MVVS 6.5 disassembly help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 6.5 disassembly help
Page: [1]
Login
MVVS 6.5 disassembly help - 5/2/2012 10:26 PM
Stand
Score: 100
Last Login: 5/19/2013
Status: offline
I have an older MVVS (1995) engine that I need to replace the bearings. I am not having success in removing the sleeve. I have tried heating the case with a propane torch and gently prying under the bolts holding the cylinder casing to the base. I also tried using the casing bolts by unscrewing them to put pressure on the sleeve. I seems to be stuck and I don't want to beat it up taking it apart. I haven't tried putting it in an oven. And I assume that I'll have to do that to remove the bearings.
From the parts lists in Europe it looks like the sleeve should just slide up and out. I want to make sure there's not something holding it that I'm over looking.
Any suggestions?
Stan D
Never mind. I got it out. Just had to apply the heat a little more vigorously. Got apart and changed the bearings. It's all back together agian and ready to roar!
< Message edited by Stand -- 5/3/2012 12:24 AM >
_____________________________
It is irrational to fear an event, if when that event occurs we are not in existence. Epicuris
Hide Signatures
       Post #: 1
RE: MVVS 6.5 disassembly help - 5/2/2012 10:53 PM
pe reivers
Score: 646
Last Login: 5/22/2013
Status: offline
take the head off, and remove rear cover / carb. Loosen the prop drive, but do not take parts off. The prop drive taper is not self-locking, so should pop off easily.
take the 4 screws that hold the cylinder jacket out.
Heat the case until the cylinder jacket/sleeve assembly loosens. (loctite on jacket/case junction)
it now is easy to remove the sleeve/piston/jacket/conrod assy from the engine
with case still hot, and crankshaft loosened but still in place as bearing guide, tap case on a wooden block to get the rear bearing loose.
remove rear bearing, re-insert crankshaft
tap out the front bearing using the crankshaft as bearing guide
Assemble in reverse order using loctite between jacket and crankcase.
Case heating is best done with a paint stripper. Use just enough heat to get the job done (about 100°C or 200°F)
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to Stand)
       Post #: 2
RE: MVVS 6.5 disassembly help - 5/3/2012 12:26 AM
Stand
Score: 100
Status: offline
Thanks I got all done. Just needed a little more heat on the case!
Cheers
Stan D
Hide Signatures
(in reply to pe reivers)
       Post #: 3
RE: MVVS 6.5 disassembly help - 7/30/2012 4:06 AM
fiery
Score: 100
Last Login: 5/23/2013
Status: offline
Love the paint stripper idea
I use the oven (my lady hates that) or a propane torch (leaves marks sometimes, and you have to be careful to "spread" the heat.
Hide Signatures
(in reply to Stand)
       Post #: 4
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 6.5 disassembly help
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.187RCU1
