #: 161
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 6:49 AM
HerrSavage
Score: 318
Status: offline
Looks good.. I'd do black though - white will look thrashed pretty quickly.. I just paint everything black now. All bodies end up thrashed, and black sort of still looks cool all mangled up..
Yeah, I have AE parts here at home even. But I've heard mixed things about running steel spur gears - as in it can be bad..
Hide Signatures
       Post #: 162
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 7:19 AM
Haddi Taha
Score: 183
Status: offline
I also like black alot the only issue is that I have problems seeng them at night. I plan on converting to a truggy later with black proline mugen mtx6 shell, black wing and black wheels, its going to look epic
To use a steel spur gear you need a stronger hardened steel pinion like the Robinson Racing ones so the pinion can handle the abuse.
Everyone had their own experiences with plastic and steel spur gears. I like steel gears much more as they never strip but I won't use one without a center diff or slipper clutch.
Hide Signatures
       Post #: 163
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 7:23 AM
HerrSavage
Score: 318
Status: offline
Well I have a 14T RR pinion in right now, and wouldn't mind buying for ex. a 13T too..
It is also pretty hard to find the 50T plastic SG as a spare part.. I've probably even got a couple steel 50T RC8 SG's around.. At least a 48T or 52T...
Hide Signatures
       Post #: 164
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 9:30 AM
speedeur
Score: 100
Status: offline
Hi from France. For the choice of my combo I will go with Xerun 150 A and a leopard motor the 4274. Can you confirm it's a good choice for my MT4 ??
Hide Signatures
       Post #: 165
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 11:35 AM
Haddi Taha
Score: 183
Status: offline
quote:
ORIGINAL: speedeur
perfect, what kv is the motor? Are you going to be using 4s or 6s
Hide Signatures
(in reply to speedeur)
       Post #: 166
Foxy
Score: 2012
Status: offline
quote:
ORIGINAL: speedeur
This is almost the same as the electrics that are in the car from Thunder Tiger. Good choices.
Hide Signatures
       Post #: 167
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 11:36 AM
Foxy
Score: 2012
Status: offline
quote:
ORIGINAL: Haddi Taha
quote:
ORIGINAL: speedeur
It's a 2000kv, so its ideal.
Hide Signatures
       Post #: 168
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 12:40 PM
HerrSavage
Score: 318
Status: offline
I think I've read that the stock MT4 motor is a rebadged Leopard, and that there is another Leopard that's even more powerful(and prob not much more expensive..)?
Hide Signatures
(in reply to Foxy)
       Post #: 169
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 12:47 PM
Foxy
Score: 2012
Status: offline
I believe its a hobbywing. As for 'powerful', in relation to electric motors, you can think of stator length as being like displacement for engines. The longer the stator the more torque (as a general rule, other factors are also involved, suffice it to say that under most circumstances, regarding two motors of the same diameter and architecture but different lengths, the longer is the more powerful.
Hide Signatures
       Post #: 170
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 12:51 PM
speedeur
Score: 100
Status: offline
Yes I will take this 2000 kv motor and I will run with 4s and 5s lipos I think. The leopard 4274 have a 4.2 cm diameter, is the motor mount ok for this size ?
It's this one : http://www.leopardhobby.com/product/product_veiws.asp?id=1344&functionID=01020220
Hide Signatures
(in reply to Foxy)
       Post #: 171
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 12:54 PM
Haddi Taha
Score: 183
Status: offline
Speedeur, thats motor should work perfectly
Foxy, I don't think its a Hobbywing, the only smooth can (no fins) hobbywing 1/8 motor are the sensored buggy ones. But they are probably made in the same factory or something with all the other chinese motors
Its looks pretty similar to this
Whatever it is, its a pretty reliable motor that has lots of power, but I'm liking my Hobbywing Xerun 4274sd Sensored Motor more, has an extra 200kv yet still runs a bit cooler than the ttr stock one. Shame there is no sensor port int he ace rc esc though despite it being based on the hw xerun 150a esc
Hide Signatures
(in reply to Foxy)
       Post #: 172
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 1:01 PM
speedeur
Score: 100
Status: offline
Cool thanks for your answer I will make an order of this combo. Can you give me an idea of wich lipos I can take for it ?
Is there any model with good quality/price to run in 4s or 5s at the hobbyking store or another website ?
Hide Signatures
       Post #: 173
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 1:09 PM
Foxy
Score: 2012
Status: offline
Get from hobbyking the NANOTECH batteries, at least 5000mAh and at least 30C. Also remember that hte MT4 has a small battery tray, only up to 139mm length.
Hide Signatures
       Post #: 174
RE: The Official Thunder Tiger MT4 G3 thread - 1/9/2013 1:12 PM
Foxy
Score: 2012
Status: offline
You're right, after only a little research, I discovered that the Ripper motor is in fact a Leopard 4074.
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.156RCU1
