So, I tried bulk charging the battery. Heres what happened: the LCD indicated around 33.4 which is .2 below cutoff for an 8 cell... I pressed stop just to see what the voltages were for each cell. they were showing around 4.8-4.9 each. I was thinking odd, but it just came off the charger maybe thats the way it happens with charging LIPO... So I kept it undone thinking I would check later... I did check later, about an hour later... this time each cell was showing about 5.2-5.4!!! which freaked me out a bit, I checked the battery for temperature (it was room temp), and for puffing, (none at all), - weird -... so I waited a few minutes checked again, and the voltage was coming down across the board, around 4.9... a few minutes later, down more to about 4.5 then several minutes later checked again and they were around 4.2. Is this weird behaviour? Id think it was, but being as this is brand new for me, I dont know. Please advise!
