Need help identifying Sport Jett Engine for Bearing Replacement...    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Need help identifying Sport Jett Engine for Bearing Replacement...
Page: [1]
Login
Need help identifying Sport Jett Engine for Bearing Rep... - 4/23/2012 3:12 PM
glowplugboy
Score: 115
Last Login: 4/7/2013
Status: offline
I have a Sport Jett that does not have any identifying engraving on it. I believe it to be an eariler model as the needle valve assembly is on the carb, not in the now standard remote position. I put on the bench yesterday, and inspite of a pretty rough main bearing, it turned an APC 10 X 6 at 15,500 on 10% fuel. As Dub is closed right now until the 29th, would anyone know what displacement this engine is, and what bearings might be needed? I suspect it is a .40 or a .46. I am not aware if Dub made a Sport Jett .40, so I am guessing. Thanks in advance!
Mike in Clear Lake
_____________________________
Representative of<br>
GCBM R/C Enterprises
Hide Signatures
       Post #: 1
RE: Need help identifying Sport Jett Engine for Bearing... - 5/1/2012 2:50 PM
bob27s
Score: 105
Last Login: 5/7/2013
Status: offline
My apologies... I missed this one somehow.
The crankcase on all of the engines were marked with the engine size, a number, and Dub's signature. If the case had been replaced, then it might not be marked.
Yes, Dub makes engines from .40 through the 60L in the small block size case.
The Sport Jett .40 was used for racing evenings for several years, and the SS-40 was based on that engine too. So finding a jett .40 is not difficult.
Yes, typically most people would use a .46 or .50 for sport plane use.
As for bearings - easy to find. The SJ-50-50 use the same bearings. Unless it is one of the 1993 version engines - Version #1 from long ago.
If you have a photo of the engine you can post, I might be able to assist.
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
(in reply to glowplugboy)
       Post #: 2
RE: Need help identifying Sport Jett Engine for Bearing... - 5/1/2012 3:13 PM
glowplugboy
Score: 115
Status: offline
Hi Bob,
Thanks for getting back with me. So that explains the lack of an engraved displacement on the engine! Here are some pics. I am beginning to believe it is a .40. Let me know....
Mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bob27s)
       Post #: 3
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Need help identifying Sport Jett Engine for Bearing Replacement...
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
