JR TX    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> JR TX
Page: [1]
Login
JR TX - 4/24/2012 1:32 AM
rcpete347
Score: 100
Last Login: 5/25/2013
Status: offline
HI all, can't believe, I can't find the answer in the manual but after setting up a gyro, I got looking a the main screen on the JR 12x, and do not know what the upper trim graft does,with 12 and 16, see pic.
Anyone know.
Rcpete
Click to see fullsize image.
Click for fullsize
_____________________________
Rcpete has all 1/6th scale pilots, BB-F86, F-4,F-14, F-15, F-16,F-18, F-22, Thunderbirds, Aviators, Female Pilots, Mr Bean, Hot Toys, Tom Cruise, Val Kilmer.
Rcpete has Blue Box Cockpits
Hide Signatures
       Post #: 1
RE: JR TX - 4/24/2012 2:13 AM
KC36330
Score: 328
Last Login: 5/22/2013
Status: offline
it's the eyebrow trims, if they aren't assigned to something they do nothing but beep as you bump them
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
(in reply to rcpete347)
       Post #: 2
RE: JR TX - 4/24/2012 2:17 AM
rcpete347
Score: 100
Status: offline
HI, thanks, it's funny, how they ended up with 12 and 16, when they have never been assigned.
Thanks Rcpete
Hide Signatures
(in reply to KC36330)
       Post #: 3
RE: JR TX - 4/24/2012 4:43 AM
Bob_B
Score: 100
Status: offline
that's there position away from Center not a channel assignment.
Cincinnati Jet Club, Team Futaba, Wren Turbines USA
Hide Signatures
       Post #: 4
RE: JR TX - 4/24/2012 2:39 PM
John Redman
Score: 117
Status: offline
As Bob stated, it is a position away from center.
Also these trimmers can be used as momentary function or as selectable function on any 12X. If you purchased your 12X when they first came out and have never sent it in you will not have the momentary function and it needs to come back to Horizon for a firmware update. Only necessary if you want it.
There is an addendum regarding this here. http://www.horizonhobby.com/pdf/JR_12X_Manual_Addendum.pdf
You can check the addendum and then check screen 83 to see if you have the updates firmware.
John Redman
Team Horizon, JetCat USA Rep
Hide Signatures
(in reply to Bob_B)
       Post #: 5
RE: JR TX - 4/24/2012 4:40 PM
rcpete347
Score: 100
Status: offline
Thanks Bob and John, my 12x was upgraded, and great to see this extra function.
So I have learned , this ear switch, can be used for a trainer switch, a on/off switch.
So back to my originall question, the screen with 12/16 ?, and how do i 0 it, where in the manual, is it explained.
Rcpete
Click for fullsize
Hide Signatures
(in reply to John Redman)
       Post #: 6
RE: JR TX - 4/24/2012 4:45 PM
Dave Wilshere
Score: 108
Status: online
Pete
You should just be able to drive them back to 0...
Dave
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
       Post #: 7
RE: JR TX - 4/24/2012 5:02 PM
Greg Wright
Score: 102
Status: offline
Pete,
You can also turn them off completely so if you do hit them they will not move from center. I have assigned the right momentary switch as my timer start button after i have inhibited the switch.
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 8
RE: JR TX - 4/24/2012 5:03 PM
seflyer
Score: 105
Status: offline
you can make them momentary buttons under trim system,either on or off, but they can be run out either direction whether set to momentary or not. they cannot be disabled that I have found.
Kevin
Hide Signatures
       Post #: 9
RE: JR TX - 4/24/2012 5:16 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: seflyer
Kevin
sure they can, under Trim code set flap and aux trim steps to 0 and they won't move.
Hide Signatures
(in reply to seflyer)
       Post #: 10
RE: JR TX - 4/24/2012 5:20 PM
seflyer
Score: 105
Status: offline
ok, cool did not think about that. you're right, just dit it.
Kevin
Hide Signatures
       Post #: 11
RE: JR TX - 4/24/2012 7:29 PM
Greg Wright
Score: 102
Status: offline
Or you can go to the two columns on the right of the flap and aux trim and turn them from on to off and they will not move at all.
Greg Wright
Hide Signatures
       Post #: 12
RE: JR TX - 4/24/2012 7:46 PM
seflyer
Score: 105
Status: offline
ok, so the left column turns the switch on or off and the right changes it from momentary to normal. learn something new everyday., lol
Kevin
Hide Signatures
(in reply to Greg Wright)
       Post #: 13
RE: JR TX - 4/24/2012 8:11 PM
John Redman
Score: 117
Status: offline
Talked about in the addendum I listed prveiously.
John Redman
Hide Signatures
       Post #: 14
RE: JR TX - 4/24/2012 8:15 PM
seflyer
Score: 105
Status: offline
never needed to disable them, I love those things, one is for my timer and the other for misc. functions that I use on a few planes. maybe I should read the instructions once in a while.
Kevin
Hide Signatures
       Post #: 15
RE: JR TX - 4/24/2012 8:39 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: seflyer
......... maybe I should read the instructions once in a while.
Instructions are just the manufacturers suggested way you use it, they aren't mandatory.
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
