3D Plane for DLE 20?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> 3D Plane for DLE 20?
Page: [1] 2   next >   >>
Login
3D Plane for DLE 20? - 5/3/2012 6:27 PM
Aviator 25
Score: 100
Last Login: 5/2/2013
Status: offline
I'm looking for a good 3D plane that won't break the bank and will easly take the DLE 20. Something with good low speed characteristics both in flight and landing.
Any ideas?
Thanks.
Hide Signatures
       Post #: 1
RE: 3D Plane for DLE 20? - 5/3/2012 7:39 PM
allans
Score: 105
Last Login: 5/17/2013
Status: offline
Aerworks makes an excellent profile with outstanding flight characteristics I think it is calle d th pro260.
But I could wrong about the name .
The DLE 20 is a perfect match for it.
_____________________________
BLACK DIRT SQUADRON ( Most Beautiful R/C Field in North America) http://www.blackdirtsquadron.org/
Hide Signatures
(in reply to Aviator 25)
       Post #: 2
RE: 3D Plane for DLE 20? - 5/3/2012 9:14 PM
ThumbSkull
Score: 108
Last Login: 5/18/2013
Status: offline
The Aeroworks ProX260 is great at high speed aerobatics and sport flying. It is NOT great at low and slow 3D or tumbling.
I would recommend building a Swanyshouse MoJo65 or Balsastore Sbach65. WWRC (Wrongway) is also just releasing a 20CC bird.
Hide Signatures
(in reply to allans)
       Post #: 3
RE: 3D Plane for DLE 20? - 5/3/2012 11:09 PM
Rotten40851
Score: 110
Last Login: 5/19/2013
Status: offline
I have a seagull 90 size Yak 54 with a 20 cc DLE in it. It is AWESOME!!! and it was only 170 bucks.  just make sure if you get one to NOT use the CA hinges! Use Du-Bro Nylon or Robart Pin Hinges.
Futaba 18 MZ... Nothing even comes Close!!!
Hide Signatures
(in reply to ThumbSkull)
       Post #: 4
RE: 3D Plane for DLE 20? - 5/3/2012 11:29 PM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
quote:
ORIGINAL: ThumbSkull
I would recommend building a Swanyshouse MoJo 65
+1 on that recommendation.
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
       Post #: 5
RE: 3D Plane for DLE 20? - 5/4/2012 12:08 AM
zacharyR
Score: 105
Status: offline
http://www.3dhobbyshop.com/68-VeloxBlue_p_15303.html
these are good 20cc bird's
Hide Signatures
(in reply to aussiesteve)
       Post #: 6
RE: 3D Plane for DLE 20? - 5/4/2012 3:32 AM
nitro wing
Score: 125
Status: offline
Zach loves 3dhs birds, and most who own one, do.
I'll actually agree with him on the Velox, a nice change from the average run of the mill plane.
The AW maybe more suitable if confidence level is lower, The velox is not meant to be cart-wheeled across the runway.
Hide Signatures
(in reply to zacharyR)
       Post #: 7
RE: 3D Plane for DLE 20? - 5/4/2012 3:42 AM
Aviator 25
Score: 100
Status: offline
I'm kinda leaning towards something ARF, I just lost a plane to gravity and wan't to get back to flying ASAP now that the weather is good. Any good ARFs out there besides the Pro260 or am I doomed to build?
Hide Signatures
       Post #: 8
RE: 3D Plane for DLE 20? - 5/4/2012 6:28 AM
nitro wing
Score: 125
Status: offline
The Velox is ARF for sure, yeah its a bit more spendy, but it will fly and be more enjoyable than less expensive models.
There are lots of choices, really depends on skills and $$ available.
Being in Canada makes things a bit more difficult
Hide Signatures
       Post #: 9
RE: 3D Plane for DLE 20? - 5/4/2012 11:02 AM
ThumbSkull
Score: 108
Status: offline
Building a profile isn't that difficult, even for a first time builder. If you are just learning 3D, you want something less fragile than the Velox. They are decent flyers, but a profile built around a fiberglass tube like the ones I mentioned above will take some hits.
Hide Signatures
(in reply to nitro wing)
       Post #: 10
RE: 3D Plane for DLE 20? - 5/4/2012 4:18 PM
raydar
Score: 142
Last Login: 5/9/2013
Status: offline
the new peak/redwing/aerobees yak profile flys really well, it has a big wing at 1050 sq/in and weighs 7 pounds 8 oz dry, designed around the dle 20 and no lead is required to balance. And its cheap in the USA.
The down side is its not strong unlike a kit profile, like most arfs one bad crash she will be destroyed.
My next profile will be a swanyhouse mojo 65 unless someone brings out another arf that is stronger.
Just want to say im in no way linked to the sale of these models.
Specifications:
Wing Span: 65"
Length: 61.1"
Wing Area: 1029 sq. in
Flying Weight: 6.8lbs
Engine Size: 20cc
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 11
RE: 3D Plane for DLE 20? - 5/7/2012 1:27 AM
F4U Corsair
Score: 125
Last Login: 5/8/2013
Status: offline
quote:
ORIGINAL: zacharyR
I have one, and yes they are great 3D airframes, but unfortunately being redesigned ( should be available this summer hopefully). I too have a Swanny Mojo and dig it as well.
Experience is something you aquire after you need it!
Hide Signatures
       Post #: 12
RE: 3D Plane for DLE 20? - 5/10/2012 2:12 AM
Uncas
Score: 105
Status: offline
How about a Great Planes Reactor Bipe?
Hide Signatures
(in reply to F4U Corsair)
       Post #: 13
RE: 3D Plane for DLE 20? - 5/10/2012 4:13 AM
dm8221
Score: 100
Last Login: 5/4/2013
Status: offline
Hi Aviator 25
One or club members flies a Great Planes U-Can-Do 60 with a DLE 20 it might be another option.
Cheers Don
Hide Signatures
(in reply to Uncas)
       Post #: 14
RE: 3D Plane for DLE 20? - 5/10/2012 9:07 AM
TimBle
Score: 162
Status: online
quote:
ORIGINAL: Aviator 25
Any ideas?
Thanks.
hangar 9 Funtana 125 seems popular and flies well.
Hide Signatures
       Post #: 15
RE: 3D Plane for DLE 20? - 5/10/2012 6:23 PM
Ernie Misner
Score: 130
Status: offline
I have a NIB Aeroworks Prox260 profile if anyone is interested...... I already have one flying too.
Ernie Misner
Hide Signatures
(in reply to TimBle)
       Post #: 16
RE: 3D Plane for DLE 20? - 5/11/2012 4:16 AM
zacharyR
Score: 105
Status: offline
shocking a Funta ...and even a U can do ... shocking !
P.S i would pick the aero works Full fused 260 over the the profile 260 IMO,
Hide Signatures
       Post #: 17
RE: 3D Plane for DLE 20? - 5/11/2012 10:09 PM
KWJ48
Score: 103
Status: offline
+ 1 on building any of the mentioned kits. It doesn't take long at all. Here's my Balsastore Sbach 65.
Click for fullsize
Click for fullsize
PRO BRO #2567
Hide Signatures
       Post #: 18
RE: 3D Plane for DLE 20? - 5/12/2012 3:30 AM
acerc
Score: 221
Last Login: 5/20/2013
Status: offline
Here's my Mojo 65, 20cc. Total build time- 3 days. Will sit still in one spot or anything your thumbs can come up with.
Click for fullsize
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to KWJ48)
       Post #: 19
RE: 3D Plane for DLE 20? - 5/12/2012 4:44 AM
ThumbSkull
Score: 108
Status: offline
Very nice double flag scheme there acerc !
Hide Signatures
(in reply to acerc)
       Post #: 20
RE: 3D Plane for DLE 20? - 5/12/2012 6:59 AM
kerwin50
Score: 100
Status: online
I have a buddy that doesn't like his Pro 260
Now if I don't harrier land it how much area does it take to bring a mojo in.
My field at home is only a 40 size field.
Hide Signatures
       Post #: 21
RE: 3D Plane for DLE 20? - 5/12/2012 6:10 PM
acerc
Score: 221
Status: offline
As little as you need. The plane is capable of zero runway, anything beyond that is up to your ability. I have walked along side of mine. So how slow you can go is how slow you go. I will also say as little as possible, those gear are not for rolling far.
Robert
Hide Signatures
(in reply to kerwin50)
       Post #: 22
RE: 3D Plane for DLE 20? - 5/13/2012 5:11 AM
zacharyR
Score: 105
Status: offline
doesn't look like your elevator is even in that picture ace .....
Hide Signatures
(in reply to acerc)
       Post #: 23
RE: 3D Plane for DLE 20? - 5/15/2012 9:50 PM
acerc
Score: 221
Status: offline
How about this view?
Click for fullsize
Robert
Hide Signatures
       Post #: 24
RE: 3D Plane for DLE 20? - 5/15/2012 11:34 PM
closetguy
Score: 166
Status: offline
i am surprise no one has mention the OMP Fusion,it has got to be one of the top three planes to fly in 3d or imac,very percise flying plane,no bad habbits that i can find,and it's a ARF.
Hide Signatures
(in reply to acerc)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
