Any readings on Saito FG36?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Tachometer Readings >> Any readings on Saito FG36?
Page: [1]
Login
Any readings on Saito FG36? - 4/24/2012 5:57 PM
PhoenixRock
Score: 100
Last Login: 12/26/2012
Status: offline
Does anyone have any readings on the Saito FG36?
< Message edited by PhoenixRock -- 5/1/2012 12:35 PM >
_____________________________
SAMAA 3013
Hide Signatures
       Post #: 1
RE: Any readings on Saito FG36? - 5/1/2012 12:10 PM
jamesroutledge
Score: 100
Last Login: 5/21/2013
Status: offline
The silence is deafening!
SAMAA 5409
Club Saito Member #766
Hide Signatures
(in reply to PhoenixRock)
       Post #: 2
RE: Any readings on Saito FG36? - 5/1/2012 12:31 PM
PhoenixRock
Score: 100
Status: offline
 At least you are talking, James!...
It's killing me!
SAMAA 3013
Hide Signatures
(in reply to jamesroutledge)
       Post #: 3
RE: Any readings on Saito FG36? - 5/7/2012 1:11 PM
jamesroutledge
Score: 100
Status: offline
Looked around on Youtube for FG36.
Most guys who give the prop size are using 18x8 or 19x8.
7200 to 8000 rpm
SAMAA 5409
Hide Signatures
       Post #: 4
RE: Any readings on Saito FG36? - 5/7/2012 1:55 PM
PhoenixRock
Score: 100
Status: offline
James,
Also read quite a lot over the weekend...
Tested it yesterday afternoon and got 7850 with the 18X8.
I have ordered the 18x10 and 19x8 and will try them as soon as I get them!
SAMAA 3013
Hide Signatures
       Post #: 5
RE: Any readings on Saito FG36? - 5/7/2012 9:23 PM
airraptor
Score: 130
Status: online
I have been looking for a 30-40cc FS for a project of mine and from what i am seeing the Roto motor 35FS is stronger than the Saito and is very close to the same weight. it also about 50 dollars cheaper. it turns a 20x10 6,000
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
       Post #: 6
RE: Any readings on Saito FG36? - 5/8/2012 6:21 PM
jamesroutledge
Score: 100
Status: offline
I know this is off topic and I apologise to other users, but I also know this FG36 is in a Typhoon. Check out this video http://www.youtube.com/watch?v=Fo0Lv1S3RfQ&feature=related and this video http://www.youtube.com/watch?v=qexMo-2ZLos&feature=related .. Awesome plane.
SAMAA 5409
Hide Signatures
       Post #: 7
RE: Any readings on Saito FG36? - 5/8/2012 9:58 PM
jamesroutledge
Score: 100
Status: offline
7850 rpm on an 18 x 8 is barely 1.5 hp and 3.75 kg thrust according to ThrustEstimator. A strong 61 two stroke makes that horsepower!
MVVS-prop-power-calculator gives 2.17 hp and 7kg thrust.
Will be interesting to put a scale behind it and do an actual thrust measurement.
Must try APC props !
SAMAA 5409
Hide Signatures
       Post #: 8
RE: Any readings on Saito FG36? - 5/9/2012 8:23 AM
PhoenixRock
Score: 100
Status: offline
James, where do I get a hold of those calculators / thrust estimator?
I have a "Prop-power-calculator" which gives me 8.3kg static thrust, needing 2.69 hp, on the readings mentioned.
I will however put an electronic scale on it this weekend...
SAMAA 3013
Hide Signatures
       Post #: 9
RE: Any readings on Saito FG36? - 6/2/2012 7:42 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: PhoenixRock
James,
That's what I get W/a Saito FA150 W/a Dynathrust 18 X 8 when running C&H electronic ignition W/15% Morgan's Cool Power. 23% longer run time on a given fuel load @ WOT.
7700 W/the same prop/fuel on glow ignition.
I get 8000 W/that prop/fuel W//an FA 180 on glow ignition. Hoping to get about 8200 on spark ignition W/the 180.
A timed spark is a wonderful thing for power & fuel economy.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 10
RE: Any readings on Saito FG36? - 6/2/2012 7:47 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: jamesroutledge
I have a ''Prop-power-calculator'' which gives me 8.3kg static thrust, needing 2.69 hp, on the readings mentioned.
According to this calculator http://personal.osi.hu/fuzesisz/strc_eng/index.htm that takes the prop diameter, pitch, prop design & amnient temperature, that's 2.759 HP & 17.64# of static thrust.
The HP for 7700 RPM is 2.6HP which is pretty close to Saito's FA150 factory HP rating of 2.5HP.
Hide Signatures
       Post #: 11
RE: Any readings on Saito FG36? - 3/11/2013 1:04 AM
akouzmit
Score: 100
Status: offline
OK, Here is field measurements taking with electronic scale (fish scale max 20kG):
SAITO FG-36B (Stock ignition replaced with RCEXL hole sensor based ignition).
Prop: Xoar 19x8
Max RPM 6870-6980 (Note: It is not optimum RPM for this engine in order to get max HP out.)
Static thrust 5.5kG - 5.7kG
I am going to use APC 18x6W in order to get my target of 8500RPM (8300-9000RPM considered the best for max HP output).
I hope static thrust may go up a bit due to low pitch prop working better in static conditions.
From today test I think 19x8 is a bit too much for FG-36 in order to get max HP output.
With Xoar 18x8 I have measured earlier I was getting somwhere around 8000RPM. No thrust measurement was done at that time.
Need to repeat my experment with 18x8 again and measure static thrust while waiting for APC 18x6W to arrive.
Anyone can share field measurements with other props?
Thank you,
Andrei K.
Hide Signatures
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Tachometer Readings >> Any readings on Saito FG36?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
