Anyone figure out how to mount a Homelite 26cc?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> Anyone figure out how to mount a Homelite 26cc?
Page: [1]
Login
Anyone figure out how to mount a Homelite 26cc? - 5/5/2012 7:43 AM
rangerfredbob
Score: 115
Last Login: 5/16/2013
Status: offline
I've been cleaning the garage out a bit the last couple weeks, and finally got to my engine shelf (just reorganized the outside parts, it's quite full) and happened across the couple Homelite Mighty Light 26cc engines I stashed away. It looks like a decently built engine but the angled back plate looks to make mounting interesting... I figure it could be done but would get complex, either go off the flywheel shroud or make a plate that goes to the back plate screws and wraps around the back... I have one that has a broken pull start (go figure, plastic parts held together with a spring expected to hold together starting an engine) that might as well be stripped and prepped for prop use.
I have one still running that I'm going to attempt to make a trolling motor out of, so far found out the carb needs rebuilt...
Hide Signatures
       Post #: 1
RE: Anyone figure out how to mount a Homelite 26cc? - 5/5/2012 1:52 PM
w8ye
Score: 318
Last Login: 5/20/2013
Status: offline
Pictures might garner some comments?
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to rangerfredbob)
       Post #: 2
RE: Anyone figure out how to mount a Homelite 26cc? - 5/5/2012 7:11 PM
rangerfredbob
Score: 115
Status: offline
Here ya go, it was kinda late when I was thinking about it last night
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: Anyone figure out how to mount a Homelite 26cc? - 5/8/2012 2:02 PM
earlwb
Score: 584
Status: offline
You use four standoff spacers on the four tabs where they screw on the cooling shroud.
They sell the spacers in all kinds of lengths and sizes for other gas engines, so it shouldn't be a problem to find them.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
       Post #: 4
RE: Anyone figure out how to mount a Homelite 26cc? - 5/8/2012 2:59 PM
rangerfredbob
Score: 115
Status: offline
hmm, wouldn't be my first choice... I think I'm just going to convert it and use it for a backup for the 4 stroke engine I have for my airboat that mounts by the shroud also since it's oil pan is angled like this back plate
Hide Signatures
(in reply to earlwb)
       Post #: 5
RE: Anyone figure out how to mount a Homelite 26cc? - 5/8/2012 9:34 PM
grant-RCU
Score: 100
Last Login: 3/1/2013
Status: offline
Has the old style 25cc been discontinued?
Hide Signatures
       Post #: 6
RE: Anyone figure out how to mount a Homelite 26cc? - 5/8/2012 10:21 PM
av8tor1977
Score: 665
Last Login: 5/19/2013
Status: offline
If you take a look at the newer Ryobi machines, most of them I've seen have 30cc Homelites on them. (The Homelite 30 looks identical to the old Homelite 25cc, and is actually about an ounce or so lighter.)
If you want a Homelite 25cc real cheap, send me a private message, as I have several I don't need.
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to grant-RCU)
       Post #: 7
RE: Anyone figure out how to mount a Homelite 26cc? - 6/18/2012 7:08 PM
oddy
Score: 100
Last Login: 4/12/2013
Status: offline
So no one has figured out how to mount this engine to the firewall other than the spacers.
Regards.
VA
< Message edited by oddy -- 6/18/2012 10:32 PM >
If I say that the Burra is Prieta is because I have the pelos in my hand.
Hide Signatures
(in reply to av8tor1977)
       Post #: 8
RE: Anyone figure out how to mount a Homelite 26cc? - 8/8/2012 11:08 PM
earlwb
Score: 584
Status: offline
I didn't think about the angled backplate. But I would fabricate a angled motor mount box to fit it and use slightly longer screws if needed. Then you can bolt up the angled box to the firewall. I would simply use good 1/4 inch plywood for it (the model airplane ply not the cheap hardware store wall panels).  It is sort of like the wood motor boxes they use for electric motors in the model airplanes.  One could make it out of aluminum but I don't see a problem with using good plywood for the motor mount box. The front of the box is angled to match the engine backplate area and the rear of the box is straight up and down to match the firewall. You also have a couple of wedge like side pieces and maybe a bottom rectangular shaped piece.  I hope it makes sense, as I can visualize it really well in my mind.
AMA # 928076
Hide Signatures
(in reply to oddy)
       Post #: 9
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> Anyone figure out how to mount a Homelite 26cc?
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
