DLA 32 Throttle Return Spring Question.....>>>    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> DLA 32 Throttle Return Spring Question.....>>>
Page: [1]
Login
DLA 32 Throttle Return Spring Question.....>>> - 5/2/2012 11:50 PM
Taz_Hobbies
Score: 201
Last Login: 9/21/2012
Status: offline
Finally, after a few months the Seagull Ultimate 90 is about to hit the bench. My new DLA 32 showed up today and after giving her a quick once over I moved the throttle and man oh man is that sucker hard to move!
It has ultra smooth action so I am quite sure it is not binding. It is just some intense spring pressure.
Do you guys alter that return spring or just put a super stout servo on it for the throttle?
Thanks!
_____________________________
Taz Hobbies
Hide Signatures
       Post #: 1
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/3/2012 12:55 AM
Texastbird
Score: 150
Last Login: 5/21/2013
Status: offline
Leave the spring on, just disconnect it so it is loose. Someone will chime in saying you should leave it hooked up, though...
Hide Signatures
(in reply to Taz_Hobbies)
       Post #: 2
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/3/2012 12:51 PM
VIRGINIA MODEL BUILDERS
Score: 105
Last Login: 4/7/2013
Status: offline
DO NOT REMOVE THE SPRING. The spring is also the spacer that keeps the throttle flap in proper alignment. Just unhook the spring.
VAMODELBUILDERS
http://vamodelbuilders.com/
Hide Signatures
       Post #: 3
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/3/2012 1:41 PM
darrolair
Score: 100
Last Login: 5/22/2013
Status: offline
Leave it hooked. Any standard sized servo will work. The throttle will return to idle.
Hide Signatures
(in reply to VIRGINIA MODEL BUILDERS)
       Post #: 4
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/3/2012 1:58 PM
Taz_Hobbies
Score: 201
Status: offline
Thanks guys. It just seems like quite a bit of pressure for a servo to be working against in flight.
Maybe a longer throttle lever would be in order for a better leverage ratio?
Taz Hobbies
Hide Signatures
(in reply to darrolair)
       Post #: 5
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/20/2012 2:21 AM
kerwin50
Score: 100
Status: offline
Hide Signatures
       Post #: 6
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/20/2012 12:14 PM
Score: 105
Status: offline
When I set up an engine I remove the throttle and chocke arms.I  replace them each with a steering control arm.
VAMODELBUILDERS
Hide Signatures
       Post #: 7
RE: DLA 32 Throttle Return Spring Question.....>>... - 5/20/2012 3:56 PM
Taz_Hobbies
Score: 201
Status: offline
quote:
ORIGINAL: VIRGINIA MODEL BUILDERS
I have seen photos with what looks like glass arms on the throttle & choke. Are these fabricated, or can they be purchased?
Taz Hobbies
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.340RCU1
