What's the biggest prop yo can use on a Super Tigre .90?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> What's the biggest prop yo can use on a Super Tigre .90?
Page: [1]
Login
What's the biggest prop yo can use on a Super Tigre .90? - 4/25/2012 2:13 AM
Corvette50
Score: 100
Last Login: 1/23/2013
Status: offline
I was wondering for thrust and not speed what's the largest you can safely use on the ST .90?
Thank you, for any advice you give.
Hide Signatures
       Post #: 1
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 4:33 AM
RCPAUL
Score: 122
Last Login: 6/19/2013
Status: offline
The Tower web site says a 12x8 or 13x7. Most 90s will swing a 14x6.
Paul
_____________________________
Gosh, model airplanes are not a matter of life and death - they''''''''re more important than that!
Hide Signatures
(in reply to Corvette50)
       Post #: 2
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 10:56 AM
Corvette50
Score: 100
Status: offline
Yea Tower I think is a bit off. I'm running a 14x4W Zinger and it seams to be on the small side. I have read where some guys are using up to 16's, but wasn't sure if it would damage the motor.
Hide Signatures
       Post #: 3
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 11:49 AM
flyingagin
Score: 114
Status: online
Mine has performed very well with a 14x6
"As for Me and My House, We Will Serve the Lord"
Club Saito Member 775
Hide Signatures
       Post #: 4
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 12:51 PM
pe reivers
Score: 646
Status: offline
I think the upper limit is a 16x6
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to flyingagin)
       Post #: 5
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 1:06 PM
AMB
Score: 110
Last Login: 6/20/2013
Status: online
As diesel conversion 16x8 martin
Hide Signatures
(in reply to pe reivers)
       Post #: 6
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 1:17 PM
RCVFR
Score: 141
Status: offline
quote:
ORIGINAL: pe reivers
I flew a Magnum 91 2stroke on a Seagull Edge 540 for a couple years using 15X6 prop. I think that is about the maximum my engine is happy with. I usually try different props to see what works best with the particular plane, and I was surprised to see very little difference between APC, Powermaster and Zinger, leading me to conclude the engine was at or near its maximum  "effort". Usually, there is some signifigant difference in performance from one prop to another. Not here.
edit: corrected 16X6 to 15X6
< Message edited by RCVFR -- 4/26/2012 8:23 PM >
Sometimes, things are exactly as they appear to be.
Hide Signatures
       Post #: 7
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 5:55 PM
daveopam
Score: 191
Status: offline
14x6 is no problem. If it's a 3D type plane a 15x4W is pretty good also.
You might tell us what it's on, and we can tell you what has worked in the past.
david
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to RCVFR)
       Post #: 8
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 7:02 PM
Corvette50
Score: 100
Status: offline
It's on my Great Planes Cap 580. I changed the carb to a Perry, and all I can say is WOW what a different engine.
I have a 14x4W Zinger on her now an have yet to get her in the air with it, but I know she's fast and I'm really not to interested in speed so a larger prop I believe is the way to go.
I appreciate everyones advice. I can't wait to get  her in the air. At 7 1/4 lbs it should be a real monster with aerobatics.
Hide Signatures
(in reply to daveopam)
       Post #: 9
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 7:55 PM
jaka
Score: 158
Status: offline
Hi!
I use a 16x4W APC in my You-Can-Do .60 and a 15x4W APC,in my GEE -BEE R-2, both powered with MVVS .91 engines! The Super Tigre should manage those props too without problems.
For a sport typ plane a 14x6 APC or RAM is also a good choice!
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 10
RE: What's the biggest prop yo can use on a Super Tigre... - 4/25/2012 11:18 PM
TFF
Score: 153
Status: online
13X7 zinger for every day but the magic prop was a 15X6N Pattern APC, not easy to find. Might have turned a 15X7N Pattern but never saw one.
Hide Signatures
(in reply to jaka)
       Post #: 11
RE: What's the biggest prop yo can use on a Super Tigre... - 4/26/2012 8:31 PM
daveopam
Score: 191
Status: offline
A 13x6 MA is not bad for instant throttle respons on a ST 90. I have this combo on an old H9 Pizzaz. It's not fast but it will JUMP out of a hover.
david
Hide Signatures
(in reply to TFF)
       Post #: 12
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> What's the biggest prop yo can use on a Super Tigre .90?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
