what is the most powerful 28    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> what is the most powerful 28
Page: [1]
Login
what is the most powerful 28 - 4/29/2012 6:04 AM
roadrunner ss
Score: 100
Last Login: 5/22/2013
Status: online
im looking to put a 28 on my car what is the best one to buy
_____________________________
IM JUST GETTING STARTED ON UR CANDY AZZ
Hide Signatures
       Post #: 1
RE: what is the most powerful 28 - 4/29/2012 7:10 AM
fdjizm
Score: 110
Status: offline
RB TM928 or Novarossi 528.
HPI Super nitro RS4 RB .28-HPI RS4 Nova flash 21
HPI RS4-3 RB Xenon-R .21-HPI Racer 2 OS .18-HPI R40 OS .18
Hide Signatures
(in reply to roadrunner ss)
       Post #: 2
RE: what is the most powerful 28 - 4/29/2012 7:41 AM
HerrSavage
Score: 318
Last Login: 5/4/2013
Status: offline
quote:
ORIGINAL: fdjizm
Both discontinued.
Novarossi Plus 7T or OS 28. If you've got the dough get it modded by AB Mods...
Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
Hide Signatures
(in reply to fdjizm)
       Post #: 3
RE: what is the most powerful 28 - 4/29/2012 8:26 AM
roadrunner ss
Score: 100
Status: online
what about about th axial .28 is that on a good motor
Hide Signatures
(in reply to HerrSavage)
       Post #: 4
RE: what is the most powerful 28 - 4/29/2012 8:49 AM
HerrSavage
Score: 318
Status: offline
It's lower rung IMHO. What car is it for?
For a more budget level engine I'd much prefer a Dynamite Big Red .28 or LRP 28 Spec 3/Losi 454 over the Axial.
Hide Signatures
       Post #: 5
RE: what is the most powerful 28 - 4/29/2012 9:06 AM
roadrunner ss
Score: 100
Status: online
im putting it in a hpi racer 2
< Message edited by roadrunner ss -- 4/29/2012 9:55 AM >
Hide Signatures
       Post #: 6
RE: what is the most powerful 28 - 4/29/2012 2:08 PM
fdjizm
Score: 110
Status: offline
quote:
ORIGINAL: HerrSavage
quote:
ORIGINAL: fdjizm
Both discontinued.
In production or not both engines are beasts and you can still find them on ebay.
The axial is a good engine for the price also the OS 28xz is definitely a good choice along with the LRP z28.
They will be happy in the RS4 good luck man!
Hide Signatures
       Post #: 7
RE: what is the most powerful 28 - 4/29/2012 8:14 PM
roadrunner ss
Score: 100
Status: online
 okay there to many too choose from i need the best one
Hide Signatures
       Post #: 8
RE: what is the most powerful 28 - 4/29/2012 8:31 PM
HerrSavage
Score: 318
Status: offline
Budget, Dynamite Big Red. High-end, OS 28XZ.
Hide Signatures
       Post #: 9
RE: what is the most powerful 28 - 4/30/2012 1:41 AM
roadrunner ss
Score: 100
Status: online
so the os 28 the best one hand down
Hide Signatures
       Post #: 10
RE: what is the most powerful 28 - 4/30/2012 2:38 AM
roadrunner ss
Score: 100
Status: online
Price:
$149.99
SKU:
RBD01910-000222
Calculated at checkout
Quantity:
Product Description
This is the RB Concept RT10 .28, Standard Plug, Competition Truggy Engine. Developed exclusively for Truggy, the RT10 is a very powerful .28 engine. This engine features a 5 port sleeve with 2 bypass ports, and the exclusive RB 3-Port Multi Exhaust System (MES), providing great power and incredible RPM's. With the torque to move any 1/8 truck, whatever the weight, this engine is just what the doctor ordered, when you need a cure for your power deficiency.
Features:
  • High level racing engine
  • 7 ports + 3 Multi Exhaust System
  • Standard plug
  • Bi-turbo 14mm crankshaft
  • 14mm main bearing and double rubber seal front ball bearing
  • Nylon 9mm carburetor with 9mm venturi included
  • Light Off Road L2G cooling head
  • Orange anodized carburetor wrist pin
  • Orange protection caps
Recommended Tuned Pipe Set:
01351-THG02: THG02 Polished Truggy Tuned Pipe
01353-192P: 92mm Inline Polished Manifold
Recommended Glow Plugs:
  • 01056-5
  • 01056-6
  • 01056-7
  • 01056-8
Specifications:
Displacement: 4.67 cc
Bore: 18.35mm
Stroke: 17.60mm
Porting intake: 7
Porting exhaust: 3
Crankshaft: 14mm
Carburetor: 01258-9 Composite 9mm
Glowplug: STANDARD 01056-6
Weight: 370 Gr.
Use: 1/8 Truggy
RRP:
$339.99
Your Price:
$149.99(You save $190.00)
SKU:
OSM12830
Quantity:
Product Description
The new O.S. 28XZ Competition Truggy Engine – perfectly balanced power for today’s truggies! With input from top truggy drivers, O.S. has developed the ideal engine for these hybrid hot rods! The 28XZ produces more low-end torque, providing the rpm/torque balance that heavier truggies require. The result is power that’s incredibly smooth! And the 28XZ comes with all the components serious racers need for fine-tuning to meet any conditions: Two carb inserts – a 9mm blue for higher rpm applications and larger tracks and an 8mm red for smaller tracks that restrict air intake, an extra copper head shim for more head raising/lowering options and a piston sleeve that boasts 6 ports for significantly increased power.
Features
• The larger head aids in cooling and is a 2-piece construction with inner head button.
• A sealed front bearing and high-performance inner bearing are part of the new crankcase design.
• The high-performance con rod features oiled bushings.
• Three needles enhance fine-tuning on the 21J slide-valve carb.
• Comes with a high-performance P3 hot turbo plug
• The Mark Pavidas Edition Tuned Pipe is the perfect accessory for the 28XZ; flywheel sets are required (sold separately) for certain truggy models.
Specifications:
Displacement: 0.284 cu in (4.65 cc)
Bore: 0.728 in (18.5 mm)
Stroke: 0.681 in (17.3 mm)
Practical rpm: 4000-38,000
Power Output: 3.31 hp @ 32,000 rpm
Weight: 13.1 oz (375 g)
RRP:
$339.99
Your Price:
SKU:
AXE223R25
Brand:
Quantity:
Product Description
This is the Axe Rossi brand Cobra X1 off road competition Truggy engine. This is one of the newest engines to come out from the Axe Rossi engine manufacturing plant, and boasts awesome all around performance.
Features:
  • Turbo Glow plug head button.
  • Bigger buster exhaust ports than the normal Cobra.
  • Plastic insert in the crankshaft for the fuel/air mixture flow path optimization.
  • Crankshaft with tungsten inserts on the flywheel for balanced performance.
  • Carburetor with heat insulation prevents fuel vaporization.
  • Crankcase with a new patented intake ports system.
  • Buster exhaust system.
Specifications:
Displacement:
 4.1cc
Horse Power:
 3.86 HP
RPM:
 42800
Bore:
 17.00 mm
Stroke:
 17.40 mm
Ports:
 7+Buster Exhaust System
Crankshaft & Type:
 14 SG+Insert
Glow Plug:
 Turbo
Weight:
 340 gr
Hide Signatures
       Post #: 11
RE: what is the most powerful 28 - 5/1/2012 9:38 PM
roadrunner ss
Score: 100
Status: online
so tell me which one is the best one out of these
Hide Signatures
       Post #: 12
RE: what is the most powerful 28 - 5/1/2012 11:43 PM
doug702
Score: 130
Last Login: 5/19/2013
Status: offline
go with an xtm 457 i have one in my xt2 it has awesome power, easy to tune and still runs like new after 6+ gallons of fuel, imo best engine for the money you will never be disapointed
yes its fast, no you cant drive it!
Hide Signatures
       Post #: 13
RE: what is the most powerful 28 - 5/1/2012 11:55 PM
yakfish
Score: 426
Last Login: 5/21/2013
Status: offline
If I was lookng for a crazy fast .28 would probably go for a Clockwork modified Novarossi Plus 28-7T. I have read alot of reviews and everybody seems to be quite impressed with it. But its pretty expensive. Since you said you wanted the best I assume price isn't much of an object.
Hide Signatures
(in reply to doug702)
       Post #: 14
RE: what is the most powerful 28 - 5/2/2012 1:33 PM
supertib
Score: 302
Status: offline
I would say my Clocked Nova 28-7T would be the fastest nastiest 28 money can buy...OS 28 will not match this engine, even after the OS is modified.....The Nova has better internal geometry and revs quite a bit higher.... I have a couple of these things running in Oval and they are tearing up the circuit and setting track records while doing it.......A HotMod 528 is just a baby compared to these bad boys !
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
(in reply to yakfish)
       Post #: 15
RE: what is the most powerful 28 - 5/2/2012 4:19 PM
roadrunner ss
Score: 100
Status: online
i try looking for one of the i can not fine that novarossi 528 no were
Hide Signatures
(in reply to supertib)
       Post #: 16
RE: what is the most powerful 28 - 5/2/2012 10:29 PM
MiamizFinest
Score: 140
Status: offline
quote:
ORIGINAL: roadrunner ss
Its crazy, i sold 2 NIB ones about a year ago after sitting in my closet for ever. The 528X pops up from time to time u just gotta look.....
-= 100 Is Only The Beginning =-
-= Made In Dade =-
Hide Signatures
       Post #: 17
RE: what is the most powerful 28 - 5/4/2012 6:05 PM
roadrunner ss
Score: 100
Status: online
 i made up my mine i know what im going to get with this engines it should get me over 100 mph i will putt picture up when i get the motor
Hide Signatures
(in reply to MiamizFinest)
       Post #: 18
RE: what is the most powerful 28 - 5/9/2012 12:13 AM
nastyboys727
Score: 105
Status: offline
yo miami one is still new im gonna send it out to rb mods then get it like dryke
tru to this not new to this
Hide Signatures
       Post #: 19
RE: what is the most powerful 28 - 6/16/2012 4:07 PM
Car-Tune
Score: 110
Status: offline
Roadrunner. Where did you find those engines?
Hide Signatures
(in reply to nastyboys727)
       Post #: 20
RE: what is the most powerful 28 - 6/17/2012 5:06 AM
roadrunner ss
Score: 100
Status: online
Harahap Hobby
< Message edited by roadrunner ss -- 6/17/2012 5:35 AM >
Hide Signatures
(in reply to Car-Tune)
       Post #: 21
RE: what is the most powerful 28 - 6/21/2012 3:43 PM
supertib
Score: 302
Status: offline
Clocked Nova 28-7T......... The fastest ,nastiest 28 .......I will put this engine against anything with confidence
here are two of my 28-7 running iin oval.....they took the entire event 1 and 2, passed the other cars like pylons and smashed the track record by 2 laps ....
So if you want a faster 28 then the other guys your not going to beat this one !
Hide Signatures
       Post #: 22
RE: what is the most powerful 28 - 6/23/2012 1:10 AM
Mufasa_719
Score: 105
Last Login: 4/17/2013
Status: offline
Damn Tib thoes are real screamers
Hide Signatures
       Post #: 23
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.719RCU1
