loosing signal    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> loosing signal
Page: [1] 2 3   next >   >>
Login
loosing signal - 5/4/2012 1:32 AM
dkcollord
Score: 100
Last Login: 8/20/2012
Status: offline
can anyone help me, been flying for about a year now and have got quite good at it, but have one problem my planes keep loosing signal. and cant figure out why. first with my dx6i, now with my dx8, could my cell phone be the problem ? I usually have it close to me and now starting to think its the problem.
Hide Signatures
       Post #: 1
RE: loosing signal - 5/4/2012 2:15 AM
Handiman
Score: 100
Last Login: 2/14/2013
Status: offline
To give yourself a good chance to figure this problem out you need to think of everything that is occurring, what is around you, what is different, what has changed? It is very important that if you change something change only 1 at a time and give it a good test. Try and keep the scenario as close as possible to the exact same things each time.
For others to give you advice you need to give very accurate and specific information.
Have you read the manuals for the product you are using. A lot of the time a issue like this is a very simple, small item that is being over looked because it is something that you always have done or it seems like it wouldn't matter.
And be willing to admit that it was something very simple to over look. We have almost all do it or will do it. It happens.
1st - What are the symptoms that you are having?
2nd - What have you tried?
3rd - what do you think it might be?
PS, I fly with my cell phone and about 10+ others within 20-50ft. More than likely not. I have a DX8 and 4 different receivers.
_____________________________
Handiman
DX8 / AR8000''s with Telemetry
Hide Signatures
(in reply to dkcollord)
       Post #: 2
RE: loosing signal - 5/4/2012 2:29 AM
wedreagle
Score: 100
Last Login: 3/27/2013
Status: offline
Try range checking your receiver. I lost two planes with a receiver that lost signal after about 75 feet from the plane on the ground.
Hide Signatures
(in reply to Handiman)
       Post #: 3
RE: loosing signal - 5/4/2012 2:32 AM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
What is your exact switch on sequence?
Are the Rx lights flashing or steady when switched on and booted up?
Do you rest your Tx flat on the ground once switched on?
What is your exact bind method?
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
(in reply to wedreagle)
       Post #: 4
RE: loosing signal - 5/4/2012 3:14 AM
dkcollord
Score: 100
Status: offline
it has hapened with 5 diff. receivers. ar500, ar600, ar7000 ar6210 and a ar6200. all bound and range checked flown . all lights on on rec. then batt unpluged radio shut off after a few min. while neighbor flew radio turned back on batt. pluged to plane range checked take off and then have a lock up. I have lost 2 bnf parkzones a 3dhs edge with about 30 flights on it then one lockup, and now my eflight 300 with about 18 flights on it.
Hide Signatures
       Post #: 5
RE: loosing signal - 5/4/2012 3:28 AM
dkcollord
Score: 100
Status: offline
yes i have set my radio flat on the ground,  but not every time, will that affect it?
Hide Signatures
(in reply to aussiesteve)
       Post #: 6
RE: loosing signal - 5/4/2012 1:04 PM
karolh
Score: 310
Last Login: 5/20/2013
Status: offline
Sounds like it's an intermittent problem as you get several flights in between and then it occurs again. Try using a different Transmitter and see if that makes a difference.
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 7
RE: loosing signal - 5/4/2012 1:51 PM
dkcollord
Score: 100
Status: offline
I just purchassed a new dx8 and had 8 good flights with it ,on two diff. planes now a glitch in the last one, the only thing i can think of is my cell is in my pocket right next to my radio when im flying
Hide Signatures
(in reply to karolh)
       Post #: 8
RE: loosing signal - 5/4/2012 3:43 PM
jester_s1
Score: 233
Last Login: 5/18/2013
Status: offline
Cell phones don't affect radios. I don't mean to bash, but threads like this about Spektrum equipment are so common that I'll never buy or recommend the brand. One common issue though is voltage at the receiver. If you'll make an extension that you can connect a multimeter to, you can check the actual voltage the receiver is getting under flight loads by manually flexing a control surface. With a little luck, you'll be able to induce a reboot and verify your problem.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
       Post #: 9
RE: loosing signal - 5/4/2012 5:08 PM
Rodney
Score: 169
Last Login: 5/19/2013
Status: offline
About the only thing certain here is that it is NOT your cell phone causing the problem, that is nearly a technical impossibility. When you do your range checks, do it with the plane in the worst possible attitude, i.e. your transmitter antenna pointing at the plane and with the planes antenna pointing at the transmitter and, if any conductive items in the plane, have them between the transmitter and receiver antennas.
Hide Signatures
(in reply to jester_s1)
       Post #: 10
RE: loosing signal - 5/4/2012 5:23 PM
BuschBarber
Score: 104
Status: offline
Borrow or buy a Spektrum Flight Logger and do some Range Checks with a friend holding the aircraft at different attitudes, in a 360 deg circle.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Rodney)
       Post #: 11
RE: loosing signal - 5/4/2012 7:31 PM
pdm52956
Score: 140
Last Login: 5/14/2013
Status: offline
What kind of battery are you using at the rx and what is the voltage when this "signal loss" occurs?
Have you checked it with a volt meter that puts a load on the battery?
Also, there have been numerous reports of issue with the AR500. I don't believe they even make it anymore but I could be mistaken. I've also heard of issues with the AR600. If it were me, I'd loose them to begin with.
Hide Signatures
(in reply to BuschBarber)
       Post #: 12
RE: loosing signal - 5/5/2012 1:14 AM
AndyKunz
Score: 116
Last Login: 5/17/2013
Status: offline
If you have a smart phone with WiFi enabled and it's talking to a hot spot, it isn't helping the situation. Cell phones belong on workbenches while you're flying. You can't use it while your out there. At least if it rings, somebody in the pits can answer it for you and tell them you'll call back after you land.
Are you flying equipment that has crashed?
Have you contacted Service and arranged to have your transmitter and receivers checked out?
How are you powering the receivers? What other equipment is in the aircraft? How tight are the linkages? You have a DX8, what's the telemetry telling you about the voltage when you wiggle the servos?
Andy
Andy Kunz - AMA 46063
Spektrum Development Team
Hide Signatures
(in reply to pdm52956)
       Post #: 13
RE: loosing signal - 5/5/2012 1:23 AM
dkcollord
Score: 100
Status: offline
I have a older verizon phone, im guessing about 7 years old. All my batteries have a full charge. is their a receiver better then the other? I have a new 8000 that came with the radio, using it on my new hyperion yak, but have a new ar 6210, is that receiver ok for the  eflight 300 when i rebuild it?
Hide Signatures
(in reply to AndyKunz)
       Post #: 14
dirtybird
Score: 173
Status: offline
I once saw a cell phone cause a crash.
This fellow was flying his airplane and his cell phone rang.
He set his transmitter down and answered the phone.
Meanwhile his airplane went sailing off into the blue.
Hide Signatures
       Post #: 15
RE: loosing signal - 5/5/2012 1:41 AM
BuschBarber
Score: 104
Status: offline
Honestly, I have had a cell phone on my hip for years, at every event I have attended and every time I am at the flying field. Never an issue. I have never had the need to turn on Wireless Hotspot at the field. I am sure those using the iPhone and the STI module don't have anything in the phone disabled when using it on the flight line.
I have even answered a call while spotting for a friend, numerous times.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to dirtybird)
       Post #: 16
RE: loosing signal - 5/5/2012 2:26 AM
essyou35
Score: 100
Status: offline
Dx8 always lose signal, get rid of it.  I had massiv eproblems with mine and using dsm2 Rxs.  This is a very common thing.  I've barely had issued with dx6i though.
Hide Signatures
       Post #: 17
RE: loosing signal - 5/5/2012 2:53 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: essyou35
I have used my DX8 with DMS2 and DMSX without any issues.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to essyou35)
       Post #: 18
RE: loosing signal - 5/5/2012 2:59 AM
Javier-RCU
Score: 105
Status: offline
Have you bluetooth active in yout cell phone while in flight?
When you know the paradise?... When you lost it!
Hide Signatures
       Post #: 19
RE: loosing signal - 5/5/2012 3:04 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: Javier-RCU
Yes!! I use a Bluetooth headset while flying.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Javier-RCU)
       Post #: 20
RE: loosing signal - 5/5/2012 3:54 AM
lopflyers
Score: 140
Status: offline
quote:
ORIGINAL: dirtybird
Now, this is funny. You have to be really dumb to answer your phone while you are flying
Keep your wings level
Club Saito Member #693
Hide Signatures
       Post #: 21
RE: loosing signal - 5/5/2012 6:15 AM
essyou35
Score: 100
Status: offline
Unless it was a really hot chick.
Hot Chicks > Rc Airplanes
quote:
ORIGINAL: lopflyers
Hide Signatures
(in reply to lopflyers)
       Post #: 22
RE: loosing signal - 5/5/2012 12:44 PM
skipper_gr
Score: 100
Status: offline
In an old Air Force term this sounds like a"short between the Headsets"
Hide Signatures
       Post #: 23
RE: loosing signal - 5/5/2012 2:41 PM
miker49
Score: 100
Status: offline
you can't even enjoy a day of flying without your phone?
Hide Signatures
(in reply to skipper_gr)
       Post #: 24
RE: loosing signal - 5/5/2012 4:15 PM
dkcollord
Score: 100
Status: offline
Its not that, I have 80 acres out side my back door,  with a mowed landing strip and fly almost every day. My wife has been sick for two years now and this is my chance to get away for a short time, but still be able to be " just a call away"
Hide Signatures
(in reply to miker49)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
