RE: Powerbox iGyro    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Powerbox iGyro
Page: <<   < prev  1 2 3 4 5 6 [7] 8   next >   >>
Login
RE: Powerbox iGyro - 12/15/2012 8:13 AM
Richi-d
Score: 100
Last Login: 3/15/2013
Status: offline
Hello Dennis,
normally there is no difference between receiver and iGyro- it´s a digital system. No offsets are there. Are you using the "Delta mixer"? Just a question...
Hide Signatures
(in reply to DennisCamps)
       Post #: 151
RE: Powerbox iGyro - 12/15/2012 4:02 PM
DennisCamps
Score: 100
Last Login: 3/25/2013
Status: offline
Hello,
I am not using the deltamixer.
and its only on one servo, although when i change the channels on the igyro from 2 to 8 and from 8 to 2 the problem is on the other servo.
Regards,
Dennis
Hide Signatures
(in reply to Richi-d)
       Post #: 152
RE: Powerbox iGyro - 12/16/2012 9:46 AM
davo580
Score: 100
Last Login: 5/20/2013
Status: offline
you guys need to learn to set upt your models properly instead relying on gyros
Hide Signatures
(in reply to Fortune7)
       Post #: 153
RE: Powerbox iGyro - 12/16/2012 3:40 PM
DelGatoGrande
Score: 105
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: davo580
Jets.. 2 liters of moving fuel (=2kilos) in the tanks changing your CG all the time during landing...deltas with duch roll effects that no pilot can catch up with the rudder input to cure this.
how you set this up?
_____________________________
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
(in reply to davo580)
       Post #: 154
RE: Powerbox iGyro - 12/16/2012 4:25 PM
Andrew Bailey
Score: 100
Last Login: 5/22/2013
Status: offline
Troll.....
quote:
ORIGINAL: davo580
Hide Signatures
       Post #: 155
RE: Powerbox iGyro - 12/17/2012 8:06 PM
DennisCamps
Score: 100
Status: offline
Hi again,
I tested the igyro, made some mistakes because it was like freezing so i didnt fly it at quarter speed to set the gains en then increase the speedfactor :d
So it wil be even better, it was great allready.
I have to say its pretty wierd to fly turns with heading on the tail it where knife edge turns...
Okey i have one question,
I noticed that when i did a pass the model went down a bit when centering the elevator stick.
This is probably because i did something wrong with the zero gyro function, correct?
So what is not clear is this. do i need to move the sticks to all directions and endpoints when the ball in front of "zero gyro"is solid of when its hollow.
Or do i need to wait til its hollow and then move the sticks?
I did the first thing...
Cheers,
Dennis
Hide Signatures
(in reply to Andrew Bailey)
       Post #: 156
RE: Powerbox iGyro - 2/3/2013 6:28 PM
EUROSPORT JET IRELAND
Score: 100
Last Login: 5/14/2013
Status: offline
ANYONE USING THE POWERBOX GYRO WITH THE MULTIPLEX ROYAL PRO. I HAVE THE UNIT CONNECTED DIRECTLY TO A MPX 16 CHANNEL RX BUT CANNOT GET IT TO OPERATE????
WOULD APPRECIATE ANY HELP.
Hide Signatures
       Post #: 157
RE: Powerbox iGyro - 2/3/2013 6:42 PM
DelGatoGrande
Score: 105
Status: offline
you can always email PowerBox at info@powerbox-systems.com and ask
and have a look in PowerBox new forum http://forum.powerbox-systems.com
my 2c
Hide Signatures
(in reply to EUROSPORT JET IRELAND)
       Post #: 158
RE: Powerbox iGyro - 2/13/2013 10:13 PM
Score: 100
Status: offline
Has anyone used the multiplex Royal Pro radio with the Powerbox Gyro?
Would appreciate some help setting up.
JB
Hide Signatures
(in reply to rc4flying)
       Post #: 159
RE: Powerbox iGyro - 3/9/2013 12:41 AM
Gonzalo38
Score: 100
Status: offline
I've been able to connect the iGyro to the Powerbox SRS Cockpit without a problem, but I haven't had the same luck with the Powerbox Royal. Just can't figure out the correct connection to make it work.
My Powerbox Royal is working with two (2) Futaba 6014HS receivers.
Anybody with experience on the iGyro and this Powerbox ?
My Gallery http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=314761
Hide Signatures
       Post #: 160
RE: Powerbox iGyro - 3/9/2013 1:24 AM
quist
Score: 116
Status: offline
THe Igyro does not work with non Sbus Futaba receivers.
If you don''''t have time to do it right the first time, when are you going to find time to do it again?
Hide Signatures
(in reply to Gonzalo38)
       Post #: 161
RE: Powerbox iGyro - 3/9/2013 2:58 AM
Gonzalo38
Score: 100
Status: offline
The strange thing is that instructions mention that the iGyro can work with normal powerbox systems (at least that's what I understand)
ç
And then in the specifications it talks about Futaba but not that it needs to be Futaba S-Bus.
I would just hate to think that I just spend US$ 550 in something that won't work for me.
Hide Signatures
(in reply to quist)
       Post #: 162
RE: Powerbox iGyro - 3/9/2013 7:25 AM
quist
Score: 116
Status: offline
Read the instruction at the top of page three. It requires a receiver that works with a serial stream. All of the surfaces and the gyro control have to work off of one output of the receiver to one input of the gyro.
If you use a Futaba Sbus rx you can make it work with the powerbox Royal.
Hide Signatures
       Post #: 163
RE: Powerbox iGyro - 3/9/2013 12:06 PM
smchale
Score: 115
Status: offline
Glad I saw this. Was interested in the iGyro but all my jets use the R6015 RX (no power box). I don't believe they make anything more than an 8 channel sbus RX, correct? After all, the point of sbus is to reduce channels and leads and also to utilize the programmable sbus servos.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to quist)
       Post #: 164
RE: Powerbox iGyro - 3/9/2013 12:29 PM
felker14
Score: 100
Status: offline
Just use Futaba rx R6208SB (8 channel output rx with 1 SBUS port). iGYRO gets SBUS port which runs rudder, aileron and elevator. Flaps, throttle, brake, smoke can be run on channel 1 - 8
RC Hobby..... ($100.00 foamie = toy, $20,000.00 jet = toy)
Hide Signatures
(in reply to smchale)
       Post #: 165
RE: Powerbox iGyro - 3/9/2013 12:38 PM
smchale
Score: 115
Status: offline
quote:
ORIGINAL: felker14
Ah. Does it run dual aileron servos (naturally), dual elevator servos, and dual rudder (rudder and nose wheel) servo assignments?
Sean McHale
Hide Signatures
(in reply to felker14)
       Post #: 166
RE: Powerbox iGyro - 3/9/2013 12:44 PM
felker14
Score: 100
Status: offline
single rudder, dual elevator and aileron
Hide Signatures
       Post #: 167
RE: Powerbox iGyro - 3/9/2013 12:56 PM
smchale
Score: 115
Status: offline
Ok, thanks!
Sean McHale
Hide Signatures
       Post #: 168
RE: Powerbox iGyro - 3/9/2013 6:35 PM
quist
Score: 116
Status: offline
I am using one with the 6208 sbus rx and no power system and it works great.
Hide Signatures
       Post #: 169
RE: Powerbox iGyro - 4/14/2013 12:52 PM
smchale
Score: 115
Status: offline
At the moment I'm running a R6014 RX with dual switches and dual A123 packs. To switch to the igyro, besides changing the RX to an 8ch SBus RX, how should I handle the power, without going to a power box dist system? Just run power to two open channels in the RX? Should I use dual rx's and run a pack/switch to each one? I want to understand my options before spending the $$, as I don't really need one, but would like to try it. Thanks!
Sean McHale
Hide Signatures
(in reply to quist)
       Post #: 170
RE: Powerbox iGyro - 4/15/2013 12:53 AM
quist
Score: 116
Status: offline
I used it with a single rx. I ran one power source to the rx and one to the open rx port on the igyro.
Hide Signatures
       Post #: 171
RE: Powerbox iGyro - 4/15/2013 1:01 AM
ww2birds
Score: 105
Status: offline
In the iGyro manual, it tells you not to make any connections to the SBus2 port.
One way to interpret this is that no connections to SBus2 are required to operate the iGyro. The other way to interpret it might suggest that when using the iGyro you can't use the SBus2 functions (e.g. telemetry inputs).
Anyone know what the correct interpretation might be?
thanks
Dave
Hide Signatures
       Post #: 172
RE: Powerbox iGyro - 4/15/2013 1:16 AM
quist
Score: 116
Status: offline
SBUS2 is a different type of signal(it sends and receives data). Futaba states that only sbus2 compatible items should be plugged into that port.
Hide Signatures
(in reply to ww2birds)
       Post #: 173
RE: Powerbox iGyro - 4/15/2013 1:57 AM
ww2birds
Score: 105
Status: offline
Yes, that is correct. For example the telemetry devices .. I am using the GPS sensor on the SBus2 port. I see they also now have servos that work on Sbus2 which is interesting.
I am curious if it is an issue to be using the SBus2 port for telemetry while using the regular SBus to feed the iGyro. My assumption is that it is fine, but the way the iGyro manual is worded leaves it open to some interpretation.
Dave
Hide Signatures
(in reply to quist)
       Post #: 174
RE: Powerbox iGyro - 4/16/2013 1:54 PM
ww2birds
Score: 105
Status: offline
Update: I checked with the Powerbox people in Germany. No problem to use Sbus2 port for telemetry when using the iGyro on the normal Sbus port.
Dave
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.961RCU1
