Forward swept wing will it turn like a normal three channel?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> Forward swept wing will it turn like a normal three channel?
Page: [1]
Login
Forward swept wing will it turn like a normal three cha... - 4/30/2012 2:47 PM
flyingagin
Score: 114
Last Login: 5/24/2013
Status: offline
  Will it turn like a normal three channel plane?
I scratch built this wing about 15 years ago and just dug it out again. It was built for an wieght caring contest. The wing is finnished other than some covering trim work. But I never finnished the oroginal plane, Due to moves etc. So the wing is all that is left
When I built this wing I discussed it with other club members, and the one big question we came up with was " would it turn correctly?" It is for a three channel plane, rudder,elevator, throttle.
Specs
polyhedral
The span is 54" STRAIGHT ACROSS TIP TO TIP
The root chord is 8"
The tip chord is 10"
The tips are actually 9" each in span by 10" chord for a total 180sq"
The center section panels are 20" x 8" (x2) for 320sq".
I am currently building the rest of the plane as just a simple box fuse  from the wing trailing edge foward and an arrow shaft boom to cary the tail feathers.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
"As for Me and My House, We Will Serve the Lord"
Club Saito Member 775
Hide Signatures
       Post #: 1
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 2:52 PM
guille2006
Score: 109
Status: offline
Thanks God you have a good dihedral there; anywa you'll need a BIG rudder to counter the yaw poor stability of that wing.
So: enlarge the rudder to increase yaw stability and shold be fine.
Hope it helps
Exocet Engineering & Design.
Hide Signatures
(in reply to flyingagin)
       Post #: 2
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 2:59 PM
soarrich
Score: 136
Status: offline
Cool wing, I think it will turn. What was your reasoning for going to larger tips. I understand the sweep forward, but not the larger tips.
Rich Border AMA 77727
Sig Kadet Brotherhood #2
Hide Signatures
(in reply to guille2006)
       Post #: 3
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 3:30 PM
flyingagin
Score: 114
Status: offline
quote:
ORIGINAL: soarrich
It was originally built for a wieght carring contest. At the extreme wieght the small .25 sized planes were carring even a very gentle resulted in the plane starting a side slip, that was not always recoverable. Not so much as a stall or tip stall but slideing sideways. Most were airleron planes modified to carry the lead box.
So I went with polyhedral and the big tips (almost PADDLES?) to help pull the low wing up. I reasoned any side ways airflow in a slip would catch that big tip and push it back up before the slip got out of control.
We all thought it was tottally wierd but worth a shot
At a contest max of 500sq" the .25 powered planes managed to lug almost 12 lbs around the pattern. Or make one whopping big crash crater in the ground.
The wing has never left the ground yet.
I have the tail feathers and boom done. Starting the fuse. Balance is going to take a rather longish nose to get the cg correct.
I have to double check my numbers but I calculated that the cg should be at the wings center section leading edge due to all the foward sweep.
Click for fullsize
Hide Signatures
(in reply to soarrich)
       Post #: 4
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 4:38 PM
Shoe
Score: 113
Last Login: 10/21/2012
Status: offline
I think what you want to know is: in what direction will this wing want to roll in response to sideslip? Forward sweep will normally make a wing roll in the opposite direction that dihedral (or polyhedral) will. The question is: which geometric feature will overpower the other? I think this is pretty easy to answer... hold the wing into the wind and give it some sideslip. Which direction does it want to roll? Is the magnitude of the roll tendency comparable to what you would feel for other designs? If the wing ends up high-mounted, that will also tend to add some roll tendency in the same direction as the polyhedral.
Hide Signatures
       Post #: 5
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 6:04 PM
flyingagin
Score: 114
Status: offline
I am thinking the first flight is going to be interesting.
Hide Signatures
(in reply to Shoe)
       Post #: 6
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 7:09 PM
soarrich
Score: 136
Status: offline
quote:
ORIGINAL: flyingagin
That's an understatement!
You will film it for us, please!
Hide Signatures
       Post #: 7
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 7:15 PM
flyingagin
Score: 114
Status: offline
quote:
ORIGINAL: soarrich
Yes
I may need the video just for future laughs
I think I will slowly add power until it gets airborn then test how it responds to rudder while low and slow.
Hide Signatures
       Post #: 8
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 8:07 PM
flyingagin
Score: 114
Status: offline
 I just did a double check of were I think the cg should be.
This is how I went at it. If this was normal non swept wing, then the cg should be at roughly 30%-33% back from the leading edge, or at or just forward of the spar.
Since the sweep is even (even the big paddle tips) I picked the mid point span wise and on the spar of each panel, and measured straight across to the wing center section. The intersection of that line and the center of the wing span is were I think the cg should be.
There is a mathematically better way of saying what I did. But for the life of me I have no idea how to say it in those terms. Would love to hear some one chime in and correct or concur with my reasoning.
I mounted the engine to the fire wall and laid the wing on top of the fuse. I also laid the tail feathers and boom on the fuse in the location it will be glued at. I then found that balance point and shifted the wing, and checked again. The actual balance point is at the wings center leading edge. It doesn't seem right but I think it is. We are so used to straight wings and balancing at the spar.
Hide Signatures
       Post #: 9
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 8:16 PM  1 votes
BMatthews
Score: 247
Last Login: 5/23/2013
Status: offline
The amount of dihedral you have will more than make up for the destabilizing effect of that fairly low sweep angle.
An old rule of thumb I've seen printed is that a thirty degree sweep is equivalent to around 5 degrees of regular dihedral. So the effective anhedral effect of the forward sweep will only cancel out a couple of degrees of your polyhedral angles. That will leave more than enough to get a nice roll response from your rudder.
Witty saying to be plagarized shortly.....
Hide Signatures
       Post #: 10
RE: Forward swept wing will it turn like a normal three... - 4/30/2012 8:29 PM
flyingagin
Score: 114
Status: offline
quote:
ORIGINAL: BMatthews
Awsome.
I will still treat the test flight very carfully till I see how well it responds. Crashing from very low and slow will leave bigger pieces to pick up.
But what you say makes perfect sense. I have heard the rules of thumb dihedral also.
I am still glad I built it the way I did. It has been the source of lots of discussions ever since.
Hide Signatures
(in reply to BMatthews)
       Post #: 11
RE: Forward swept wing will it turn like a normal three... - 5/1/2012 8:38 AM
BMatthews
Score: 247
Status: offline
Well, it does look odd what with the big "paddletips" and sweep forward look. You're obviously keen for attention from others at the field....
Hide Signatures
       Post #: 12
RE: Forward swept wing will it turn like a normal three... - 5/1/2012 11:40 AM
flyingagin
Score: 114
Status: offline
It was origainally designed for a weit carring contest.
We (some club member and I) thought the wings forward sweep would possibly be slightly more efficient.
Polyhedral eliminated a servo, and ailerons (three channel plane). A very small weight savings. It was also thought the polyhedral would help with turns over standard dihedral. At the extreme wing loading the planes had a tendency to start a slide side ways and then rather spectacular impacts with the ground. Hence the big tips (paddles?). They are 2" wider than the rest of the wing. We thought they would improve turn stability at the extreme wing loadings and help (push??) the low wing back up.
I was originally going to name it “CARGOYLE”, for cargo and gargoyle. A pun on the looks and function.
Hide Signatures
       Post #: 13
RE: Forward swept wing will it turn like a normal three... - 5/1/2012 6:13 PM
otrcman
Score: 118
Status: offline
As long as you are worrying about your swept forward wing, here's another concern: Wings of that configuration often have trouble with structural divergence. Speed and wing loading are your enemies in this respect. As you increase your wing loading the problem could become more pronounced. The two symptoms of divergence are unusually rapid roll response to gusts or rudder input and (worse) actual wing failure.
I can see from the photos that the leading edge is sheeted. That will help to make the wing stiffer in torsion. Is it also sheeted on the lower surface ? And did you put shear webs on the spar face to structurally connect the upper sheeting to the lower ? All that will help to make the wing more resistant to twisting and therefore structural divergence.
Dick
Hide Signatures
       Post #: 14
RE: Forward swept wing will it turn like a normal three... - 5/1/2012 11:15 PM
flyingagin
Score: 114
Status: offline
quote:
ORIGINAL: otrcman
Dick
Thanks for the input Dick
Wing failure was a concern when I designed it. I was fortunate to be friends with a structurall engineer at the time (fellow club member). I consulted him a lot on it.
Top and bottom are fully sheeted. Both top and bottom spars are capped with monofilament carbon fibre, both sides of both spars. I think they are also Bass wood 1/4 x 1/4. I found a unused peice of of sparring in my wood scrap box. And man are they strong. Also there is full span vertical sheer webbing between the spars (glued full face to the back of both spars.
I would really hate to get hit in the head with that wing, it is pretty darn strong. No idea how much it weighs, but it seems reasonably light.
Also the engineer had run some speed calculations on the cargo planes. He figured they would max out in level flight at 35 mph and have a stall speed of maybe 30-32 carrying a winning weight load. Obviously that just aint much margin. You barly can get off and sustain level flight. Oh and there was only 300 ft from release till wheels off the ground or you had the flight disqualified. A lot of stall thuds at the 300' mark. the first turn was just nasty. you had to clear the fence. Well at least you did not have far to walk with your trash bag.
To get the most out of the stock engines 10% nitro we were 11x4 wood props were the only thing that had a chance.
I am going to use a large diameter low pitch prop on this thing (speed will not be this wings friend), and throttle management.
Ken
this is going to be fun as long as I don't get laughed off the feild
Hide Signatures
(in reply to otrcman)
       Post #: 15
RE: Forward swept wing will it turn like a normal three... - 5/2/2012 1:42 AM
flyingagin
Score: 114
Status: offline
Ok here are a couble of pics. I am just holding the parts together for effect.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 16
RE: Forward swept wing will it turn like a normal three... - 12/26/2012 1:36 AM
flyingagin
Score: 114
Status: offline
It has been a while since I last posted on this thing. Other projects were worked on. And one plane finished and ready for test flight. My building situation became to crowded and cluttered With zero room to put any thing. So getting organized as best as I can in such a small area and cleaned up was the first order of business.
Then I resumed work on this plane. Made a fairing for the back out of $ tree foam board,paper off, to give some stream lining, and improve the looks a bit.
Then installed servos and nyrod linkages.
Put the engine on.
Now the kicker With gear installed I rechecked the balance. OH CRAP OFF BY 10 MILES. The wing has a forward sweep of 7" and with  gear in the only place it could physically fit, it really threw the cg off.
Only solution was to cut the nose off. I then taped the engine and battery to a stick and started shifting forward till I hit my balance point. Then made nose extension. Now the cg is spot on at the LE of the wing center section. Wich if measured at the mid span point of the wing puts the cg at the main spar
Click for fullsize
< Message edited by da Rock -- 12/27/2012 10:06 PM >
Hide Signatures
       Post #: 17
RE: Forward swept wing will it turn like a normal three... - 1/26/2013 10:02 PM
flyingagin
Score: 114
Status: offline
Here is an update on this funny wing plane.
I had to redo the tail boom It was to flimsy and extend the nose a bunch, like in a lot to acheive proper balance.
Took it out today to fly. We never even started the engine as it did not range check succesfully.
I will have to replace some gear then will try again.
Hey no poked fun at funny wing. They all seemed rather intrigued by this odd ball, and really want to see it fly.
I will eventually get her in the air. I think while I have this down time with it I will give it a bigger rudder. There was some concern about needing more.
Ken
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 18
RE: Forward swept wing will it turn like a normal three... - 1/29/2013 8:00 AM
eddieC
Score: 249
Status: offline
Check the full-size Hansa jet. Interesting design.
I might not be very good, but I am fun to watch!
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
