RE: Powerbox iGyro    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Powerbox iGyro
Page: <<   < prev  1 2 [3] 4 5 6 7 8   next >   >>
Login
RE: Powerbox iGyro - 5/14/2012 7:08 AM
gonzalom
Score: 100
Last Login: 6/18/2013
Status: online
I have some fantastic results using the Powerbox systems on all my planes. I wonder how the new iGyro can be plug to the Powerbox Royal Spectrum.
Gonzalo
Hide Signatures
(in reply to Andrew Bailey)
       Post #: 51
RE: Powerbox iGyro - 5/14/2012 11:12 AM
Dave Wilshere
Score: 108
Status: offline
Gonzalo
Sorry the iGyro isnt supported by the Royal or Evolution PB as they are not BUS system units.
Regards
Dave
_____________________________
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to gonzalom)
       Post #: 52
RE: Powerbox iGyro - 5/14/2012 11:49 AM
ww2birds
Score: 105
Status: offline
Dave,
Do you know if the Robbe/Futaba S-BUS PSS-2018 "powerbox" (see: http://shop.rc-electronic.com/e-vendo.php?shop=k_emcotec_e&SessionId=&a=article&ProdNr=RF1660&t=861&c=1786&p=1786 ..they call it a "power supply" ) might acutally be OEM'd from the Powerbox guys?
I note that while marketed toward Futaba users, the unit also can attach JR/Spek-style satellite receivers. I recently got one shipped over from Emcotec and it's quite nice but does have a bit of the PB look and feel. Nice unit, btw.
Thanks for the info on the iGyro .. cool device!
Dave
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 53
RE: Powerbox iGyro - 5/14/2012 2:58 PM
gonzalom
Score: 100
Status: online
Thanks Dave for the quick response!
Gonzalo
Hide Signatures
(in reply to ww2birds)
       Post #: 54
RE: Powerbox iGyro - 5/17/2012 8:14 PM
Andrew Bailey
Score: 100
Status: offline
Powerbox iGyro with Futaba S.Bus receiversPowerbox iGyro ordered on Monday, arrived today (Wednesday)  Beautiful box of tricks. Looks very well made and robust.
I had to read the manual a few times before I felt I understood how it works and the setup process. Very simple installation and setup involves just three flights to set the gain for both normal and heading modes on each axis.
Two things strike me about this product as being really important and as big differentiators from alternative gyro systems.
  1. The iGyro gives you receiver redundancy without having to buy a full bown Powerbox. So, combined with a Sensor Switch for power redundancy it gives you a much more robust setup.
  2. The iGyro works in both 'heading' mode and 'normal' mode at the same time. When the stick is centered it automatically switches that axis to heading mode. As soon as the stick is moved away from centre is switches to normal mode. The exception is the rudder which only works in heading mode when the 3rd Flight Mode is selected.
All I need to do is work out how to free up the two channels I need for setting the gyro up. I could really do with an 18ch radio!  I will report back when I have installed, set up and flown with it. So far I am very impressed.
< Message edited by wearypanda -- 5/17/2012 8:59 PM >
Hide Signatures
       Post #: 55
RE: Powerbox iGyro - 5/21/2012 3:07 PM
Andrew Bird
Score: 110
Status: offline
Gerhard at Aircraft International now has these in stock in the US http://www.aircraftinternational.com/
I picked one up at Joe Nall and have installed it in an electric set up before I put it in the jet. It's an impressive unit and set up so far seems to be relative simple, even for an idiot like myself. Hopefully I will fly it in the next day or so and see what it can do.
Hide Signatures
       Post #: 56
RE: Powerbox iGyro - 5/21/2012 3:26 PM
quist
Score: 116
Last Login: 6/19/2013
Status: offline
Andrew,
It was nice meeting you Friday. I think I am going to do the same. I am going to test it in my Sebart SU29 before it goes in the F-16.
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
(in reply to Andrew Bird)
       Post #: 57
RE: Powerbox iGyro - 5/21/2012 3:47 PM
Andrew Bird
Score: 110
Status: offline
Good to meet you too, Tony.
I have installed mine in a 60" EF Extra. As I'm on JR it means I can play with the inbuilt RX as well. All the channels are assignable so it means I've been able to use a gyro channel for the throttle and shut the Gyro off on that channel.
Just need it to stop bloody raining here so I can play with it
Hide Signatures
(in reply to quist)
       Post #: 58
RE: Powerbox iGyro - 5/21/2012 6:24 PM
Bob_B
Score: 100
Status: online
quote:
ORIGINAL: ww2birds
Dave,
Do you know if the Robbe/Futaba S-BUS PSS-2018 ''powerbox'' (see: http://shop.rc-electronic.com/e-vendo.php?shop=k_emcotec_e&SessionId=&a=article&ProdNr=RF1660&t=861&c=1786&p=1786 ..they call it a ''power supply'' ) might acutally be OEM'd from the Powerbox guys?
Dave
Nice looking piece of electronics Dave
Cincinnati Jet Club, Team Futaba, Wren Turbines USA
Hide Signatures
       Post #: 59
RE: Powerbox iGyro - 5/22/2012 4:17 AM
ww2birds
Score: 105
Status: offline
Yes, it's cool, even better "in the flesh" than I expected. Reading the manual for it, I did not realize that the Spektrum satellites output was the demodulated serial data stream, just like S-Bus .. so it makes sense it can take Futaba or Spek satellites as inputs. Learn something new every day...
I think I'll have to give Brother Gearhardt a call to get an iGyro!
Hope to see you this summer at some of the events...
Andrew .. let us know how the iGyro works for you.
Dave
Hide Signatures
(in reply to Bob_B)
       Post #: 60
RE: Powerbox iGyro - 5/23/2012 9:18 PM
Rezagh
Score: 100
Last Login: 6/17/2013
Status: offline
Hi Guys,
Love to hear how it works out for you.
I have one to do a review on FG. Just waiting for my transmitter to come back from tuning!
Jack Price at Duralite also has them on order and will receive a shipment very soon!
I would love to hear how it's working out for you on different planes.
Please share it here once you have yours going.
Cheers,
Reza
HorizonHobby, DuraliteFlightsystems
DesertAircraft
Hide Signatures
       Post #: 61
RE: Powerbox iGyro - 5/23/2012 10:27 PM
kev-o
Score: 100
Status: offline
Hoping jack gets them soon he's coming up to our event in a week and hoping to see one in the flesh.
if ya aint burnin well?
Hide Signatures
(in reply to Rezagh)
       Post #: 62
RE: Powerbox iGyro - 5/24/2012 10:09 PM
Andrew Bird
Score: 110
Status: offline
I've had the chance to play with mine this week as I've not been working. I should get some more time over the weekend but I've about 20 flights on it now.
I put it in my electric Extreme Flight 60" Extra before I put it in a jet to make sure I'm on top of how the whole thing works. It also gave me the chance to use it as a JR RX as well.
The EF 60" is an impressive little plane - it flies very well but I ended up using Savox servos in mine as Horizon were out of stock of the JR units I wanted to use. These servos aren't great, they're not as consistent as I'd like and happily wonder out of trim regularly. That said, gyro free the plane flies awesome and will happily make its way through the Unlimited IMAC sequence without issue other than those my squiffy fingers create
The set up was pretty simple and I managed to get the gain set for the 3 axis' wrapped up in a couple of flights. Switching the gyro on makes the plane fly like an even bigger plane. It becomes incredibly precise and it removes all the inaccuracies and inconsistencies of the crappy servos. It's quite incredible how it makes the plane feel, especially if you fly in a decent amount of wind. I flew today in 15kts of wind gusting 20kt and it was stunning how precise the plane stays in both precision and 3d. Like I said - the plane flies straight in the first place but it will be interesting to put this in something far more unstable. I suspect this technology will take a really poor flying platform and make a huge difference. It seems to be idiot proof in that you can take a poor set up and poor quality servos and sorts the mess out.... Looking forward to getting out and playing more before I stick in something a lot quicker and play with the GPS based speed function.
Hide Signatures
(in reply to kev-o)
       Post #: 63
RE: Powerbox iGyro - 5/24/2012 10:20 PM
Dave Wilshere
Score: 108
Status: offline
Birdy
My first del left Germany today...so we will be playing soon too!
D
Hide Signatures
       Post #: 64
RE: Powerbox iGyro - 5/24/2012 10:22 PM
Andrew Bird
Score: 110
Status: offline
Please find the crappiest plane you can find and put it in! I'm really intrigued to see what it can do
Hide Signatures
       Post #: 65
RE: Powerbox iGyro - 5/24/2012 10:37 PM
Andrew Bailey
Score: 100
Status: offline
I have about 20 flights now on an Sebart Angel 50e and my experience is much the same as Andrew's. I had a bit of trouble with a touch of wing rock coming out fast from downline manoeveres but was able to dial that out in a few flights. One additional observation I would make is that the instant you centre the sticks when in any kind of rotational manoever the plane rotation (in whatever axis) just stops dead. It is like flying a plane with absolutely no rotational inertia.
I am very impressed with the iGyro. Just wish that I had not lost the jet in which I was intending to install it .
Andrew
Hide Signatures
       Post #: 66
RE: Powerbox iGyro - 5/25/2012 8:05 AM
Dave Wilshere
Score: 108
Status: offline
We have a series of test models lined up from Big Petrol models, to Hunters :-) I guess my DJ Vampire would be a good choice as it needs a rudder gyro and would benefit from an aileron gyro too.
Dw
Hide Signatures
       Post #: 67
RE: Powerbox iGyro - 5/25/2012 10:44 AM
Ali
Score: 135
Status: offline
Just arrived. I could go and fit it and have a play this weekend, although the only model I have that "needs" a gyro only needs a bit of help on the rudder, and this I gyro may be a tad overkill for it.
Click to see fullsize image.
Click for fullsize
Al''''s Hobbies. Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, FEJ, pull over, Tomahawk, Skygate, C-ARF, Jet-Teng,Kingtech
Hide Signatures
       Post #: 68
RE: Powerbox iGyro - 5/26/2012 8:11 PM
ZivBit
Score: 100
Status: offline
quote:
ORIGINAL: Ali
Just arrived. I could go and fit it and have a play this weekend, although the only model I have that ''needs'' a gyro only needs a bit of help on the rudder, and this I gyro may be a tad overkill for it.
Hi Ali,
How about the Igyro on the SM A-4?
Cheers,
Ziv
Hide Signatures
(in reply to Ali)
       Post #: 69
RE: Powerbox iGyro - 6/2/2012 4:31 PM
jzuniga
Score: 105
Status: offline
How are guys setting their igyros with an Sbus setup? I mean, sbus servos? Assign servo specific function, then plug anywhere in the igyro? I'm not sure exactly how it works/supports Futaba sbus? save for the fact that I can plug an sbus receiver into it (or two) At least that's how I'm reading it from the manual. I'm thinking of getting an igyro, but I'm trying to fully understand and see how it would fit into my sbus set up? I can see the obvious advantages, in triple axis, and gps capabilities...but it appears you would have to run long extensions to all the servos like in a normal setup, thus, eliminating the cool features of sbus? I know I'm missing something here?Thanks
Z
Hide Signatures
(in reply to ZivBit)
       Post #: 70
RE: Powerbox iGyro - 6/2/2012 5:18 PM
Andrew Bailey
Score: 100
Status: offline
So far as I can tell it is not possible to output an S.Bus signal. It appears that the only S.Bus support is from the Rx to the iGyro. I hope someone can tell me different as I would like to install the iGyro on a jet using S.Bus on all flying controls. If I am right this seems to be a very odd omission by Powerbox.
< Message edited by wearypanda -- 6/2/2012 8:24 PM >
Hide Signatures
(in reply to jzuniga)
       Post #: 71
RE: Powerbox iGyro - 6/2/2012 7:34 PM
quist
Score: 116
Status: offline
I am running sBus to igyro for the 5 channels. AIL A and B, ELE a and b, and rudder. The other channels are plugged into channel 1-8 on the rx which is going through a power expander from Smarfly. I actually have the sBus also plugged into one channel of the PE.
I just removed it from the little pattern plane and installed it in the Aeroworks P-51. I am going to fly it in the morning.
Hide Signatures
       Post #: 72
RE: Powerbox iGyro - 6/2/2012 8:08 PM
jzuniga
Score: 105
Status: offline
quote:
ORIGINAL: quist
That's kinda what I thought? I guess with sbus servos though, you'd have to assign and plug the correct servo in to the igyro?
Z
Hide Signatures
(in reply to quist)
       Post #: 73
RE: Powerbox iGyro - 6/2/2012 8:09 PM
Richi-d
Score: 100
Status: offline
Hi Guys,
you can enable the Digital output. Then on Elevator B and Rudder you get a S-Bus output. It can be used to go into a SRS PowerBox, but you can also use it for S-Bus application. The channels you select for control surfaces in the "Input Maping" Menue are then with gyro signal on the output
Hide Signatures
(in reply to quist)
       Post #: 74
RE: Powerbox iGyro - 6/2/2012 8:23 PM
Andrew Bailey
Score: 100
Status: offline
That's great news. I missed that reading the manual. Thanks very much.
quote:
ORIGINAL: Richi-d
Hi Guys,
Hide Signatures
(in reply to Richi-d)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.125RCU1
