Hobbywing vs Velineon Motor?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> Hobbywing vs Velineon Motor?
Page: [1]
Login
Hobbywing vs Velineon Motor? - 5/4/2012 4:26 PM
rcmodelland
Score: 100
Last Login: 7/19/2012
Status: offline
Hey guys-
So I'm thinking I'll up the ante one of these days (sooner than I think probably). Currently I'm running the cheapy Hobbywing 35A ESC/3000KV motor in the Dominus - actually a great combo, IMO, for the track I'm running on - outdoor mix of loose dirt and hardpack - and I'm actually very happy. Had great fun dicing with a 2WD Slash over the weekend. My 4X4 helped make up for less power - and the Slash rolled a TON more than my Dominus - a ton more. But I'll want more speed soon. Thinking I'll upgrade the motor/ESC to something more powerful that will likely eventually find its way into Losi SCTE roller in a few months or so....so as of now my plan is to get the Hobbywing 120A Waterproof SC8 ESC. Motor: I was thinking the Hobbywing 10T 3500KV or the Velineon. Both around $60. Is one better than the other? (if so why?) And is there a better motor for equal, or better yet, LESS money?
thoughts appreciated - thanks.
Hide Signatures
       Post #: 1
RE: Hobbywing vs Velineon Motor? - 5/4/2012 5:35 PM
cummins driver
Score: 214
Last Login: 3/1/2013
Status: offline
Id go with a motor more powerful than the velineon. Something 4 pole or larger can sized.
_____________________________
- Savage - MGT Pulling Truck - Losi LST2 - Brushless Blitz - RC10GT (getting a 2.5) - Brushless T4 - Sportwerks Mayhem Pro
Hide Signatures
(in reply to rcmodelland)
       Post #: 2
RE: Hobbywing vs Velineon Motor? - 5/4/2012 8:11 PM
nitrosportsandrunner
Score: 296
Last Login: 5/19/2013
Status: online
if you are looking at a hobbywing, and a vxl which have about the same power and the same cost...
then get the one which is waterproof, and which will come with a warrenty..IE the traxxas vxl.
Im not saying the hobbywing is bad, its just as good as the vxl IMO. but if the hobbywing fails who do you send it to? Good luck getting it replaced.
I have had traxxas replace (for free) 4 vxl ESC's and 1 vxl motor over the past 4 years. They are a big company(which has good and bad points) but their customer service is top notch.
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to cummins driver)
       Post #: 3
RE: Hobbywing vs Velineon Motor? - 5/4/2012 8:17 PM
SyCo_VeNoM
Score: 621
Status: offline
I'd go with a 1800-2000kv motor, and run it on 4S if you are looking at the 120A HW ESC
I ran the slash 4X4 (when it was still one) on a 60A HW setup and it got damn hot.
I run my pede 4X4 (was a slash 4X4) with a 3500kv motor(bigger can from HK) on the 120A HW and it still gets pretty damn hot.
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 4
RE: Hobbywing vs Velineon Motor? - 5/5/2012 4:14 AM
Score: 296
Status: online
quote:
ORIGINAL: SyCo_VeNoM
personally, i wouldnt run either 4x4 on 4s (even with a lower KV motor)
Reason being that the spur gear and driveshafts will not last long.
My buddy had a 150a system and 2000kv motor on 3s and he rarely got more than 5 minutes of runtime before a spur gear or driveshaft broke. Its simply more torque than the truck was meant to handle.
so then he dropped $100 on front/rear MIP metal driveshafts. He broke the front MIP driveshafts the 1st day. And this guy doesnt beat on his truck either. Its just that the slash/pede 4x4 are scaled up 1/10 2wd trucks with 4wd systems made to fit.
The 1/8 scale brushless systems and 4s lipo used in many 1/8 4wd trucks is different. the chassis was built to handle it.
syco, HOW hot were those systems getting? And what was the gearing? Did you gauge temps by touch or a gauge? 160 for the ESC and 180 for the motor is OK if you are running 3s.
I wouldnt use the HW 60a ESC either. If hobbywing, Id use at least the 80amp esc.
But using a true 540can 3000-3500kv motor is fine. Just gear it with the stock pinion.
Adding more torque will just mean lots of broken driveline parts.
Heat sink/fan on the motor always helps as well.
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 5
RE: Hobbywing vs Velineon Motor? - 5/5/2012 4:43 AM
SyCo_VeNoM
Score: 621
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
2S on the SC8 ESC (120A) and http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6673
and yea I couldn't find my thermometer so I was going by touch.
ohh yea as for the 60A HW setup I did have my thermometer that day it was over 150 after 6 minutes motor was 160 on 2s (but it was the 4000kv motor) I also used the lowest pinon I could get in the slash.
I'm gonna guess a 3000kv motor might work best in it.
You do got a god point about the crap drive chain Traxxas uses. I wasn't thinking about that when I said 1800kv on 4S I can only imagine how bad that would rip it up
Hide Signatures
       Post #: 6
RE: Hobbywing vs Velineon Motor? - 5/5/2012 2:57 PM
Score: 296
Status: online
yeh, the slash and pede 4x4's are fun, but not built like 1/8 4x4 chassis are.
The slider shafts are fine for brushless and lower power brushless systems, but traxxas really needs to think about dogbones or CVDs on their bigger 4wd stuff.
And the MIP shafts are silly to. Yes, they are tough but why hasnt anyone come up with a simply drivecup/dogbone setup? CVD's always seem to have an issue with the set screws/pins coming loose.
Anyway, a properly geared traxxas vxl motor....with a heat sink is probly best for the slash/pede 4x4. As for the ESC the HW 120a will certainly do the job...just dont run more than 3s.
Hide Signatures
       Post #: 7
RE: Hobbywing vs Velineon Motor? - 5/5/2012 6:22 PM
pyromatic177
Score: 255
Last Login: 4/18/2013
Status: offline
I'm pretty happy with Hobby Wings stuff. I have the Xerun in my E-revo
!!!Bash Like There''s No Repair Bills!!!
Hide Signatures
       Post #: 8
RE: Hobbywing vs Velineon Motor? - 5/6/2012 3:23 AM
phmaximus
Score: 627
Status: offline
U can't compare the velineon to most of the hobby wing combos...
IMO the velineon only compares to the 35a combo... But even then the HW is a lot safer on 3s.
Why the hell would u need a 120a combo in a SCT?...
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to pyromatic177)
       Post #: 9
RE: Hobbywing vs Velineon Motor? - 5/6/2012 3:43 AM
pyromatic177
Score: 255
Status: offline
Yeah i really like HW
Hide Signatures
(in reply to phmaximus)
       Post #: 10
RE: Hobbywing vs Velineon Motor? - 5/6/2012 10:45 PM
SyCo_VeNoM
Score: 621
Status: offline
quote:
ORIGINAL: phmaximus
well in my case it is now a pede 4X4 running HPI bullet rims/tires, but easy the motor I got was rated 90A(originally wanted a 100A motor, but alas after 4 months of waiting for it to be in stock I got impatient) which is over the SC10's 80A limit
I also figured if I ever get sick of the pede I could buy a 1850kv motor, and a 1/8th scale buggy roller, and not have to re-buy the ESC
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
