RE: AJ-2 Construction Revisited    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-40 Racing >> RE: AJ-2 Construction Revisited Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: AJ-2 Construction Revisited - 5/27/2012 12:48 AM
sahartman21
Score: 110
Last Login: 5/5/2013
Status: offline
On the second wing the hole overlapped the carbon fiber laminant. Don't cut the carbon as it provides strength at the wing center section.
I slid the 1/8" thick plywood plate under the carbon fiber and left it intact.
The wing center section is covered with several layers of fiberglass cloth. The carbon laminant will not be exposed.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to sahartman21)
       Post #: 26
RE: AJ-2 Construction Revisited - 5/27/2012 3:41 AM
sahartman21
Score: 110
Status: offline
Temporarily attach the wing with masking tape.
Locate the rear wing mounting holes
Remove the wing and use a hole drill as needed.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 27
RE: AJ-2 Construction Revisited - 5/27/2012 7:27 PM
sahartman21
Score: 110
Status: offline
Pieces of 3/4" diameter dowels are glued in place with an epoxy micro-balloon mix.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 28
RE: AJ-2 Construction Revisited - 5/27/2012 7:29 PM
sahartman21
Score: 110
Status: offline
One inch square pieces of 1/4" thick plywood are glued in place with Shoe Goo.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 29
RE: AJ-2 Construction Revisited - 5/28/2012 2:23 AM
D.E.
Score: 100
Last Login: 4/28/2013
Status: offline
looks good,,,, two is better than one! and can be built almost as fast as one.
how are you getting your pics to load? I tried a couple of times but got error message both times.
DE
Hide Signatures
       Post #: 30
RE: AJ-2 Construction Revisited - 5/28/2012 3:40 AM
sahartman21
Score: 110
Status: offline
I set the camera at low resulution.
When loading I have to load 1 picture at a time.
Scott
Hide Signatures
(in reply to D.E.)
       Post #: 31
RE: AJ-2 Construction Revisited - 5/28/2012 4:08 AM
sahartman21
Score: 110
Status: offline
Here are some pictures of servo tray installation.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 32
RE: AJ-2 Construction Revisited - 5/29/2012 12:58 AM
sahartman21
Score: 110
Status: offline
Here are some pictures of the wing tip installation:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 33
RE: AJ-2 Construction Revisited - 5/29/2012 1:02 AM
sahartman21
Score: 110
Status: offline
A piece of window sheer is tacked in place using 3M77. This plus the fiberglass cloth makes the aileron hinge.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 34
RE: AJ-2 Construction Revisited - 5/29/2012 1:05 AM
sahartman21
Score: 110
Status: offline
Some 2 ounce fiberglass cloth was used instead of 3/4 ounce cloth.
Three more layers of fiberglass cloth were tacked in place at the wing center section. The widths were approximately 11", 9", and 7 ".
Approximately 1.5 ounces of finishing epoxy was used on each side of the wing or a total of 3 ounces of finishing epoxy.
The wing was then placed between layers of peel ply (nylon fabric) and placed in a vacuum bag. The finishing epoxy needs to dry approximately 8 to 12 hours before attempting to remove the wing from the peel ply.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 35
RE: AJ-2 Construction Revisited - 6/1/2012 3:03 AM
sahartman21
Score: 110
Status: offline
The wing was removed from the peel ply and it was cleaned up a little.
I use a sanding block to trim the excess fiberglass from the trailing and leading edges.
Lightweight Spackle is spread on with a squeegee to fill up the pores and low areas.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 36
RE: AJ-2 Construction Revisited - 6/4/2012 1:14 AM
sahartman21
Score: 110
Status: offline
Here are some pictures of adding the aileron torque rods and making the skinned hinges.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 37
RE: AJ-2 Construction Revisited - 6/4/2012 1:18 AM
sahartman21
Score: 110
Status: offline
The wing is still light at this point. It weighs about 15.55 ounces.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 38
RE: AJ-2 Construction Revisited - 6/6/2012 3:33 AM
sahartman21
Score: 110
Status: offline
The aileron servo is installed in the following pictures.
This method avoids cutting a big hole in the top of the wing that can reduce wing strength.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 39
RE: AJ-2 Construction Revisited - 6/11/2012 2:39 PM
sahartman21
Score: 110
Status: offline
The wing and landing gear are installed in the following pictures:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 40
RE: AJ-2 Construction Revisited - 6/11/2012 7:11 PM
PylonDave
Score: 100
Last Login: 5/19/2013
Status: offline
Do you tape the belly pan on or is it glued??
Hide Signatures
       Post #: 41
RE: AJ-2 Construction Revisited - 6/11/2012 7:41 PM
sahartman21
Score: 110
Status: offline
At this point the belly pan is just stuck in place with tape.
You can build it like you want it. If you glue it on, then there needs to be a split to allow for the landing gear.
Hide Signatures
(in reply to PylonDave)
       Post #: 42
RE: AJ-2 Construction Revisited - 6/11/2012 7:53 PM
sahartman21
Score: 110
Status: offline
The horizontal tail surfaces are shaped in the following pictures:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 43
RE: AJ-2 Construction Revisited - 6/11/2012 7:57 PM
sahartman21
Score: 110
Status: offline
A layer of window sheer is tacked in place on the top surface.
Additional pieces of 2 ounce fiberglass cloth is applied over both the top and bottom surface.
Finishing epoxy is squeegeed over the surface.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 44
RE: AJ-2 Construction Revisited - 6/11/2012 7:59 PM
sahartman21
Score: 110
Status: offline
The tail surfaces are placed between layers of peel ply and placed in the vacuum bag.
The bag consists of 4 mil plastic sealed with latex caulking.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 45
RE: AJ-2 Construction Revisited - 6/11/2012 10:18 PM
sahartman21
Score: 110
Status: offline
The tail surfaces were removed and cleaned up with a sanding block.
Lightly sand the surface with 220 grit sandpaper on a sanding block.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 46
RE: AJ-2 Construction Revisited - 6/16/2012 11:26 PM
sahartman21
Score: 110
Status: offline
Some planning was done on routing of the flexible cable.
Use a nylon connector with the metal control horn. This prevents the hole in the control horn from gradually wearing and getting too big.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sahartman21 -- 6/18/2012 1:30 AM >
Hide Signatures
       Post #: 47
RE: AJ-2 Construction Revisited - 6/16/2012 11:28 PM
sahartman21
Score: 110
Status: offline
A slot is cut with an exacto blade.
This is followed with a cut off wheel.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 48
RE: AJ-2 Construction Revisited - 6/16/2012 11:31 PM
sahartman21
Score: 110
Status: offline
A large control horn is made from 3/32" wire, wheel collars, and sheet metal.
Parts are soldered together with silver solder.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 49
RE: AJ-2 Construction Revisited - 6/16/2012 11:34 PM
sahartman21
Score: 110
Status: offline
The control horn is tacked in place with CA glue.
A mixture of finishing epoxy and micro-balloons is applied in the gap.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
