twister xb/xtg and xb/xtg pro thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> twister xb/xtg and xb/xtg pro thread
Page: [1]
Login
twister xb/xtg and xb/xtg pro thread - 4/21/2012 1:31 AM
greggreg2011
Score: 100
Last Login: 4/27/2012
Status: offline
 did a lil browsing and didnt see an actual thread just for these rides.......id just like this to be a q&a thread for these redcats....also a show your mods and ride all together..........
Hide Signatures
       Post #: 1
RE: twister xb/xtg and xb/xtg pro thread - 4/21/2012 2:19 AM
greggreg2011
Score: 100
Status: offline
so heres what ive seen so far with my twister xb pro.....this is only on the track.....so far ive ran rite around 14 packs through this car.....only lipo,,a 3800 30c 2s lipo  juice pax....fits great as its not a hard case.....full size 2s hard case does fit but its really tite......ill start with the weak links.....im leaning more towards racing then bashing so keep that in mind((((and this buggy is comp capable))))  ok so first thing off the bat the tires are just horrible..the glue they use isnt to great either to hold up to the brushless power......so first this to be track ready id suggest at least rear tires(((i chose proline evil twins on the rear of mine because they work good for my current tracks layout(((it will differ from yours but they are a good starting point at only 12 bucksish on ebay)))) second thing i noticed...you can see i swapped out the rear wheels as well....the redcat hole for the axle is a hair bigger then the rest,,or at least a hair bigger then what will fit the associated b4.1...also the axle pin is a little bigger,,,,,this is a good thing for durability but not for quick swaps.....remedy that by a lite drill out of the wheels you want to use and just use a hair smaller axle pin as well(((half my batts run were with smaller pin and held up great,,no probs))))).....on to the front wheels...they arent too bad, but if changing the rear may as well change the front....i was able to pull stock front tires off with ease as they werent glued too great,,,,i just added losi ribbs to the front....same as stock but softer and ribbs are constructed better........moving onto the suspension.........basic setup out of box wasnt all to bad but no adjustability unless you want to use preload spaces witch im surprised redcat didnt include......basically i dug out some older schaool aluminum bodied shocks that are not threaded but have an adjuter sleve,,,,,filled em with regular old tamiya damper oil...fronts set to top and bottom inner positions for droop....and same with rear,,innermounts top and bottom.....then worked the shock adjuster sleve from there......
big thing you need to do weather racing or bashing....the zipties they used for the wires....they are a bit tite and will damage and eventually sever the wires,,,,i suggest to cut them out and replace with your own slug but not too tite to damage the wires.......
weak spot i see so far is the front end,,,,,,,,  part ###s
KB-61004
KB-61002
KB-61012
all cheap parts but since track hobby shops dont carry them i advise to keep an extra set just in case
TO THE GOOD
buggy overall so far has been great....cant wait to beat some associateds and losis next month in a novak 6 week series witch i will update in this thread
like i said earlier fronts a lil fragile but being a buggy on the track thats just how it goes....everything else is great.....motor and esc stay cool during normal racing times....during practice ill run hard 25 mins straight and itll start to get warm then but thats after a hard 25 mins so anything would be getting warm......i thought the rear on/off switch would have been a problem but actually its not even when getting into contact with other cars...very nice not being under the body.....the included servo seems to be plenty fast and durable(((((if you go to the track always keep a spare though)))you can pic up a associated metal gear servo for under 15 bucks new....ebay!!!!!!
always keep an eye and tighten your screws regularly,,,if you do strip something out or happen to have to replace a part id reccommend switching out the hardware(((i personally havent because i like phillips over hex hardware))) but hex doesnt strip like phillips
its really up to what u prefer...you dont need to spend a bunch buying an upgraded screw kit...go to your local mom n pop hardware store and spend the 30 mins to find the hardware you need...its cheap
i cant talk on the radio system yet as mine had problems that are going through redcat now.....but what i can say is that so far redcat customer support has matched team associateds in everyway so far....."""""keep it up redcat support"""""""
thats about all for now...ill add pros n cons as i go....please do the same and any upgrades you find...also lets see pics of yours..
its all in fun,,,,heres how mine sits now((was at the track 7 hrs yesterday so yeah))) and track pic is current layout where i race at  702rcraceway in las vegas nv
Hide Signatures
(in reply to greggreg2011)
       Post #: 2
RE: twister xb/xtg and xb/xtg pro thread - 4/21/2012 2:20 AM
greggreg2011
Score: 100
Status: offline
darn pics didnt show,,,this is diff from other forums im on....i see a youtube link button so ill do a short photo vid and post in a sec
Hide Signatures
       Post #: 3
RE: twister xb/xtg and xb/xtg pro thread - 4/21/2012 3:19 AM
greggreg2011
Score: 100
Status: offline
http://www.youtube.com/watch?v=iXw2Uc3qhAU
Hide Signatures
       Post #: 4
RE: twister xb/xtg and xb/xtg pro thread - 4/21/2012 3:32 AM
greggreg2011
Score: 100
Status: offline
great upgrades on the xb here this guy did,,,ill see if i can get a parts list from him    http://www.youtube.com/watch?v=MNFKU3pw&feature=related
Hide Signatures
       Post #: 5
RE: twister xb/xtg and xb/xtg pro thread - 4/26/2012 12:46 AM
greggreg2011
Score: 100
Status: offline
didnt get a list yet i dont think from the youtube guy for compatible integy alum parts yet but if i have to ill go through the vid again and write it down to post here....i do though actually have a working lansu tx rx now and heres my thoughts on that....
decent adjustability being a basher with the epas(((end point adjustments)))  this should apply to anyone...the steering epas left and right do need to be cut down abit to keep servo life....if you turn and turning radious hits max but you still hear the servo trying to turn it needs to be lower....i saw it needed to be cut in half on my twister xb pro after i alighned the servo to be straight... the throttle and brake/reverse epas are nice to have....that way you can set it to half throttle for a begginner or you can take reverse out totally if you race like i do....i havent done a how far i can control test yet but it runs in the track fine...100 yards give or take....
ill get more input as thurs ill be at the practice track all day....
other....being a buggy if you dont keep it on the wheels all the time eventually the rear body mount usually will give out(((body itself i mean)))) i will add velcro to this witch also stops the little bit of parachutying also....will add 2marro eve if you dont know what im talkin about
still love this redcat
Hide Signatures
       Post #: 6
RE: twister xb/xtg and xb/xtg pro thread - 4/28/2012 1:51 PM
volcanoman01
Score: 100
Last Login: 6/17/2012
Status: offline
whate part number is that associated metal gear servo you mentioned .Thanks
Hide Signatures
       Post #: 7
RE: twister xb/xtg and xb/xtg pro thread - 4/29/2012 5:10 PM
PetRock
Score: 100
Last Login: 5/23/2013
Status: offline
A Twister thread without a link to the UltimateRC review? What's going on here?
Hide Signatures
(in reply to volcanoman01)
       Post #: 8
RE: twister xb/xtg and xb/xtg pro thread - 4/29/2012 7:11 PM
volcanoman01
Score: 100
Status: offline
Thanks for the review link. I have a twister xtg pro had it about three weeks .Been running on local track been through 3 sets body munts battery case rear upright set of back tires rim and a wheel pin.Dont think this car is as tough as my volcano s30 wish it was.
Hide Signatures
(in reply to PetRock)
       Post #: 9
RE: twister xb/xtg and xb/xtg pro thread - 5/28/2012 2:14 PM
volcanoman01
Score: 100
Status: offline
maybe some one can help me .I trying to find out who makes the motor for the twister xtg pro (3930kv brushless).and what turn this motor is.any help would be appreciated.THANKS
Hide Signatures
       Post #: 10
RE: twister xb/xtg and xb/xtg pro thread - 5/29/2012 5:55 PM
billymare
Score: 105
Last Login: 5/16/2013
Status: offline
I have the XTG Pro, the update's I did were the metal diff...  A MUST!!  the other things i did is to use the front steering arms and c hubs from a blitz, no mods required, now i can use any wheel with a 12MM hex!  I have run 5000mAh 3S lipo in this and the plastic diff lasted 30 seconds.
https://www.youtube.com/watch?v=MhI-q42SBUY&list=UUfeYue5ovV1YczwmwCBFL6A&index=4&feature=plcp
< Message edited by billymare -- 5/31/2012 1:15 AM >
_____________________________
Redcat''s a-plenty,savage XS,2 Savages,1brushless XL
Sprint2, Blitz, Terra Crusher,ast. planes, helicopters and a LOT m
Hide Signatures
       Post #: 11
RE: twister xb/xtg and xb/xtg pro thread - 5/29/2012 10:56 PM
Microz
Score: 120
Last Login: 5/3/2013
Status: offline
Hey there. I have the Twister XTG Pro and would like to know, will traxxas and ECX pinion gears work on the XTG or do i need to buy some redcat ones?
Planes:HBZ Champ, Micro T-28, Ember 2, UM Stryker
Cars: Traxxas Rustler, ECX Circuit
Hide Signatures
(in reply to billymare)
       Post #: 12
RE: twister xb/xtg and xb/xtg pro thread - 5/30/2012 12:44 AM
billymare
Score: 105
Status: offline
No, the motor shaft is 5MM
quote:
ORIGINAL: Microz
Hide Signatures
(in reply to Microz)
       Post #: 13
RE: twister xb/xtg and xb/xtg pro thread - 5/30/2012 1:17 AM
nitrosportsandrunner
Score: 296
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: billymare
quote:
ORIGINAL: Microz
yeh, the 5mm shaft on the motor is the one odd thing on the twister. Its a 540 can but has a 5mm shaft, which is usually only seen on 550 can 1/8 scale motors.
I have the twister's ESC and motor in my rustler. I used a 5mm 32 pitch gear and a 32 pitch hot racing spur gear.
Dont forget that the ESC can be programed with the ezrun program card.
I wish redcat would come up with a upgrade front body mount. Those are for sure weak(on the xtg)
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
       Post #: 14
RE: twister xb/xtg and xb/xtg pro thread - 5/30/2012 2:04 AM
Microz
Score: 120
Status: offline
Thank you guys. Well i am going to be changing out the motor to a tacon, so would they work then, or is the spur not compatible?
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 15
RE: twister xb/xtg and xb/xtg pro thread - 5/30/2012 4:31 AM
Score: 296
Status: offline
quote:
ORIGINAL: Microz
i think it should then. pretty sure the twister spur is 48pitch, which is the same a a rustler.
Hide Signatures
       Post #: 16
RE: twister xb/xtg and xb/xtg pro thread - 5/30/2012 9:40 PM
Microz
Score: 120
Status: offline
Okay nice thanks!
Hide Signatures
       Post #: 17
RE: twister xb/xtg and xb/xtg pro thread - 6/6/2012 3:21 AM
volcanoman01
Score: 100
Status: offline
this is to billymare I would appreciate it if you could give me the part # for the c hubs and steering arm you used on your twister xtg pro .THANKS
Hide Signatures
       Post #: 18
RE: twister xb/xtg and xb/xtg pro thread - 6/12/2012 8:38 AM
86MOmo
Score: 100
Last Login: 5/5/2013
Status: offline
Wondering if anyone has any experience in Flashing the ESC with updated software and trying to run Mod motors?
I've played a little bit with the HW/RC ESCs and it seems as though they can be updated, I'm just curious if anyone has played with any motors other than the stock one.
MOmo
Hide Signatures
       Post #: 19
RE: twister xb/xtg and xb/xtg pro thread - 6/12/2012 6:17 PM
billymare
Score: 105
Status: offline
Pretty sure this was all I needed.  You may have to shim up the control arm to c hub pins a little to make it work.
103360 FRONT AXLE 5x26mm (2pcs)
$8.00 $8.00
103362 LOCKING HEX WHEEL HUB 12mm (4pcs)
$8.00 $8.00
100311 FRONT UPRIGHT SET
$10.00 $10.00
    Total: $26.00
$8.00 $8.00
$8.00 $8.00
$10.00 $10.00
    Total: $26.00
quote:
ORIGINAL: volcanoman01
Hide Signatures
       Post #: 20
RE: twister xb/xtg and xb/xtg pro thread - 5/20/2013 6:56 PM
RCChino
Score: 100
Status: offline
nebody know what other models have parts that are compatible with the XTG. Trying to mod up my ride.....
Hide Signatures
       Post #: 21
RE: twister xb/xtg and xb/xtg pro thread - 5/21/2013 3:32 AM
Zonked
Score: 100
Status: offline
Has anyone converted the buggy XTB to hex wheels ? Would be sweet if Kyosho or B4 hex wheels would fit .
@RCChino, I dont have the truck just the buggy but going by appearance it looks like Redcat used the HPI E-Firestorm as inspiration for this chassis
Hide Signatures
(in reply to RCChino)
       Post #: 22
RE: twister xb/xtg and xb/xtg pro thread - 5/21/2013 3:39 AM
Zonked
Score: 100
Status: offline
Hey guys wanted to ask if the metal diff upgrade is a sealed unit with gaskets orings etc.
Hide Signatures
(in reply to Zonked)
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.093RCU1
